Old 01-25-2010, 02:05 PM   #1
justpball
justpball's Avatar
late build thread...LOL
ok so everyone keeps asking me about a build thread so I guess I will try to create one, so there may be a few steps left out along the way...LOL, if you have any questions just ask... here we go. Picked up a taterd Burb for some chump change.
Then got her some new shoes, also dropped it some, pulled 2 leafs in the rear, and chopped some 06 chevy coils down and put them in.
Then about 6 months later started the body work for paint...and traded the 22s for some coys so I could keep my AC when I bagged it.
While we had it tore apart at the body shop i started get up parts for the air ride.
here it is after I bagged it,
Then it was not low enough so I chopped the crossmember and cut the cups down to 1.25 inches
Fuzzy Dice Club Member
87 Crew SWB
Build for the crew
http://67-72chevytrucks.com/vboard/s...d.php?t=430082
http://www.cardomain.com/ride/3232925
90 burb 2wd
Build Thread For The Burb!
http://67-72chevytrucks.com/vboard/s...d.php?t=383055
justpball is offline   Reply With Quote
Old 01-25-2010, 02:19 PM   #2
justpball
justpball's Avatar
Re: late build thread...LOL
ok so here it is after the chopped xmember
it sits on the front spoiler and the tires are touching the inside of the fender...
Nice but the front bags were touching the a-arm, so i put the 2.5 cups back in and am sinking some 9 inch pipe down into a set of a-arms... so this is it with the bigger cups in.
87 Crew SWB
Build for the crew
90 burb 2wd
Old 01-25-2010, 02:44 PM   #3
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Damn that's sick. The ultimate road trip wagon.
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 01-25-2010, 02:46 PM   #4
justpball
justpball's Avatar
love taking it on the Hway! it rides like a caddi!
87 Crew SWB
Build for the crew
90 burb 2wd
Old 01-25-2010, 09:15 PM   #5
Driveway Dreams
I have car A.D.D.
Driveway Dreams's Avatar
Your Burb looks killer as usual. Do you have any close up shots of your headlight bezels after you "cleaned them up"?
-Gerald
Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace.
61 GMC Suburban SOLD
The 86 build thread SOLD
Are you a Colorado member?Click here.
Driveway Dreams is offline   Reply With Quote
Old 01-26-2010, 09:24 AM   #6
justpball
justpball's Avatar
I will take one for you...
87 Crew SWB
Build for the crew
90 burb 2wd
Old 01-26-2010, 09:42 PM   #7
menace121978
menace121978's Avatar
sick! outstanding job man!
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 01-26-2010, 11:10 PM   #8
Driveway Dreams
I have car A.D.D.
Thanks! How bad were they before? I am thinking about doing mine, but not sure yet.
-Gerald
Old 03-20-2010, 10:53 PM   #9
justpball
justpball's Avatar
here is the rear stuff
87 Crew SWB
Build for the crew
90 burb 2wd
Old 03-21-2010, 02:07 AM   #10
joe231
joe231's Avatar
I love your 'burb!!!
What are the specs on the coys?
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 03-21-2010, 08:08 AM   #11
hotrod_991
hotrod_991's Avatar
i see you fliped the axel and bagged it but kept you leafs and didnt cut the hell outa the botom fo the body. doesnt that make it harder for the bags to raise the frame aways from the axle? sorry dont know alot about bags but thinking about it on my C10 lwb but I dont want to cut up my bed or run a four link. Would rather keep the leafs and my trac bars.
"Buckle up I wanna try somethin!!"
"of course it will hold!, I welded it!"
1977 c10 under knife for full rebuild, 5.3l 4l60e drive rain swap, replacement frame and green repaint
hotrod_991 is offline   Reply With Quote
Old 03-21-2010, 02:50 PM   #12
79gmc5.3
6.0L power.........
79gmc5.3's Avatar
Very nice paint job!! Love the colors and that stripe!!!
What ever the mind of man can conceive......... he can achieve!
My built thread http://67-72chevytrucks.com/vboard/s...d.php?t=375914
1979 GMC Sierra 6.0 L 4L60E
1995 Mustang GT 347
79gmc5.3 is offline   Reply With Quote
Old 03-21-2010, 06:50 PM   #13
johnnyrvan
johnnyrvan's Avatar
dang seeing that makes me want to get another burb looks nice
If your gonna be a bear, be a Grizzly
johnnyrvan is offline   Reply With Quote
Old 03-22-2010, 07:31 PM   #14
justpball
justpball's Avatar
The coys are 20x10 on rear 5.5 BS, 18x 8 on front with 4 BS
87 Crew SWB
Build for the crew
90 burb 2wd
Old 03-24-2010, 08:17 PM   #15
87 dually burb
my short bus
87 dually burb's Avatar
3 quick questions for you
what size gas tank are you running?
how close to ground is tank when aired out?
frame to ground in rear aired out?
thanks
I just ripped all my tub work back out raising gas tank
and 3/4 link setup soon building rear to lay body
removing pinch weld and doing 2"x4" frame center section
**90 burb**bagged,shaved**(about done)*********
**91 burb**stock worker for now****************
*********only squares for me******************
87 dually burb is offline   Reply With Quote
Old 03-25-2010, 09:18 AM   #16
justpball
justpball's Avatar
I am still running the stock 35 gallon tank in the stock location, it is about 3 inches off the ground, the frame is about the same. I took the gas tank skid plate off my 4x4 burb and put it on this one so if it drags it is not a big deal, but I still have my hitch on here and it drags before the tank does!
87 Crew SWB
Build for the crew
90 burb 2wd
Old 03-25-2010, 10:22 AM   #17
justpball
justpball's Avatar
here ya go
87 Crew SWB
Build for the crew
90 burb 2wd
Old 03-25-2010, 10:29 AM   #18
justpball
justpball's Avatar
here is what I am doing next!
87 Crew SWB
Build for the crew
90 burb 2wd
Old 03-26-2010, 11:15 AM   #19
nlped
nlped's Avatar
^^^That's good work! Looks great...well once it is all cleaned and sprayed, it will be great looking!
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 03-26-2010, 11:34 AM   #20
justpball
justpball's Avatar
getting them powdercoated hammertone silver, I have the upper ones as well that we cut and angled down to keep the ball joints from binding
87 Crew SWB
Build for the crew
90 burb 2wd
Old 03-29-2010, 08:23 PM   #21
cochino12
It followed me home?
cochino12's Avatar
I see you are running 18" & 20"s what size are the tires? Also would you mind measuring your fender wells in front and back when its aired out? thanks
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 03-29-2010, 09:21 PM   #22
87 dually burb
my short bus
ok I'm ready to see the front aired out with the new arms
so when are you starting on the back
Old 03-29-2010, 11:37 PM   #23
Driveway Dreams
I have car A.D.D.
here ya go
Beautiful, thank you. May have to do that to mine at some point.
-Gerald
Old 04-29-2010, 11:42 AM   #24
justpball
justpball's Avatar
265-35-18,and 285-30-20, the front fender well is 22 in from the ground and the rear is 21 in
87 Crew SWB
Build for the crew
90 burb 2wd
Old 04-29-2010, 11:53 AM   #25
justpball
justpball's Avatar
here is what I am currently working on, because I am still waiting on my other coys to come in...
87 Crew SWB
Build for the crew
90 burb 2wd
