Old 01-26-2010, 02:09 PM   #1
CPPJEFF
CPP Totally Tubular Rear suspension! A CPP crowd favorite!
Guys take a look at this kit! Although it has been out a few years and we have sold quite a few i wanted to put it up and talk about the features and benefits and also answer any questions. Keep in mind this is an entire kit but it can be ordered in individual parts. This kit fits the 63-72 Chevy Trucks and has numerous benefits and a clean custom look. Benefits such as added exhaust clearence, increased ground clearence, corrected pinion angle, increased driveline clearence, adds torsional rigidity and additional strength. CPP'S tubular trailing arms are manufactured with a laser cut and formed spring platform fabricated to a CNC bent heavy wall 2" DOM tube body. The bushings are made of a "NEW" patented D-spec heat resistant, self-lubricating material that offers long life and remarkably quite, comfortable ride. This complete kit was designed with lowered trucks in mind, correcting the pinion angle that is affected with lowered coil and airsprings. The crossmember will bolt into the original location and work with factory trailing arms. This will correct pinion angle associated with a lowered truck and offers 3" by 5" exhaust openings. WE ALSO MAKE THIS KIT NOW FOR THE 73-87 CHEVY TRUCKS THAT CONVERTS LEAFSPRINGS TO COILSPRINGS!! If you guys need a kit or parts of this kit i will get you guys a great deal. Thanks :Sidenote. that silver bar across the c-notch is for display only it is not a part we sell or that you need.
CPPJEFF is offline   Reply With Quote
Old 01-26-2010, 03:47 PM   #2
HarrolLS1
HarrolLS1's Avatar
Re: CPP Totally Tubular Rear suspension! A CPP crowd favorite!
Thanks for explaining the purpose of the cross bar.
I thought it was for mounting the shocks. To bad; the bar looked cool.
Is there any chance of CPP seeing if the "73-87 conversion kit" could be used in converting 4WD 69-72 chevy blazers to 2WD?
It seems the main questions are, would the CPP c-notch/spring mount work on the Blazer 4WD frame and would the cross member fit inside
the frame rails.
Thanks for your efforts to improve customer service.
Harrol
1968 SWB
1968 SWB 4x4
1969 Suburban
1970 LWB
1970 Blazer
2002 Tahoe
Inside every older person is a younger person wondering what happened
HarrolLS1 is offline   Reply With Quote
Old 01-26-2010, 04:59 PM   #3
panic66
hey jeff how easy is it for the trailing arms to work with air bags?
panic66 is offline   Reply With Quote
Old 01-26-2010, 06:22 PM   #4
JW76
JW76's Avatar
does it work on both long and short bed 73-87s? thanks
JW76 is offline   Reply With Quote
Old 01-26-2010, 09:20 PM   #5
DKN
Active Member
Currently we have these for short bed 73-87's. We have not installed one on a long bed yet so we do not know what all the differences are between the two chassis.
Danny Nix
CPP
DKN is offline   Reply With Quote
Old 01-26-2010, 09:23 PM   #6
DKN
Active Member
On the air bag trucks we installed it was very easy. The bottom of the air bag bolted upto the trailing arm without any mods. We had to drill a hole for the air fitting to fit thru the frame at the upper air bag mount. Everything else was the same as a coil spring install.
Danny Nix
CPP
Old 01-26-2010, 09:33 PM   #7
DKN
Active Member
Some more FAQ's:
The crossmember has 3-3/8" by 5" oval holes so you can easily tuck 3" exhaust up above the bottom of the frail rail.
There is an optional bracket that allows you to use the 2 piece drive shaft. The bracket and carrier bearing are shown in the photot Jeff posted.
There are provisions for your parking brake cables in both the crossmember and the tubular trailing arms.
If you tucked up the exhaust by adding the CPP trans crossmember, and used the CPP tubular lower control arms in the front the lowest point on the truck will become the U-bolts that mount the front control arm cross shafts.
This set up on air bags is killer when it sits that low.
Danny Nix
CPP
Old 01-26-2010, 10:35 PM   #8
Eighty-6
Really good looking product. What's the damage on price for the 73-87 version? Do you sell one with bags instead of springs? Oh and one more question how does it compare to the 4-Link AirBAR from RideTech?
Eighty-6 is offline   Reply With Quote
Old 01-27-2010, 03:41 AM   #9
bluex
bluex's Avatar
CPPJEFF,
Let me know when you need a real world home hotrodder garage install article on the 73-87 kit.
Till then I'll keep saving. Unless you guys take trades....
I would like to see a picture of the 73-87 kit outside the truck like the 67-72 is above.
bluex is offline   Reply With Quote
Old 01-29-2010, 04:57 PM   #10
Dynomutt
Dynomutt's Avatar
What kind of "great deal" can you do? I've been thinking about doing one of these setups in a 72 LWB and have a few questions.
Can you get the 4" heavy duty springs with it?
Do you have sway bar setup for it?
Do you sell any braided stainless e-brake cables for it?
What type finish is it, raw, paint, powder? If paint or power, what color (s)?
Looking to do this and possibly the upper and lower control arms so PLEASE make me a smokin deal so I can get it all at one time.
Shoot me a PM or I can call you if we need to talk about it.
MARQ
Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=446194
Dynomutt is offline   Reply With Quote
Old 01-29-2010, 05:43 PM   #11
pcmcobra
pcmcobra's Avatar
whats the price on the 73-87 kit?
1986 C10 SWB 6.0/6l90e
Miami...Flee it like a native
pcmcobra is offline   Reply With Quote
Old 01-29-2010, 05:46 PM   #12
Eighty-6
x2
Old 01-30-2010, 08:26 PM   #13
bluex
bluex's Avatar
Originally Posted by Eighty-6 View Post
x2
From the site the kit with trailing arms is $1199, without is $609.
Old 01-31-2010, 12:00 AM   #14
pcmcobra
pcmcobra's Avatar
Ya but he said he could get us a good deal...
Old 01-31-2010, 02:08 PM   #15
Wild83C10
Wild83C10's Avatar
Can you buy just the crossmember for the 73-87 trucks?
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
Old 01-31-2010, 04:24 PM   #16
BIG KRIS
BIG KRIS's Avatar
I emailed you about this and never got a response on priceing for members if there is one.
Flowershop Hip Hop & Street Rods
Dropmember
83 Custom Deluxe Almond on Almond
85 Silverado White on Red/Now Chevy LeMans Blue
Rendering in Truckin magazine vol 36 no. 11,2010
BIG KRIS is offline   Reply With Quote
Old 01-31-2010, 04:35 PM   #17
BIG KRIS
BIG KRIS's Avatar
Fellas i dont know how to post pics or video on there but they have a nice video of their 79c10 called extreme manuvers on their site and its on youtube.It shows the truck going through a road coarse and doing a braking test.
Dropmember
Old 02-01-2010, 02:23 AM   #18
bluex
bluex's Avatar
Ya, just thought I would put it up so you had an idea since they have not put up a price. Its a little hard to find on their website.
Yes I asked in another thread if they would sell the kit cheaper without the crossmember. He said he could sell any part of the kit seperate.
Old 02-01-2010, 12:40 PM   #19
CPPJEFF
Yes just bolt them right to the trailing arm.
Old 02-01-2010, 12:42 PM   #20
CPPJEFF
CPPJEFF,
Right on Paul, i might be able to cut you a deal on a kit and the trade no sweat send me a pallet of sanity and you can have the whole kit!!
Old 02-01-2010, 12:43 PM   #21
CPPJEFF
Its about the same price as the 6372 kit. I will take a picture today and post it. Thanks
Old 02-01-2010, 12:44 PM   #22
CPPJEFF
I will call me and we will talk, 888-522-8303 ext 118. Thanks
Old 02-01-2010, 12:44 PM   #23
CPPJEFF
Sure no sweat!
Old 02-01-2010, 12:45 PM   #24
CPPJEFF
Yes we still own that truck, let me see if i can post the video fron the roadcourse, it was sick!
Old 02-01-2010, 12:46 PM   #25
CPPJEFF
Who did you e-mail? Im confused, i will answer any question you have. Thanks
