02-06-2010, 11:54 PM | #1 |
Broke the rearend.
Hey guys, Im new to the forums. My name is Chris. I have a '68 pickup that has been a good truck sofar. I decided to mess around with it a little bit to see if it would do a burnout. Put it in 1st(its a 3 speed with 292) and dumped the clutch(not really sidestep, just released it quickly) First time was awesome. Didnt break a sweat, but the second time made some bad noises. The driveline was dragging, and the diff on the 12 bolt was turned up way further then it should be. It broke the welds that keep the diff from twisting. Iv never seen this or heard of it. I don't think it will be too hard to fix, but I thought id share my little mishap. I think I can turn it back down and weld it back together. If not, i'll look for another 12bolt. No more beatings for this old pickup, I like it too much to keep breaking it. Pics:
02-07-2010, 12:55 AM | #2 |
Junior Member
Re: Broke the rearend.
Wow!! alot of tourqe or just old age!!
I,m not suprised the axle welds sheered off!! that was a weekness in the GM axles!! I would take it to a drive line shop to make shure the axles strait across! Love the One Tire Fire Mark!!
1968 LWB C10 "Project LADY EYE SORE" (She is my baby and sent me to the hospital 3 times for eye injuries lol) who said love hurts?? |
02-07-2010, 12:59 AM | #3 |
I suppose I beat on it a little harder then I should have. This old 292 sure runs strong. anyways, A driveline shop huh? I was hoping I wouldn't have to pull it lol.
02-07-2010, 01:02 AM | #4 |
Cops, ha, catch me if you can!
NICE! It showed you it has no prob laying down rubber. On the other hand it showed you it has no prob hooking up either
Hope its an easy fix, keep us updated.
72 C-10 Stepper 350/TH350 3.73 in the back Edelbrock intake and Carb Hooker Comp Headers 275/60R15 on Rallies Last edited by gonzo6869; 02-07-2010 at 01:03 AM. |
02-07-2010, 01:06 AM | #5 |
WOW, I broke the spider gears in mine because I did two many a one-wheeled burnouts with my 383, but I never suspected that you could break those welds without breaking an axle or the diff carrier.
this is what I did BTW, welcome and congrats on a fine looking truck
-- Josh Instagram: @americanmusc1e OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread 1999 4wd OBS Tahoe - daily. DM me if you can't see photos i posted |
02-07-2010, 01:09 AM | #6 |
Thanks for the great replys. I really do like this truck. I sold my subaru to get it, and I don't regret it at all. I know i didn't break the diff or the trans. I think I got lucky on this one. I have heard the 3 speed column shift transmissions don't take too much abuse. Im hoping to have it fixed in the next few days. Thanks again.
Chris |
02-07-2010, 01:13 AM | #7 |
Best of luck...Sorry to hear of your mishap.
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
02-07-2010, 01:53 AM | #8 |
maybe swap axles with a good 10 bolt (trailing arm perches needed and shock mounts moved). i hear the 12 bolt is not as rugged as the 10 bolt. also remember nothing lasts long when you beat on it. make sure everything is in tip top shape and also maybe use synthetic fluid (diffs get hot). supertech, mobil 1 and several other brands make it. i put royal purple in my the 3onthetree in my 72 burb 3/4 ton and plan to change out the rear diff fluid in the HO52 when i swap in my 4.10 third memeber. i will be towing with my truck and the drivetrain only has 74,000 gentle miles and i plan to keep it in that condition.
02-07-2010, 03:20 AM | #9 |
Has more rust than truck...
Impressive! I've taken out some rearends but never done that....yet. I'd find another 12 bolt in a junk yard and swap it in, no fab required. Unless you like to modify then I'd skip the 10 bolt and go for a 9"
02-07-2010, 03:22 AM | #10 |
I dont plan on doing anything like that again. It was my stupidity, and I knew it might break. I'll look around for another 12bolt and be nice to it.
02-07-2010, 04:11 AM | #11 |
Welcome to the forum.
I pulled a similar stunt but I broke the front yoke off the driveshaft in my 4x4. |
02-07-2010, 06:21 AM | #12 |
Six in a row makes it go...
There's just a puddle weld that holds the tube into the main housing. That's why the differential shops do a 360 degree weld on the tubes when building up a performance rear.
Never underestimate the ability of a 292 to make gobs of low-end torque.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
02-07-2010, 06:50 AM | #13 |
kids....
lol if there's no damage to the axle other than the mounts, just weld it back down after you set it. I'm guessing you broke more than that though... |
02-07-2010, 07:16 AM | #14 |
Did it brake the u-joints or yoke at the rear-end, thats a lot of angle for a spinning mass. Also the first time for seeing this happen. Awsome burnout man!!! Fix what you got, as long as the tubes didn't bend or crush/twist up where they go into the diff. housing or at the perches. Good luck.
02-07-2010, 07:49 AM | #15 |
nice peg leg burn out
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
02-07-2010, 08:39 AM | #16 |
I agree, if it isn't leaking, weld it. I would tack it in, spin the yolk and see if the rear is making any noise. If all else fails, replace it. But it would suck if you replace it and all it needed was to be re-welded
02-07-2010, 10:20 AM | #17 |
[QUOTE=bigsnookmaster;3785577]I agree, if it isn't leaking, weld it. I would tack it in, spin the yolk and see if the rear is making any noise. If all else fails, replace it. But it would suck if you replace it and all it needed was to be re-welded[/QUOTE YOU BET.. I'D LOOSEN THE U-BOLTS , TURN IT BACK WHERE THE OLD WELD MARKS LINE UP & WELD IT. HECK YOU ONLY GAMBLE 15 MINUTES. YOU JUST MIGHT GET LUCKY. IT'S SURE WORTH A TRY. JOHN
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
02-07-2010, 01:23 PM | #18 |
PROJECT 7DEUCE
Power of the six popper....
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
02-07-2010, 01:55 PM | #19 |
Hey nice job! lol
I broke the spring perch's off my axel on the 70 camaro I had years ago. Thats what happens when you put slicks on it at the drag track and it really hooks up after a burnout lol. The diff twisted up so hard,the u joint broke and the yoke punched a hole through the floor. HAHA that was the last time I took it to the track! Another time I blew the rear up and broke the c clips, both axels slid out and set the diff almost on the road, what a sight that was through the side mirrors with the wheels/tires running about 2' outside the fenders! That was funny, my friends never let me forget that one.
"I'll Procrastinate Tomorrow" quote by LEEVON 71 K10 long fleet (sons truck) new 370hp 355, sm465 np205, 3.73's 33's 70 K20 long fleet 98 G3500 work van |
02-07-2010, 02:02 PM | #20 | |||
"I ain't nobody, dork."
Gary
02-07-2010, 02:03 PM | #21 |
yeah.....straight 6's are very efficient and make great low end torque, especially the big boy 292. that's why they put an I6 in the trailblazer instead of sticking with a v6 like in the old s10's. with or without work, they make great towing engines due to their low rpm performance characteristics compared to V engines. the 292 also has a 4-1/8 inch stroke which is pretty much unmatched even by modern stroker engines.
you can hot rod up the 292 with a 4 barrel intake, split exhaust manifold to go dual exhaust. that magnaflow x-pipe ss exhaust for the 67-72 would probably work great with a little tweaking to match up. there are also roller valvetrains and you can put a petronix kit in the factory distributor for electronic ignition. they even have a TBI system for the 292 i hear. i'd love to put a modernized 292 in an early 50's burb or panel truck (i like the 1 ton extended wheelbase). but i have my 72 burb and many other projects needing my time and money. |
02-07-2010, 02:50 PM | #22 |
the boat guy
definatly want to make sure the driveshaft is still relativley straight, make sure the pinion and pinion yoke arrent damaged.
hell id bolt the rear end down and take a gentle ride around the block before i even bothered welding it. who says a I6 couldnt do a burnout, heres a memeber winning the 09 midwest all truck nationals burnout contest with his 250 w a 3 speed.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
02-07-2010, 03:47 PM | #23 |
It has something to do with the 10 bolt having a larger pinion shaft.
02-07-2010, 05:30 PM | #24 | ||
It might have a larger pinion shaft but is a weaker unit all together. If they were that solid of a rear end, there would be more people swappin' out 12 bolts for 10 bolts...
Gary
02-07-2010, 08:54 PM | #25 |
So I found out its a lot harder to twist that back to the stock location then just "twist it back". I think I will have to put a chain around the yoke and under the diff and see if I can pull that back and twist it down.
