Jason
71 C-10 Big Block Swap
Sold the small block to fund the big block swap. Here are the specs and some pics of the new rat.
454 .030 over GM Steel Crank GM Double Dimple Rods with 7/16 fasteners TRW Forged Dome Pistons L2349F 781 Oval Ports with 2.19 1.88 valves Lunati Hydraulic Roller 282/290 .600/.600 #60212 PRW 1.7 Ratio Rockers Edelbrock Performer RPM Airgap Holley 750 HP |
Re: 71 C-10 Big Block Swap
Looks awesome man. When ya gonna have it in and running.
I just put my bbc in my truck tonight |
motor exploder
Good looking truck and nice motor - glad to see the BBC's are getting some love!
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac ![]() ![]() Use the SEARCH function on this forum - it is your friend!! |
Jason
Cleaning up the firewall and frame rails for paint before installing. Should have it painted and the engine installed this weekend I will post some pics when it is in.
Kool we can stress test the turbo 350 and 12 bolt soon.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
Jason
Update got the firewall painted and engine installed. Have to get a convertor and headers so hopefully I will have it going soon.
Looks sweet.
theres nothing better than a BB, awesome ride!
Jason
Moved motor back 1"1/4 tonight. I did not like how close it was going to be to the radiator or how far is was from the firewall. Should help weight transfer a little anyway.
sweet bring a bunch of cash tomorrow and you can crank it this weekend.
What mount bracket is that? Will it let you go 3" back?
Jason
The mounts came from performanceonline.com. In small or big block applications they are made to mount in the forward holes on frame rails. You can use them in the rear most holes on frame for small block installation but the big block will not due to coming in contact with firewall. I moved it back as much as possible form front holes on frame and just redrilled the frame and crossmember to accept new location. It is back 1"1/4 from that point. In order to go back 3" you would have to modify firewall.
What is the benefit of those....I like the way they look. Stronger I guess since they are tubular. Are they easier to install the engine ?
'72 Chevy C10 383, 700r4, 3.73's A little rust never hurt anyone. I consider it weight reduction. |
Many Reasons. For one thing they are much cheaper than oe 72 up mounts. They are 129 for the mounts and the stands and they swap you to a car type mount so you can run solid mounts if you want. I would think they would help a little with hedder clearance and they should be easier to install.
#15 |
Jason
#16 |
#17 | |
Post a pic if you don't mind.
#18 |
This is the only pic I have on my computer. I'll have to go snap a pic of the mounts.
#19 |
Is the firewall notched?
#20 |
Redefining LowBudget
hey guys dumb question but how does the trany linkage line up ??? I'm getting ready to do a swap and was woundering if that was an issue??
#21 |
Jason
I have not got that far yet on swap but all factory linkage will interchange between big block and small block. The only issue I would think will be header clearance.
#22 |
thanx I'm putting a caddy in mine so when I slide things in I thnk the linkage will be a good point to determine how far forward/back the motor need to be?? I'm going to have to make up a drive shaft anyway....
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. ![]() Mikes Sandwich Fair Run OCT 8th 2011
#23 |
#24 |
Junior Member
Good looking 454s.
We just put a '74 454 from a C-30 into my '71 lwb stepper. We had to use the BB mounts out of a '75 to get the header clearance for the style hooker headers I have. This is not a power machine though, it is hooked to old style 4 speed transmission with an open 3.73 rear. We could not use any of the pre-drilled holes and be able to mate up to the transmission. I did not realize I would have a heat soak problem with my starter running headers so now I have to get a mini starter. I should have though since I know others have had the same problem. We used the BB radiator shroud out of the '74, but had to modify it some to clear the crank pulley, power steering pump and alternator. I still have not got around to taking pictures, I guess I better add it to my to do list. Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
#25 |
