Shlong Bed Club
Pipe Notch
stupid question, but does anyone have pics of a 60-66 with rear bags and just a pipe notch? (preferably aired out)
"If it ain't broke, hit it with a hammer, then fix it.." ![]() |
Shlong Bed Club
Re: Pipe Notch
no one?
Re: Pipe Notch
Get at shotbed,he welding some in his.I cant remember right off what size it was
http://67-72chevytrucks.com/vboard/s...=332884&page=9 |
Re: Pipe Notch
'77 GMC SWB '66 SNB (Project) Battle Ground, WA |
Shlong Bed Club
Re: Pipe Notch
exactly what i was was looking for, got any side pics aired out?
Re: Pipe Notch
Re: Pipe Notch
The notch was done by my friend Dan at Sick Industries. Its simple and works great. The cross member in front of the rear end has a small notch in it too to clear the rear end when air'd out. I had to raise the bed floor 2 inches to clear also.
[IMG] ![]()
SAVING ONE TRUCK AT A TIME
![]() Join Date: Feb 2010
Re: Pipe Notch
Nice truck i just got my truck back from dan. He cut the frame down and the bed. He does killer work.
Shlong Bed Club
Re: Pipe Notch
Looks great. i assume you're running drop spindles in the front too? thats the hieght i was looking for in the rear, thanks for the pics.
Re: Pipe Notch
Heres my pipe notch welded in
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
#11 | |
Re: Pipe Notch
Your right dropped spindles and dropped lower control arms. I may take one of the two out and see how it sits. I think it is too much drop. The bags have to get 90% full to lift. Cross member lays out long before bags do.
Re: Pipe Notch
I did a search, but does anyone have a link for a good 'how to" on the pipe notch?
Re: Pipe Notch
I've always just unbolted the rear hangers or coils and let the truck down on the axle to get my mark. Easiest way for me to figure out where to cut. Then just measure how much farther you have to go to reach the lowest point, laid out or wherever and cut ur piece of pipe to give you that much notch. Trace it on the frame, cut it out and weld it. It goes pretty quick that way. Has for me anyway.
#14 | |
Re: Pipe Notch
#15 |
Resistance is Futile
Re: Pipe Notch
lakeroadster; with out going into a complete engineering seminar, how do you make that calculation? Just curious.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
#16 |
Shlong Bed Club
Re: Pipe Notch
Keep the pics commin' guys! i've decided that a pipe notch is all i need for what i want. i got the pipe Wednesday and will probably start in on it this tuesday night. i'll try to take some pics to show progress. from the pics it looks as though i'll get plenty of drop with a pipe notch. thanks again guys.
#17 | |
Re: Pipe Notch
Also.... What if a pipe notch similar to what is pictured above is boxed on the inside? What effect would that have to restore that strength?
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 03-26-2010 at 09:27 PM. |
#18 |
Re: Pipe Notch
My notch I used .25 wall tubing and then used 1/4"x2" plate and welded on top of the notch to top of frame. Nothing fancy but it works.
#19 |
Jonny
Re: Pipe Notch
Without detailed engineering experiments and only sense to work with. I would say that by notching half the height of the frame, using the same grade/thickness steel, and boxing the back side, to include going a distance equal to the height of the frame forward and aft of the notch, ther would be little to no degredation of the integrity of the frame. And lets face it, if you're notching your frame, you're not planning on heavy duty work.
Oh, and the gas tank behind the axle? Really? Even a topped off 40 gal tank only weights about 300lb!
1966 C30, Cummins, stacks, and a flat bed in progress... "Honor.....simply put, A veteran - whether active duty, retired, national guard or reserve is someone who, at one time in his life, wrote a blank check made payable to 'The United States of America', for an amount of 'up to and including his life.' That is Honor, and there are way too many people in this country who no longer understand it." -AEC Hundley USNR |
#20 |
Re: Pipe Notch
When my truck was in the process of having the notch welded up I stepped onto the back of the frame (all 280 lbs. of me
#21 |
Jonny
Re: Pipe Notch
So, how is it after the boxing? I'm looking at the possabilty of doing this on my truck, but would still like to be able to pul a small trailer. What types of material did you use and how long is the boxed section? do you have a pic os the inside of the frame rail?
#22 |
Re: Pipe Notch
I think a small trailer with a lite tongue weight should be fine. But remember the further you get away from the notch the more leverage you have and it may be a bad thing. The boxed sides we used are just 3 inches longer than the notch itself. Forward they could be longer but aft of the notch is another cross member. Thats why the kits are made to bolt up on the outside, to get more length.
#23 |
SSN 706
Re: Pipe Notch
Thanks for the time to figure this out John. I knew you just were'nt talking $hit.
#24 |
Re: Pipe Notch
Ok, thanks John.........that's cool!! Now my question is what is the difference from boxing to '' heavy structural steel members that are added to the existing frame rail.''?
Isnt that just the same as boxing on the outside of the frame? And, do the bolt holes reduce the section modulus of the frame?
#25 | ||
Re: Pipe Notch
I did consider the strength impact when reducing the height of my frame channel. I figured the use of the heavier walled material (.250" steel plate c-notch) w/boxing it in (using .1875" steel plate) would restore the majority of the strength. Seeing those numbers crunched, I'm going to re-evaluate/scrutinize my set-up & consider the possibility of plating the outer wall of my frame for additional assurance.
