04-01-2010, 03:05 PM | #1 |
rack and pinion
I'm wanting to get information and pics on how to do rack and pinion steering setup. Would like to go with manual to do away with the pump. How bout you guys that have done it give us some pros and cons, work involved, parts required, etc. My goal would be focused mostly on the weight savings off the front, so is it worth doing and what are the real benifts. Thanks.
79 Blazer 2wd; flip kit drop spindles and springs. |
04-01-2010, 10:38 PM | #2 |
Re: rack and pinion
I have a mustang II fatman fabrication bolt in kit. It has a manual rack. It saves a ton of weight.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
04-01-2010, 11:05 PM | #3 | |
ShortBus KingPin
Re: rack and pinion
67 shortstep prosteet. 505 BBC, FULL BILLET TH350, Owner built EVERYTHING.... (My RIDE) 2008 GMC Yukon DENALI, 425 AWHP, 5700LBS, 12.40's at 109mph. (Her RIDE) 2006 Kawasaki Brute Force, 916cc, 80 shot, 6.20's at 111 mph. (Her RIDE) |
04-01-2010, 11:27 PM | #4 |
Truck and auto performance nut
Re: rack and pinion
any change on the turning circle?
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
04-02-2010, 08:15 AM | #5 |
Re: rack and pinion
You can stick with a power rack, just buy an aluminum rack.
83 C10 Stepside (SOLD, it was a blast!) 383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt S475 and C4 DM running, fine tuning turbo= Douchebag Racing: Runs Fine all the Time |
04-02-2010, 09:13 AM | #6 |
ShortBus KingPin
Re: rack and pinion
Turning radius is better than stock.
04-02-2010, 03:25 PM | #7 |
Champagne Taste on Beer Budget
Re: rack and pinion
Anyone have a link from a vendor for one of these kits?
Would love to have this on my truck!!
Coming Soon: Project 1970 Country Truck |
04-02-2010, 04:20 PM | #8 | |
ShortBus KingPin
Re: rack and pinion
I perfer to make everything myself. Thats just me. My truck is one loooooong conversation piece. If you have the ability and the means to do it yourself. It is not that bad of a project. I bet I have less than a 1/4 the cost of one of the aftermarket kits in my steering and eveything is stainless or billet.
04-03-2010, 12:03 AM | #9 | |
Re: rack and pinion
http://www.customclassictrucks.com/t.../photo_28.html Interesting cross member here, some fatman stuff. but i sure like the idea of pipe clamps and a manual rack (1/4 cost) would like to see more. what did you use from rack to spindle couldn't tell from your pic. thanks all for the feed back. Last edited by will scratch; 04-03-2010 at 12:12 AM. Reason: went back and read upr ends and extentions whats that?? |
04-03-2010, 11:55 PM | #10 |
ShortBus KingPin
Re: rack and pinion
I used these spherical tie rod ends from UPR and their bumpsteer kit.
Brakes are from a 72 Impala SS and I crossdrilled them for shorter stopping distances.
04-04-2010, 12:47 PM | #11 |
Re: rack and pinion
Midevil1, could you show us another pic of how you mounted the rack? I'm seriously considering this as my next mod for weight reduction.
1982 Silverado - SBE, cleaned up GM heads, small cam, TH350, 850 Demon, 4.56 gears, and caltracs. Best time so far 11.8@XXXMPH |
04-04-2010, 06:17 PM | #12 |
Re: rack and pinion
I'm also very interested...
http://67-72chevytrucks.com/vboard/s...d.php?t=494388 431 big block times, changed to a 6.0 ls with turbo 1.58- 60' 7.18- 1/8th mile@95.18 11.37- 1/4 @115.81 |
04-04-2010, 10:22 PM | #13 |
ShortBus KingPin
Re: rack and pinion
Got a local member coming by to take pics for the same thing. I will get as many pics as I can to post on here.
I really need to start a build thread, HUH? Most of my build pics are stuck on my crashed laptop, otherwise I would show you guys all my homemade parts......
67 shortstep prosteet. 505 BBC, FULL BILLET TH350, Owner built EVERYTHING.... (My RIDE) 2008 GMC Yukon DENALI, 425 AWHP, 5700LBS, 12.40's at 109mph. (Her RIDE) 2006 Kawasaki Brute Force, 916cc, 80 shot, 6.20's at 111 mph. (Her RIDE) Last edited by midevil1; 04-04-2010 at 10:23 PM. |
04-06-2010, 01:04 PM | #14 | |
Re: rack and pinion
And if I had the parts list I would gladly piece it together myself!
06-30-2010, 12:40 PM | #15 | |
Re: rack and pinion
any updates on the pics of the rack and pinion setup? I am planning on doing this... rather then rebuild the OEM complete steering system.
06-30-2010, 04:17 PM | #16 | |
Re: rack and pinion
06-30-2010, 10:38 PM | #17 |
ShortBus KingPin
Re: rack and pinion
Power supply is bad. SORRY guys I forgot about this thread all together. Taking it to get all the info retrieved. Let me see what I have for pics on this laptop.....
06-30-2010, 10:51 PM | #18 |
ShortBus KingPin
Re: rack and pinion
I added lower gussets to the bottom of the u-bolts, but dont have any pics of the final product. I Used a crome-moly oil pump driveshaft out of a SBF for the side to side bracing. I will get somemore....
67 shortstep prosteet. 505 BBC, FULL BILLET TH350, Owner built EVERYTHING.... (My RIDE) 2008 GMC Yukon DENALI, 425 AWHP, 5700LBS, 12.40's at 109mph. (Her RIDE) 2006 Kawasaki Brute Force, 916cc, 80 shot, 6.20's at 111 mph. (Her RIDE) Last edited by midevil1; 06-30-2010 at 10:55 PM. |
07-01-2010, 04:56 AM | #19 |
"Where were you in '62?"
Re: rack and pinion
Mine...'62
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
07-01-2010, 11:36 AM | #20 |
Re: rack and pinion
I sooo want a Rack and pinion setup.
If I do the conversation, what parts should I look for in the junk yard or pick-n-pull yards to piece this system together? Thanks guys!
07-01-2010, 03:50 PM | #21 |
ShortBus KingPin
Re: rack and pinion
No need to go to the junkyard. You can get everything new for relatively cheap. Foxbody mustang manual or power rack can be had at any local parts house. Tierods and extensions can be bought from UPR products or ebay. Supplies to build Mounts can be bought from local stores.
07-01-2010, 06:16 PM | #22 |
Re: rack and pinion
I was wondering....would it be possible to use the original mounts on the rack by welding some like 1-1.25" heavy wall DOM tubing to the OEM crossmember...with grade8 bolts straight thru the rack mount into the tubes with a lockwasher and a nut on the inside of the crossmember. Would be as strong as the original rack mount?
and I've heard of using a t-bird rack over the Mustangs....whats the size difference?
07-01-2010, 07:28 PM | #23 | |
Re: rack and pinion
And what about Tierod ends and extensions? From what vehicle would they fit the 1967-72 Chevy Trucks? Thanks.
07-01-2010, 09:36 PM | #24 | |
ShortBus KingPin
Re: rack and pinion
T-birds are the same rack up to 1988. They were then changed to the sn-95 chassis. The rack is wider on the 89 and up T-birds. Factory didnt offer a manual rack, so aftermarket is where you would have to get one. $$$$$
07-01-2010, 09:56 PM | #25 |
Re: rack and pinion
my truck will be an occasional cruiser and I'll drive it to the track...so I'll be going with a power rack.
