Old 04-07-2010, 01:11 PM   #1
texastrendz
El Chingon
Decided to share the work so far on the chassis,
step notch for the rear.
step notch for the front.
texastrendz is offline   Reply With Quote
Old 05-06-2010, 11:12 PM   #2
texastrendz
Re: El Chingon
Porterbuilt bag plates being installed, he gives you the bolt holes for the sway bar for the alignment.
Then i used a transfer punch to align the rest once i bolted it with the sway bar holes.
Then just drill and bolt it all up.
Old 05-06-2010, 11:35 PM   #3
texastrendz
Re: El Chingon
PB dropmember that is going in.
Old 05-07-2010, 11:26 AM   #4
leddzepp
Moderator
leddzepp's Avatar
Thumbs up Re: El Chingon
Love the work....love the project name even more
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 05-07-2010, 11:44 AM   #5
SATownChevy
SATownChevy's Avatar
Re: El Chingon
good progress, where are you going to mount the rear bags?
View pics of my truck - 1968 Chevy C10 SWB - Photobucket
I'm not wasting money on my truck, I'm helping to rescue the economy one mod at a time.
SATownChevy is offline   Reply With Quote
Old 05-07-2010, 02:41 PM   #6
texastrendz
Re: El Chingon
bag mounts run along the front of t he notch, i will post more pics of the rear frame later tonight. the rear section is not completely finished.
Old 05-07-2010, 03:40 PM   #7
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Re: El Chingon
nice
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 05-07-2010, 07:09 PM   #8
ERIK D
ERIK D's Avatar
Re: El Chingon
its gonna be nice bro.
ERIK D is offline   Reply With Quote
Old 05-08-2010, 10:23 PM   #9
texastrendz
Re: El Chingon
pics of the rear section with all the bag mounts, shock mounts and panhard bar mounts.
pic of the front porterbuilt notches welded in and smoothed.
Old 07-26-2010, 08:59 PM   #10
texastrendz
Re: El Chingon
update: just got the frame and porterbuilt parts back from powdercoating. It was raining in houston so the frame already got its first wash.
Old 07-26-2010, 09:06 PM   #11
texastrendz
Re: El Chingon
If you want to get parts powdercoated in houston this is the place to go. I took them a total of 38 pieces:
Frame, rearend housing, complete front porterbuilt package, upper and lower control arms, bag plates, valve mounting brackets, u bolt and mounting plates for rear, panhard bar, trailing arms, trailing arm crossmember, air tank, and a bunch of mounting brackets and tabs. 800.00. no tax. cash.
The color option was any color as long as it was black. It is a polyester tgic powder i think he called it. I hope it was the right stuff for the application.
Old 07-26-2010, 09:08 PM   #12
texastrendz
Re: El Chingon
Few more pics:
Old 07-27-2010, 10:51 PM   #13
texastrendz
Re: El Chingon
Got the trailing arm crossmember together tonight, i used 7/16 bolts instead of 3/8. It seemed that the 7/16 bolts took up more slack in the hole then 3/8, it was not for strength.
Old 07-29-2010, 10:18 PM   #14
texastrendz
Re: El Chingon
well since you asked:
Old 07-29-2010, 10:21 PM   #15
texastrendz
Re: El Chingon
i used kp components axle kit for the bag brackets and shock brackets. the bag plates for the a arms are from porterbuilt. i stitched up the trailing arms every 8 inches or so with the welder to keep them from seperating. i wish it would stop raining here in houston so i can start throwing parts on the frame......
Old 07-29-2010, 10:28 PM   #16
tremman78
tremman78's Avatar
Re: El Chingon
no rain and 100 degrees all weekend!! get that frame done,lol
tremman78 is offline   Reply With Quote
Old 07-29-2010, 10:32 PM   #17
Slick67
Sofa King Crazy!!
Slick67's Avatar
Re: El Chingon
I hear ya, the rain is gettin old around here. Almost everyday for over 2 weeks! Your frame and other parts look great, they did a really good job on the powder coating. What part of H-Town are you in?
You found the Tater.
My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650
My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650
67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS.
1972 2wd Blazer "Porterbuilt and Sloshed"
Slick67 is offline   Reply With Quote
Old 07-29-2010, 10:42 PM   #18
texastrendz
Re: El Chingon
I am in N.W houston, 610 and 290 intersection. Yea, i am dropping the diff off at pyle bros. tommorrow to get assembled. It will go together real fast once i get the diff. back. I still need to install the a arm bushings i got from energy, i am actually scared to do this and hope i dont chip the arms installing them.
Old 07-29-2010, 10:56 PM   #19
Slick67
Sofa King Crazy!!
Slick67's Avatar
Re: El Chingon
Cool. I am out 290 @ 1960, well that's were I am building my truck, although I live in Spring by the Woodlands. As for chippin them, you can use a razor blade to cut the powdercoat at an angle and it will save you from that headache. I do powdercoating on small parts and have done that in the past for the same reason. I am subscribed to the build, can't wait to see what you have in store for us!
Old 07-29-2010, 10:59 PM   #20
texastrendz
Re: El Chingon
i used to work out of 1960 and 290, a go kart/bicycle shop called Davids Cycles. I like the area, one day i will move out of the hood.
Old 07-29-2010, 11:07 PM   #21
Slick67
Sofa King Crazy!!
Slick67's Avatar
Re: El Chingon
Hahahaha. Yeah David Cycles by Sterling Body Shop, not to far from the shop. Closest intersection to us is Cypress North Houston and Eldridge. I grew up in the Heights when it was the hood. Keep the pics rollin, I may get some good ideas!!!!
Old 07-30-2010, 08:58 PM   #22
texastrendz
Re: El Chingon
got the upper and lower control arms together, the lowers were a pita, one was a little tweaked so i had to get the porta power out and do work. show ya guys some assembly.
Old 07-30-2010, 09:08 PM   #23
texastrendz
Re: El Chingon
well one picture will not come up, it shows where i sanded the powder off of the end the bushing rides on. it is pretty straight foward on the uppers, i will not even show what i had to do to get the lowers in.
Old 07-30-2010, 09:22 PM   #24
texastrendz
Re: El Chingon
lowers:
Old 08-01-2010, 10:34 PM   #25
texastrendz
Re: El Chingon
got the bushings from summit racing, they are from energy suspensions. the are the poly. bushings. i hope they dont make noise when it is all said and done. i coated them with the grease that comes with them, price was to good to pass up over the rubber ones.
