700 r-4 converter lock up
I just picked up a 700r4 out of a 1986 Chevy caprice classic that was behind a 305,I want to put it in my 64 step behind my built 350,I have the complete car,so will have other parts.My question is,do I have to rewire trans with a hot wire for the converter lockup,or should I just run it?Tx Firefighter posted a quick rewire does this work for you?Thanks
#2 | |
Re: 700 r-4 converter lock up
1965 c-10 swb 1997 c-1500 extended cab 2004 tahoe 1993 mustang gt BUILD THREAD:http://67-72chevytrucks.com/vboard/s...d.php?t=336653 |
How about a shifter other than a lokar? any ideas?
My suggestion would be a B&M Megashifter, Quicksilver, or Prostick possibly a ProRatchet. I Megashifter (ratchet) in a S10 Blazer with a small block and 700r4 that is built (rev manual valve body, gears, vette servo, 3500 stall converter). I like the ratchet shifter in it. But it is being redone and are switching to a ProRatchet. Just my two pennies.
When I was still driving mine it had a Prostick. I had to swap out the plate to go from a three speed auto to a foer speed auto.
1965 c-10 swb 1997 c-1500 extended cab 2004 tahoe 1993 mustang gt BUILD THREAD:http://67-72chevytrucks.com/vboard/s...d.php?t=336653 Last edited by greg65; 04-23-2010 at 09:47 AM. |
I have a B&M ratchet /gate shifter,for 3 speed auto,can I alter or change anything to make it work for a 4 speed auto,anyone ever done this?
I should have said B&M star shifter
![]() Join Date: Sep 2006
You need to be able to lock up the converter. It will create to much heat if you don't. Just wire it and use a toggle switch. I did that for years and I liked it as I could control the lock up myself.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
Senior Car Nut
![]() Join Date: Jan 2008
I'm still running the old z-gate from my previous 400, I just have no way of holding it in low gear. love the manual lock up, I think I have a TCI kit off of e-bay, didn't spend big bucks. haven't seen Tx Firefighter's diagram but wouldn't hesitate to try it.
Larry |
I used a automatic column out of a van. Gee I am so boring, but I got it at pick n pull for $28. it looks like this one except cleaner.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 Last edited by Chevy Fleetside; 04-23-2010 at 10:16 AM. |
How do you tell if the lockup is working properly? On mine at low speeds I feel a clunk that feels like a downshift on a manual transmission (it's a stage 2 700r4) Is that the lockup releasing?
I think the star shifter is 3 speed only: http://www.fastpts.com/cgi-bin/hazel...mshifters.html
On my Mega Shifter I had to remove a couple of pins & swap out the plate that shows you what gear your in. |
#15 |
With the Painless kit the lock up work fine on the highway. My 406 has a big cam so around town when the converter locks up the trucks starts to buck and jerk. This is at speeds under 55. To solve this I installed a toggle switch to lock the converter up when I choose to.
#16 |
Is there anyway to use the original Automatic Steering column thats set up for a three speed automatic when installing a overdrive tranny like a 200R4?
JRBECK64 Last edited by JRBECK64; 04-23-2010 at 10:49 AM. |
#17 |
So you need to lock up tranny in overdrive only?Or is it the whole time through all gears.I f I use my z-gate ,I won't have L1?Here is diagram from TX FIREFIGHTER.
#18 |
Yes you can. I am using a 3 speed auto column from a van. It would be a 70's van column.
#19 |
These columns come from 70's vans. I think all the way up to 1979 or 80 are the same. I welded two nuts to the bottom of the column so I could bolt it to the coliumn/hand brake bracket. I also used the lower column from a 73 and up truck.
#20 |
[QUOTE=Chevy Fleetside;3936495]Yes you can. I am using a 3 speed auto column from a van. It would be a 70's van column.[/QUOTE
Chevy Fleetside, I guess that the drive position would actually be the overdive position and you just wouldn't be able to manually shift the tranny into L1, would that be right? JRBECK64 |
#21 | |
#22 |
I guess I could make the steering column from the caprice work,just some fab work,and linkage,and would leave more leg room.Also run wiring with switch right on shifter arm.
#23 |
B & M makes a great pull and play lockup controller that's allows you to manually adjust the lockup. I put one in when I installed my 700R4 I think at the time it cost about $150 but it was worth it.
You can use your 3 speed colume (automatic) you just need to get your self a 4 speed indicator to mount on your colume in place of the 3 speed. I used the original powerglide colume and shift linkage all the way up though my 200R4. |
#24 |
![]() Join Date: Apr 2009
I used a kit from Jegs that uses vacuum to control the lock up. Heres the link: http://www.jegs.com/i/TCI/890/376600...oductId=748599
"All Alone Meet & Greet 2010." http://67-72chevytrucks.com/vboard/s...d.php?t=393754 |
#25 | |
