Old 04-29-2010, 01:37 AM   #1
thepenguin99
Big Block in square body, what headers on lowered truck?
I am in the process of installing a mild 454 into my 86 Silverado. I also want to lower it ~4" in front with a flip in back at some point. After a little searching I have found that the summit brand (flowtech I think) full length headers I was planning on using will hang below the frame rails. Are there any 3/4 length bb headers that work in our trucks?
thepenguin99 is offline   Reply With Quote
Old 04-29-2010, 06:05 AM   #2
S10Fan
Old Heap Driver
Re: Big Block in square body, what headers on lowered truck?
Subscribed...
There are "shorty" headers that will work but I refuse to pay triple the price for half the header.
I looked at some Camaro headers side by side on the floor with truck headers. I'm not convinced the Camaro headers will work without serious mods.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 04-29-2010, 08:38 AM   #3
bigblock73
yeller
bigblock73's Avatar
Sanderson BB8's will work perfect. They are 3/4 length headers for 73-87 BB trucks. I have them on mine, and like them a lot.
bigblock73 is offline   Reply With Quote
Old 04-29-2010, 08:42 AM   #4
cochino12
It followed me home?
cochino12's Avatar
I ordered hooker 3/4 length for a late 70-mid 80's bbc camaro and they worked great.
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 04-29-2010, 01:41 PM   #5
JCampbell
Thorley's work good, too.
JCampbell is offline   Reply With Quote
Old 04-29-2010, 05:15 PM   #6
thepenguin99
Do you happen to know the model number of the headers you used? I was looking at camaro BB headers on summit and found some hedman shorties (68610) that people say work but didn't see any 3/4 length hookers.
Old 04-25-2012, 08:33 PM   #7
tirefrier
new to the site and was wondering if there was any clearance issues with hedman shorty headers on an 86 c10 with a 454 in it? Is there any other mods that need to be done?
tirefrier is offline   Reply With Quote
Old 04-25-2012, 09:55 PM   #8
ozark
I used chevelle headers on mine. They fit nice and dont hang much lower than the frame rails.
ozark is offline   Reply With Quote
Old 04-25-2012, 10:11 PM   #9
tirefrier
so was there any interference with motor mounts or the lower control arm or the frame?
Old 04-25-2012, 10:31 PM   #10
tirefrier
were there any clearance issues or mods
Old 04-25-2012, 10:48 PM   #11
ozark
I had to cut a small amount off of the upper rear corner of the clam shell motor mount on the drivers side, and relocate the emergency brake cable bracket on the bottom of the frame rail. They were easy mods and didn't take much to do. No a arm or any other clearance problems.
Old 04-25-2012, 10:52 PM   #12
ozark
Forgot to add, if it wasn't for them having 3 1/2 inch collectors I wouldn't have had to relocate the emergency brake cable bracket. with a 3 inch collector I don't think you will have to.
Old 04-25-2012, 11:08 PM   #13
tirefrier
what brand of header did u use?
Old 04-25-2012, 11:12 PM   #14
ozark
not 100% sure I think they are headman. 2 1/8 primaries with 3 1/2 collectors. I know they aren't hookers. I bought them used, the person I bought them from said he had them on a 70 chevelle. My truck has 2 inch drop spindles with 1 coil cut.
Old 04-25-2012, 11:54 PM   #15
tirefrier
i would like to use hedman headers
Old 04-25-2012, 11:58 PM   #16
tirefrier
i will be about the same drop how much clearance does your exhaust have from the ground and is it tucked into the frame
Old 04-26-2012, 12:16 AM   #17
SCOTI
SCOTI's Avatar
I have 'used' Chevelle headers from an unknown manufacturer on my dually w/a bbc. Full length, 1.75" primary, & 3" collectors. They are about 1.5" above the bottom of the frame rail (which is slightly taller on a dually but they would still work just fine on a 1/2 ton). I had to clearance the motor mount shell to ensure .250" clearance from everything & trimmed the lip of the frame rail where it drops under the cab (again, just to ensure a full .250" clearance everywhere). I tried them because I used Chevelle headers on my 67 & they cleared well. Much cheaper vs 'custom' headers....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-26-2012, 06:48 PM   #18
shadhudson
i have an '86 with 3" drop coils and 4" kit in the rear. i went all out and got the Hooker SuperComps on my truck. they fit very nice. make sure you get the 1 7/8". the 2" primaries hit the control arms and hung way too low. the first setup had some old headers off a 1968 camaro that fit decent, but the new engine needed more bling!
shadhudson is offline   Reply With Quote
Old 04-26-2012, 10:08 PM   #19
69GMC910
MOTORHEAD!
69GMC910's Avatar
Someone on here recommended chevelle headers to me... I think the hooker part number is HKR-2455. I bought them as they are suppose to tuck in up high and fit great.. I havent got them installed yet, but the person said they fit excellent. 2" primary, 3 1/2 collector.
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Performer RPM Air Gap
Hooker 2455's
TCI Turbo 400 Super Street Fighter
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Hoosier 30x10.5 Radial Slick
Full weight long box pickup
Current best- 11.33@117mph
69GMC910 is offline   Reply With Quote
Old 04-26-2012, 10:43 PM   #20
tirefrier
so are those a full length header? that would be sweet if they are because putting on exhaust would b easy
Old 04-26-2012, 10:54 PM   #21
69GMC910
MOTORHEAD!
69GMC910's Avatar
Ya they r full length. I got the stainless ones. They were $650 or something. They look awesome!
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Hooker 2455's
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Old 04-26-2012, 11:26 PM   #22
tirefrier
$650 is a little steep for me do you have any pictures of them
Old 04-26-2012, 11:33 PM   #23
Liddy71
Liddy71's Avatar
I bought the hookers for 2455 they fit good my is drop 5"
Liddy71 is offline   Reply With Quote
Old 04-27-2012, 01:15 AM   #24
INSIDIOUS '86
INSIDIOUS '86's Avatar
A 4 inch drop up front shouldn't cause any clearance issues. I have a 4 inch drop on mine right now and it does fine with full lengths. Tall speed bumps are the only issue and with some planning are no issue.
Most muscle cars I've been in had some road rubbing love
One would think that header manufacturers would bring us more choices on headers for these trucks instead of just a handfull
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 04-27-2012, 01:36 AM   #25
tirefrier
I allready have headers on it. I have a 3 inch drop spindles with some lo pro tires. I plan on putting bigger tires back on but will put drop it even more by cutting the coils. im also running a 454 so I just want to make sure I keep my exhaust as high up into the frame as possable. I drive it kinda hard and I dont want to worry about dragging my exhaust off
