05-01-2010, 03:42 PM | #1 |
8848stro
Driveshaft
Hi Guys-new to forum,would like to know if a one piece driveshaft will work on my long bed 71.
05-01-2010, 04:50 PM | #2 |
Re: Driveshaft
short story NO
welcome to the board
71c-10 350/2004r/4:11 lowered3/4 longbed/dead by hurricane MEANING OF DEATH::::: SOMEBODY ELSE GETS YOUR STUFF DONT BELIEVE EVERYTHING YOU THINK TAKE MY ADVISE;I DON'T USE IT ANYWAY Last edited by cdowns; 05-01-2010 at 04:51 PM. |
05-01-2010, 05:02 PM | #3 |
Moderator
Re: Driveshaft
Welcome to the board!
Your first question has been answered...
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
05-01-2010, 05:52 PM | #4 |
Re: Driveshaft
Sure it will, if you modify your crosser and order a custom shaft.
I'm putting in a single piece shaft. Custom made through Summit, 4 inch aluminum. |
05-01-2010, 05:54 PM | #5 |
its all about the +6 inches
Re: Driveshaft
there is no real good reason to do this. The 2 piece is stronger than your average one piece, and it is WAY cheaper to build your 2 piece with top of the line parts, then it would be to properly do a one piece.
05-01-2010, 06:03 PM | #6 |
Six in a row makes it go...
Re: Driveshaft
What mods do you have to do to the crosser?
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
05-01-2010, 06:08 PM | #7 |
Re: Driveshaft
Make the hoop that the driveshaft passes through bigger, the driveshaft will hit the bottom of the hoop otherwise.
you could probably do fine with a 2 piece shaft, however I installed a new engine and tranny etc. and required a new shaft anyways so I went with a single. This shaft is rated @ over 500 RWHP |
05-01-2010, 06:33 PM | #8 |
Re: Driveshaft
You guys were scaring me. The PO installed a one piece (not that he took short cuts or did stuff 1/2 @$%ED). My friend has a one piece on his '72 C20. I just got mine tuned up. What are the advantages/disadvantages. I've got others projects in front of it; so I have lot's of time to read the pros and cons.
05-01-2010, 06:45 PM | #9 |
resident oilfield trash
Re: Driveshaft
Seems like there would be a lot of opertunity for lost power on a two piece. I could be wrong but that's just the way it seems
1967 SWB C10 396/400 factory air factory tach (sadly had to send to a new home) 1986 Honda 70 Fourtrax 1991 Chevrolet K5 blazer 2wd 1982 Mastercraft Pro Star 190 Stars and Stripes 2002 Chevrolet Tahoe 2011 Nissan Armada |
05-01-2010, 07:51 PM | #10 |
Re: Driveshaft
where will it go?
The resistance in a single added U joint and carrier bearing is so minimal its moot. If your engine is so lame that the added resistance reduces the rear wheel power levels, then you have some seriouse other issues. |
05-01-2010, 08:04 PM | #11 |
Re: Driveshaft
COULDN'T HAVE SAID IT BETTER. JOHN
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
05-01-2010, 09:05 PM | #12 |
Re: Driveshaft
This is an article that might square things up for everyone, it's about cars but the same applies to trucks.
like I said I used a single shaft but I changed engine and tranny, and the the stock shaft was to long and had the wrong style yoke, also for this aplication the single shaft will give the right feel for hard launches. http://www.rodandcustommagazine.com/...ech/index.html |
05-01-2010, 09:28 PM | #13 |
Re: Driveshaft
The biggest problem will be you will stress the out put bearing to look like a egg on the tail of your transmission with a one pc shaft in about 100 miles!
Two pc design is much better.
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps. 68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread Last edited by Mt Man Chad; 05-01-2010 at 09:28 PM. |
05-01-2010, 09:51 PM | #14 |
Re: Driveshaft
Won't have an issue if both yokes are the same angle, issues arise when the tranny yoke and pinion yoke aren't the same angle, they should be parallel.
05-01-2010, 10:04 PM | #15 |
Re: Driveshaft
Sounds like more work than it's worth.
The weight of the one pc shaft is the issue, not the alignment if using a steel shaft. How much did that Aluminum shaft cost? What are you gaining by doing this? A 2 pc shaft takes care of all of that.
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps. 68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread Last edited by Mt Man Chad; 05-01-2010 at 10:17 PM. |
05-01-2010, 10:34 PM | #16 |
Re: Driveshaft
I may be wrong but didn't some of these trucks lwb come with a 1 piece shaft?
05-01-2010, 10:46 PM | #17 |
Re: Driveshaft
lol No my engine can hold it's own. My point was all things being equal why would you give up any power or add more moving parts to fail.
05-01-2010, 10:56 PM | #18 |
Re: Driveshaft
no LWB trucks 67 - 72 had a one piece shaft.
The shorter shats are less prone to twisting. shorter shafts are less prone to twisting the added joint adds a point to flex, a spot where you can take the shaft from one angle, and add another angle in it. Straight out from the trans (not perfectly straight, but fairly straight) and then to the cross member, where it can drop from that U joint. With this set up, the crossmember on the frame, where the C bearing is mounted, can do its job adding rigidity to the frame. If the hole is large, it isn't as strong. In order to cycle the rear suspention from full drop to full compression, (as a working truck) the hole would be too big to add strength. However, small hole in the crossmember, stronger frame, U joint right after that, full range of motion on the rear suspention. |
05-02-2010, 10:33 AM | #19 | |
Re: Driveshaft
I'm gaining a shaft that will handle 500 + RWHP which I require, I'm loosing some weight off the rotating assembly and I was able to upgrade to stronger yokes, and U-joints. there is a method to the madness. Might not be the right choice for you but it is for me. And in responce to the original post, Yes you can use a one piece shaft. |
05-02-2010, 01:41 PM | #20 |
Re: Driveshaft
Amen!
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps. 68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread |
05-02-2010, 11:22 PM | #21 |
Re: Driveshaft
I'm with Longhorn on this one. I'm keeping my two peice.
But Hey...What's the take on the "Carrier Bearing" wear, lube an longevity??? Before Pop passed, He advised CB replacement yearly. Ouch!
"Do not follow where the path may lead. Go instead where there is no path and leave a trail." "SEMPER FI" Never retired-Always a Marine '72 C10 Longhorn-very daily '86 C10 Van (mothballed) previous; '65 C10 shorty & bunches of M/C's |
05-03-2010, 11:10 AM | #22 |
8848stro
Re: Driveshaft
Thanks for the info guys-i will keep the two piece!Looking to buy parts truck-tmr!1970 C-10 396.Starter,rad,bat,were stolen-were the bolt patterns stager or in-line.Would like to start it if i could.
05-03-2010, 12:38 PM | #23 |
Re: Driveshaft
you seem to have forgotten to post how much it cost
05-03-2010, 12:47 PM | #24 |
Re: Driveshaft
I thought I saw $395 ,in post#19.... nice lookin shaft too
http://community.webshots.com/user/hotrodhorn |
05-03-2010, 03:27 PM | #25 |
Re: Driveshaft
My carrier bearing just failed after a few thousand miles. Ripped the metal right by the mount due to driveline angles and Ujoint deflection because the truck is lowered. I'll be looking at relocating that carrier bearing.
