Cruzin
Re: What did you do to your truck today!
no, there is a small bracket that bolts to the frame in the hole in the top of each end of the frame.
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
Did some more interior work. Put on the new dash bezel with the painted gauge cluster. Installed the knobs that I cleared the other day. Installed an electric pump in my winshield washer jar, ran new wires to it and plugged it into my OEM wiper switch. Shorted out my light switch cause now the tail and dash lights stay on whenever I turn the key on. I guess I will pick up a new one tomorrow and put it in. Hopefully it will fix that problem. Here are some dash pics.
[IMG] ![]() [IMG] ![]() [IMG] ![]() [IMG] ![]() [IMG] ![]()
67 C10 Stepside 66 Mustang Coupe 99 Burb 2500 |
Fixed the temp gauge. Was easy just replaced the temp sending unit.
1970 SWB "old flame" 1967 SWB c10 sold 1972 Elcamino 496 2012 Denali HD dmax |
Collector of Projects
old lights....
![]() new lights... ![]() dont mind the crooked bumber... i swear it was like that when I got it.... |
![]() Join Date: Mar 2011
Pulled out just about every inch of spaghetti and started mapping out my new Painless 18 ct. kit. So, this will be my "what i did to my truck today" for about the next month. Also I started tearing down the air system for new bags, valves, and steel braided lines while i have the bed off
I set the pinion angel on my 9" rearend. Removed the rearend and trailing arms. Cleaned the trailing arms. Finish welded the perches on the rearend. Welded the trailing arms together, top and bottom. Painted the rearend and trailing arms. Replaced the trailing arm bushings with urethane and put it all back together.
Got my new used grille installed.
1972 K1500 Longbed 350 w/3 on tree. 1976 Chevy Nova 350 auto 1972 C10 (donor) |
Old Skool Club
![]() Join Date: Jun 2001
Painted the frame rails, trailing arms and engine crossmember. Tomorrow, we'll flip the frame over and get what we missed.
My son is a hammer...drives me like a nail! We've done more in the past 2 months, than had been done in 2 years.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
Big Red - Now its a SWB!
Did some work on the leaf to coil swap that I started a few days ago. Got some rivets out then removed the exhaust. Then bolted up all the coil stuff to see how it fits, now I get to dissasemble it and sand and paint it and put it back together. Also have to hit the junk yard and get some misc. parts that I need to complete the swap.
68 3/4 ton ![]() ![]() 41 3/4 ton ![]() 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
S.D.M.F.
Got my 85 goin and its badass
1969 Chevy Longhorn 396/400 3/4 ton. ![]() 1991 Chevy Camaro RS 305/700r4 ![]() 1978 Honda XL175 and XL350(the evil twin) ![]() 2006 Kawasaki ZX-14r drag bike-best e.t. 9.4@145 mph without nitrous 1971 BSA Thunderbolt 650cc ![]() |
@60ratrod i might have a good grille pm me
yes, i do
will do rondog. i got a hold of livrat and he has one that i am going to look at on friday on my way back from bremerton. if it doesn't pan out then i'll come check it out monday if you don't mind. thanks man!
ERROR 404....... SNAPPY COMEBACK NOT FOUND ![]() _______________________________________________________________________________________________ -60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination" -07 gmt900 silverado 1500 lt xcab z71, granite blue -81 suzuki gs650g "shelah"- current project -81 kz1000m1 csr "sarge" -next project (just beautification) -07 kawasaki vulcan classic vn900 |
(My sons truck) Almost finished up the 12" notch, got the truck off of jack-stands and onto air shocks
![]() Last edited by PLANETGETLOW; 03-22-2011 at 09:25 AM. |
#15 |
yes, i do
made a sketch of my 72 with a 67 front end so i can play with paint schemes
ERROR 404....... SNAPPY COMEBACK NOT FOUND ![]() _______________________________________________________________________________________________ -60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination" -07 gmt900 silverado 1500 lt xcab z71, granite blue -81 suzuki gs650g "shelah"- current project -81 kz1000m1 csr "sarge" -next project (just beautification) -07 kawasaki vulcan classic vn900 Last edited by 60ratrod; 03-22-2011 at 09:40 PM. |
#16 |
yes, i do
lets try this this time
#17 |
Not a whole lot but i did start cutting some stainless interior trim pieces on one of the lasers at work. And I put my new Powermaster XS starter in. Man this thing cranks!
#18 |
Adjusted the glovebox door striker so I can pop it open with one push of the button. Now I don't have to fight with it to get to my stereo.
#19 |
Old Skool Club
Flipped the frame over and painted the bottom of everything we couldn't get to on Sunday afternoon. Learned something, too. If I EVER (!) do this again, I'm not going to brush-paint the chassis, regardless of what kind of paint I use. Rattle-cans or bonafide spray gun....that's the ticket.
Once the parts are sand-blasted....the work begins. Looking forward to the chassis reassembly. I want this thing back on 4 wheels. 4 years is too long to go without my truck. I need a fix.....man.
#20 |
I finally changed all of the fluids and filters in the "new" '68......I think the oil filter had been on there awhile 'cause it REALLY didn't want to come off.
This is what happens when a stubborn oil filter meets a determined new owner.........and a Vice Grip chain wrench. (nothing else got it to even consider turning.) |
#21 |
![]() Join Date: Sep 2010
Location: Formerly MD and San Diego, now loving life in Arizona
Dropped my 396BB at my local machine/pro shop for evaluation and a complete overhaul. Bought the truck with the engine removed and disassembled. Now I am having the pleasure of having the engine build to my specs.
SO far we are looking at a complete rebuild of the '71 402 heads with new valve guides, valves and seats. The crank will have to go to -.020 and the cylinders will have to go to -.060. The engine and rods will be line bored and balanced. I am also looking to go with a Lunati Voodoo series 60202 mild cam. Not decided wether or not to go with the PO Holley intake and Holley DP (size unknown). I might just go to the Edlebrock mainfold/carb setup for ease of maintanability. AL '69 GMC 2500 Custom Camper '69 Chevy C10 396 That is all so far. |
#22 |
Broke my motor...actually I guess that was last Friday.
'68 Dodge Dart 270, 225, 904, 2.76--"Lucy" 1996 Gmc 1500 Z71, 350, 4l60e, 3.73s 1995 Jeep Wrangler Rio Grande 2.5, AX5, 4.10s 1989 Toyota Pickup 22re, auto, 3.73 |
#23 |
Worked on the wheeltubs for the rear (actually this was Sunday, but I havent been able to get on here fince then). Got them trimmed to fit real nice to the factory bedsides and floor, and got them tacked in. Just have to finish welding them in, and decide if I am going to leave the rest of the floor open or make a notch cover for it.
This one of the probably 50 times we put them in to check the fit. The factory bedsides have several complex angles in them, so it took a long time to get them just right. They are almost there in this pic, but not quite. ![]() And this is finally tacked in, adn done for the evening. ![]() |
#24 |
I did a brake flush. Found a plate in a garage and the rest was easy.
#25 |
I pulled my front clip off, relocated the proportioning valve, and started pondering how to keep my steering shaft off of my upper arm when I'm aired out. Still a little stumped. Colin Havens--those tubs look great.
