Old 05-11-2010, 02:14 PM   #1
81ratrodc10
house of chevy's
81ratrodc10's Avatar
carb spacers
i was wondering how much differance do carb spacers make is it a noticable incres or not really was thinking about putting one on my truck but didnt know
81ratrodc10 is offline   Reply With Quote
Old 05-11-2010, 04:24 PM   #2
xrcr
Re: carb spacers
They can. But bolting one on and walking away is not how you do it. What intake you are running/ engine combo needs to be considered. Go to Automedia.com they explain it generally pretty well.
xrcr
xrcr is offline   Reply With Quote
Old 05-11-2010, 04:37 PM   #3
81ratrodc10
house of chevy's
Re: carb spacers
the engine is a 305 i was told it is a intake off a 350 not sure were to look to figure it out i know its a aftermarket intake not a stock one with a 4b carb not sure the make of that either should go look
Old 05-11-2010, 04:44 PM   #4
81ratrodc10
house of chevy's
Re: carb spacers
just went out side the intake says performer rpm and its a holley carb if that helps
Old 05-11-2010, 04:52 PM   #5
bitchin85
bitchin85's Avatar
Re: carb spacers
carb spacers might give you a few horses but they mainly just move your power curve higher or lower in the rpm range.. if u use a four hole spacer, it would give you better low end torque, which is what i have and what is what you want in a full sized truck.. an open spacer will give you more plentum volume and better high rpm horsepower.. all u need is longer studs and new gaskets.. id get a 1 or 2 inch 4 hole and slap it on. youl feel a diferance.. i did
"I'll keep my guns, money, and freedom. You can keep the "change"
bitchin85 is offline   Reply With Quote
Old 05-11-2010, 04:52 PM   #6
3r!c84
Badass
3r!c84's Avatar
Re: carb spacers
the preformer rpm is already a taller intake so i think think a spacer will help any
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 05-11-2010, 04:58 PM   #7
81ratrodc10
house of chevy's
Re: carb spacers
is this a good intake i dont know much about intakes new to the engine build aspect
Old 05-11-2010, 05:04 PM   #8
3r!c84
Badass
3r!c84's Avatar
Re: carb spacers
the RPM means for higher rpm range..1,500-6,500 the 305 is just not a high rev'er you need just a regular performer intake idle to 5,500 rpm
-00 Saturn 5spd
1/4:13:90
Old 05-11-2010, 05:08 PM   #9
81ratrodc10
house of chevy's
Re: carb spacers
it came on the truck when i bought it dont know much about it if it camed or anything i know it moves burns the hell outa the tires lol
Old 05-11-2010, 05:12 PM   #10
3r!c84
Badass
3r!c84's Avatar
Re: carb spacers
lol i know my stock 305 burns it pretty good
-00 Saturn 5spd
1/4:13:90
Old 05-11-2010, 05:15 PM   #11
81ratrodc10
house of chevy's
Re: carb spacers
so all in all i really dont need really a carb spacer i guess i need a 350 lol
Old 05-11-2010, 05:20 PM   #12
81ratrodc10
house of chevy's
Re: carb spacers
one other question how do i find out what cfm my holley 4 barrel is
Old 05-11-2010, 05:22 PM   #13
3r!c84
Badass
3r!c84's Avatar
Re: carb spacers
my dad says that..stop putting money into that 305.just get some balls with a 350
on the cfm.you can look at the numbers on the side of the carb and google it..its probly like a 500. somthing small for that 305
-00 Saturn 5spd
1/4:13:90
Old 05-11-2010, 05:24 PM   #14
81ratrodc10
house of chevy's
Re: carb spacers
i was told it is to big of a carb for the motor like to flood some times
Old 05-11-2010, 05:25 PM   #15
81ratrodc10
house of chevy's
Re: carb spacers
was also thinking of putting in a 454 but it all comes down to the money so i guess for now gotta stick with what i got
Old 05-11-2010, 05:25 PM   #16
3r!c84
Badass
3r!c84's Avatar
Re: carb spacers
oh then it might be bigger..my friend has a 650cfm on his 350 and its still too big of a carb
-00 Saturn 5spd
1/4:13:90
Old 05-11-2010, 05:26 PM   #17
81ratrodc10
house of chevy's
Re: carb spacers
what side would the # be on
Old 05-11-2010, 05:27 PM   #18
3r!c84
Badass
3r!c84's Avatar
Re: carb spacers
no idea
-00 Saturn 5spd
1/4:13:90
Old 05-11-2010, 05:29 PM   #19
81ratrodc10
house of chevy's
Re: carb spacers
thanx maybe ill go out and try to look now
Old 05-11-2010, 05:38 PM   #20
81ratrodc10
house of chevy's
Re: carb spacers
just went and looked found # under air cleaner assembly looked it up its a 600cfm thanx for the help
Old 05-11-2010, 05:40 PM   #21
3r!c84
Badass
3r!c84's Avatar
Re: carb spacers
thats a little big..but yourwelcome
-00 Saturn 5spd
1/4:13:90
Old 05-11-2010, 05:44 PM   #22
81ratrodc10
house of chevy's
Re: carb spacers
thats what the guy i bought it from said but i dont know to much about that sorta thing
Old 05-11-2010, 07:46 PM   #23
bitchin85
bitchin85's Avatar
Re: carb spacers
if you put a 4 hole spacer it will help ur low end torque and youll feel it. i have a 305 headed 350 with a performer eps intake which is about the same motor ugot and i noticed a differance for sure
Old 05-11-2010, 07:54 PM   #24
81ratrodc10
house of chevy's
Re: carb spacers
you think it will still help with my setup
Old 05-11-2010, 07:58 PM   #25
bitchin85
bitchin85's Avatar
Re: carb spacers
ya. get a two inch 4 hole spacer.. on all my vehicles, and friends they never hurt..
