07-20-2010, 07:53 PM | #1 |
Re: 65 shorty build
that sounds like a thing to look for at the junk yard
1965 c/10 swb 1969 c/10 lwb |
08-01-2010, 09:51 PM | #2 |
Re: 65 shorty build
Hey man great build i've only just stumbled upon it but I'm liking what your doing. It's nice to see some more trucks over here on the eastern side of things. I'm down here In Pendleton. Got any plans for those springs?
ian |
08-02-2010, 01:31 AM | #3 |
Re: 65 shorty build
lytemup454, thanks! and yes its nice to see guys on here some what locally! i plan to get rid of the front springs, they are 60-87, 2'' lowering djm springs.
this idea that i have in the back of my mind keeps me up... so here it goes: i want to paint the firewall, do i take the cab off, sand blast the firewall and bottom of floor pan, then spray it with por15.... clean and paint the frame take the 3 speed crossmember out and bolt in the 700r4 member or..... get the paint off of the firewall some how and spray it and leave the cab on. i just dont want the nice condition windsheild to get shot with sand as well as sand in the new baer brakes.... im willing to do both and you guys have done this statue of a project more than i have so what would you guys do?
08-04-2010, 12:33 AM | #4 |
60-66 Nut
Re: 65 shorty build
It sounds like you're at that point where things can really snowball on you. It's the question of 'Where do I stop'. You can take the cab off and do a better job of stripping the firewall and floor, but then you may as well blast the frame under the cab......then maybe pull the bed and do under there too. So you see You just have to ask yourself, how nice you want the truck, how much time do you realisticly have to do this build, and how big is your budget.
You can sand blast the firewall and floor without damaging the windshield as long as you mask it off and protect it well. I'm a big fan of blasting things down to bare metal so you can see just what is rusted, or full of mud and what isn't. That way when it is done, you know exactly what's underneath the paint, and that is isn't going to come back and bite you in the a$$.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 08-04-2010 at 12:33 AM. |
08-05-2010, 09:21 AM | #5 |
Re: 65 shorty build
aww good point captain fab... that gives me something to think about!
08-05-2010, 11:15 PM | #6 |
Re: 65 shorty build
ok so i got the brakes on the front last night and i did not get any brake lines from the guy i bought it from so i'll have to call him. also it doesnt look like its lowered 2'' but i think it will look its part when there is more weight on the front
08-08-2010, 08:50 PM | #7 |
Re: 65 shorty build
well during my 2 day stay in reno at hot august nights we bought a 700r4 trans and a b&m ratchet shifter. which should be here by the end of the week!
08-14-2010, 08:13 PM | #8 |
Re: 65 shorty build
i finally got a chance to sandblast the rear frame and firewall.
i found this number it looks like a "66" what would this mean? has anyone heard of por15's pelucid topcoat? is it a good idea to spray it over the black on the firewall? hopefully tommorow i can take the rear end out along with the trailing arms blast and paint those too.
08-15-2010, 12:17 AM | #9 |
60-66 Nut
Re: 65 shorty build
Be very careful using that silica sand. Breathing the dust from it can cause serious lung damage and even death. Even what's on the ground afterwards can get stirred up.
I haven't heard anything about POR's Pelucid topcoat, but then again I've only used POR15 2 times.
08-15-2010, 12:21 PM | #10 |
Re: 65 shorty build
yeah silacosus (or how ever you spell it) that would be a bad way to go. yeah i wear a resperator.
08-24-2010, 01:07 AM | #11 |
Re: 65 shorty build
the internet has been down for about a week or better and i have made significant progress as well as bought a powder coating gun and oven on craigslist for $100!!! i finaly got the 700r4 trans and the pro ratchet shifter to. the painted items were sprayed/brushed on with por15.
well heres some pics of the progress and powder coating.... is this panhard bar suppused to be bent?
08-24-2010, 01:20 AM | #12 |
60-66 Nut
Re: 65 shorty build
No. it's not supposed to be bent. Someone may have done that to center the rear end if it wasn't originally. You can buy adjustable panhard bars if you so desire.
08-24-2010, 01:22 AM | #13 |
Re: 65 shorty build
why would make them do that??
ill just build a new one
08-24-2010, 03:15 PM | #14 |
Re: 65 shorty build
Raising or lowering changes the required length of the Panhard bar when centering the rear housing.
12-02-2012, 01:10 AM | #15 |
Cluster King
Re: 65 shorty build
Well, I do know one way to bend a panhard bar. When I was younger I owned a 68 with coils and the butt end of the truck would on occasion get loose and find a curb or some other object that would not move. You would think that would bend or break a rim before it would bend that bar, not always. If it were me, I would just find a good used replacement and have new bushings pressed in it.
I have not found any quick way to remove undercoating other than chemical dipping. I have tried the heat method and all it seams to do is make a gummy mess. I have had the best luck using a good stiff putty knife at room temp. If it is really old undercoat, it usually chips away fairly quick. Good Luck |
08-24-2010, 07:08 PM | #16 |
Jesse
Re: 65 shorty build
Nice progress, Hows that powder coat set-up working for you?
08-24-2010, 07:51 PM | #17 |
Re: 65 shorty build
Thanks! it works really good! it would be nice if i could get the powder to stick onto the sharp corners better. i have done a wheel and a bunch of suspension parts for my truck and a freinds datsun 240z.
so your saying buy the adjustable one?
08-24-2010, 11:59 PM | #18 |
60-66 Nut
Re: 65 shorty build
I would either buy or make an adjustable panhard bar.
08-25-2010, 12:02 AM | #19 |
Re: 65 shorty build
ill have to get the "how to" from some one.
also whats the best way to remove undercoating??
1965 c/10 swb 1969 c/10 lwb Last edited by chev-obsession; 08-25-2010 at 12:03 AM. Reason: second line |
08-25-2010, 12:16 AM | #20 |
60-66 Nut
Re: 65 shorty build
To build an adjustable panhard bar, you'll need a piece of DOM tube for the length, a piece of DOM that will work with the bushings on the fixed end, a bushed rod end on the adjustable end, and a threaded bushing that matches the threaded rod end to weld in the end of the long tube. If that isn't understandable, take a look at the ones from CPP.
Sometimes you can remove undercoating with a little heat from say a propane torch and a putty knife. Or just a putty knife or a gasket scraper may work also. Aircraft paint stripper works sometimes too.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 08-25-2010 at 12:16 AM. |
08-25-2010, 12:26 AM | #21 | |
Re: 65 shorty build
i have tried air craft stripper and it was not very practical. i was researching it and people claim to use a needle gun or a halogen work lamp on the back side of the peice.
08-30-2010, 08:35 AM | #22 | |
Re: 65 shorty build
08-29-2010, 11:08 PM | #23 |
Re: 65 shorty build
does energy suspension off rear trailing arm bushing for this truck? all im coming up with is rear control arms bushings. or are they the same thing?
http://www.summitracing.com/search/B...?Ns=Rank%7cAsc
1965 c/10 swb 1969 c/10 lwb Last edited by chev-obsession; 08-29-2010 at 11:09 PM. |
08-30-2010, 01:21 AM | #24 |
60-66 Nut
Re: 65 shorty build
I would say those should be what you're looking for. You might contact Summit and ask before ordering.
12-30-2010, 07:10 PM | #25 |
Re: 65 shorty build
It's been a while since my last post. I've got a few things done since then. I got the rear end all buttoned up and now its sitting on all 4's!!!
I just sent the rods out to get re-sized and pistons put on. I ordered the rebuild kit and it should be back with the rods next week. I also need to order some vortec headds. I feel like its just a matter of buttoning up little things. ( and putting the motor together!) Here is some pics!
1965 c/10 swb 1969 c/10 lwb Last edited by chev-obsession; 12-30-2010 at 07:17 PM. |
