06-25-2010, 02:25 PM | #1 |
Motor Pulling SOB
I've got a gusher of a leak from the rear main seal and I want to pull the motor and transmission to fix that and also for the experience. I aim to look over everything on the motor and put it back together to a long term owner standard. I am a motor pulling virgin, but I have a mechanic in the family who agreed to loan me a hoist and engine stand, but mostly I am working on my own.
My question is: 1. How much room do I need in front of the truck to comfortably pull the 350 and T400 transmission? My garage is not huge and the long bed takes up a lot of space, there is maybe 3 feet between the front bumper and my workbench now, 5 or 6 feet between the bumper and garage wall. Also, is the hoist operation a two man job? Can I remove the fender and lift out forward and to the side, and not need as much room in front? I've read some other posts about motor pulling and they were extremely helpful even though I probably need to read them again. A few notes: 1970 C-10 with motor probably a '77 chevy 350 and T400 trans I am using socket wrenches not air tools Truck has ac I only have about an hour a day to dedicate to this project Chances are good this will turn in to an engine rebuild, transmission swap, or frame off resto. On the flipside I am anxious to complete the task and get the truck running and functional again asap. Look forward to reading your responses. |
06-25-2010, 02:29 PM | #2 |
Real Projects never die
Re: Motor Pulling SOB
i drop the trans then pull the motor. I dont pull as an assembled unit. Although you could take the front clip off to make it easier, and to get more room roll it backwards out of the shop, BLOCK IT (no trans=no park gear) and then pull motor.
Ill put it this way, ive got a few lawn ornaments My name tag says Ryan KansasTwister On other forums
06-25-2010, 02:34 PM | #3 |
as WR said.. pull trans then pull motor... pull your hood off and make sure ya got enough room to lift motor up (ceiling height ?) and push truck out... block it and put engine on stand... have fun , take your time, take lots of pics if need be...
good luck its fun if you know what youre doing.... Last edited by QKENUF4U; 06-25-2010 at 02:34 PM. |
06-25-2010, 02:44 PM | #4 |
alot faster to pull as unit// unhook everything possible,rad out ,lift up and slowly push truck back a bit at a time in a small garage is how i do it
06-25-2010, 02:45 PM | #5 |
Junior Member
When we pull engines we remove the radiator first.
It will be easiest to remove the transmission from the engine before pulling the engine as others have said.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. Last edited by Shyguy; 06-25-2010 at 03:30 PM. Reason: Spelling |
06-25-2010, 02:47 PM | #6 |
Between Trucks...
Last time I pulled a motor I left the transmission in. Put a piece of wood under the pan a slipped a jack under it.
Beat it to fit, Paint it to match... |
06-25-2010, 03:22 PM | #7 |
the trouble is its alot more trouble in a small home shop twice the work twice the time to remove as seperate units// no tranny jacks no fancy driveon lifts etc// just a basic engine hoist and floor jack is what is required
06-25-2010, 04:46 PM | #8 |
From what I've read there is about 50/50 opinion on the transmission attached/separate unit argument. I am planning to pull the trans anyway, so I have 90% decided to pull it all out at once. In my head I was thinking jackstand the truck but now that I have learned to roll the truck out from under the hoisted engine I can formulate my plan of attack.
The radiator was the first thing to come out, and I have a dented grill, bumper, and fender so a lot of things are coming off this truck and going back on will be new hood hinges, battery tray, hoses, grill, fender and god knows what else. I'm tearing it all out. Taking lots of photos and taping wires with notated flags as well. Thanks for the advice. |
06-25-2010, 05:19 PM | #9 |
If you're planning to do a lot of front clip rebuild/replace, then consider pulling the front clip off as a unit. Either way pull off the hood. You disconnect the wires at the firewall (bolt in the middle of the connector), and the starter, unbolt the radiator support panel mount bolts (two in the bottom), unbolt the cowl. The you remove the two bolts at the top of the rear of the fender and one at the bottom.there is also one bolt on each side holding the inner fender to the cab (about 2/3 way back toward the inside. The whole front end will then come off as a unit.
72 Fleet (died) 78 Step (sold) 55 Step named Fred (sold) 00 F150 68 Step (named El Scorcho by PO) Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932 |
06-25-2010, 05:24 PM | #10 |
Sweet, that is good advice. I am sure I have been wasting time unbolting a lot of pointless bolts and screws, when what I want to do is get to the point and get the whole front clip off and move on to the engine.
06-25-2010, 05:47 PM | #11 |
Junior Member
Pulling an engine with the front clip off is a piece of cake so to speak.
When we put the engine in my '67 with the front clip off the engine went in so easy. I have found if the front clip is on when removing or installing an engine it usually is a lot easier with at least one helper to watch out for interferences.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
06-25-2010, 05:59 PM | #12 |
Redefining LowBudget
DO NOT DISCONNECT YOUR A/C take the compressor off and lay it some where or your looking at recharging the hole thing..the rest is piece of cake...make sure you don't forget the trans shift linkage, speedo cable, and oil sending line..the rest is plug and play...
use fel pro gaskets ..I like to clean the hole thing and paint it then replace the gaskets I love the clean look
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. Mikes Sandwich Fair Run OCT 8th 2011
06-25-2010, 06:14 PM | #13 |
Yeah, I was wondering about the AC. Compressor has been off since forever.
I am looking forward to having this thing clean. Any time I work on a new part on the underside of my truck I have to scrape off 1/2 inch or more of red clay. I cant wait to get the front end cleaned up, and have it hold fluids. |
06-25-2010, 06:21 PM | #14 |
well just to be sure the lenght of a longbed is about how much room you will need to pull the motor here at my house we usually take the radiator out the fan and disconnect the hoses the main wires to the firewall and take the hood of to disconnect the driveline from the axle and trans then drain all the oil from the tranny then start pulling the engine up and out and guide it out of the front end then after that go get a beer and enjoy what you did
06-25-2010, 06:51 PM | #15 | ||
"I ain't nobody, dork."
Pulling the motor and trans together is EZPZ... since the confined space. Either drain the oil out of the tranny or put a ziploc bag over the tailshaft with a rubber band. Or tranny fluid will come out of the tailshaft.
If you only have an hour a day to put towards getting the engine and trans out... it will make it difficult to do. Gary
06-25-2010, 07:01 PM | #16 |
For what you want pull the front clip then motor and trans together.Remove the bumper first.disconnect battery.Unhook the wiring harness from the firewall and then unhook the engine harness from the light harness.Remove brace from driver side inner fender around lower steering column.remove radiator.Remove 2 radiator support bolts.Remove wiper arms and cowl.remove 4 upper fender bolts and 2 lower fender bolts.2 bolts thru inner fenders .5/8s underneath.check for ant ground straps and any lines still hooked to ac condensor.you can then remove front clip with one person on each side.If you remove the hood you willl be able to flex it a little and if your tires are not to big it will come off.If you set on jack stands and remove the tires you do not have to remove the hood from clip and it will come off alot easier.The problem comes when tires are still on and the passenger side inner fender wants to bind in between tire and ac box.Once clip is removed the engine and trans are simple .just double check and make sure everything is unhooked before you lift.
10-26-2010, 12:39 AM | #17 |
Its a lot easier to get stuff done when it's not so hot out.
10-26-2010, 12:51 AM | #18 |
I think you can see in the second and third pics how the transmission came off the driveshaft. I was told that would be impossible to slip that back on and I would have probably need to remove the driveshaft to put it back together, is that the case really? I don't see why it would be so hard to slip that back on.
The Universal joints on this truck dont unbolt, they are pressed in real tight spicers. I would have liked to undo a Ujoint near the transmission, but I think that might have taken a bit more effort and time, hopefully I haven't done it in a way that will cause more effort to put it back on. Last edited by gontek; 10-26-2010 at 01:08 AM. |
10-26-2010, 01:05 AM | #19 |
10-26-2010, 01:07 AM | #20 |
10-26-2010, 04:03 AM | #21 |
Yea, you're going to need to pull the drive shaft, unless you have 6 buddies that can help push, pull, lift, twist, angle, and align in perfect unison.
The rear U-joint unbolts, and pops out. Wrap tape around the loose U-joint to keep the caps and needle bearing clean and in place. Then the carrier (middle of the shaft) unbolt from the cross member. Just let it lay there.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
10-26-2010, 04:06 AM | #22 |
I really hate wet sanding!
I don't understand why you would want to pull the trans to change out a rear main seal? I would remove only the motor and leave the trans in the truck, that would be the simpliest method.
Jeff, 68 C-10 75 C-20, now a C-10! 10 F-150 |
10-26-2010, 07:10 AM | #23 |
10-26-2010, 09:22 AM | #24 |
I'd pull the nose (few bolts, take note of the shims and where they cam from )
undo the light wires and take it off.. , now roll(drive) truck into garage.. unbolt engine tranny, unwire it , use'n a note pad and tape to mark what went where.. digital camera too. picutes are worth a 1000 words.. pull it out,, roll truck out into driveway, block it and sit the nose back on.. now seperate the engine tranny.. and do your work,, while you have it out, pull the converter and replace the tranny front seal and the rear seal.. then with the front seal wet(tranny fuild on it) install the converter, it'll click in as you turn it slowly, your looking for two clicks,, you'll feel them.. bolt together, drop it in and wire it up.. start it up.. better to find a leak(oil) before you reinstall the nose.. no leaks button down the nose.. |
10-26-2010, 09:46 AM | #25 |
The transmission came out easy I'm glad it did them together, now I can clean up the transmission and seal it up good too.
