06-29-2010, 04:29 PM | #1 |
LSX addict
'82 Shortbed 6.0 project
Well hey guys, i'm not new to the site but have been lurking around silently lol. Anyway, my name is kris from tyler tx. i am 20 and a student at a local junior college taking automotive tech. i bought this '82 to be a project truck, an after a year of daily driving (and 9 mpg) ive decided to go with a newer 6.0, as i am pretty familiar with the LS series engines from working on my LS6 swapped '01 SS camaro (now sold for an ECSB '01 K1500, 6" BDS lift on BFG 35's). but i am sure i will have questions and that many people would like to watch as the project moves along.
i only have a couple of pics but i will get newer ones at class tonight. i have removed both fuel tanks and an '87 tank/sending unit is on the way as well as the '99 vette inline regulator and ACdelco EP-381 fuel pump and a new EZ 21 circuit wiring harness, the old was trashed, an this will be a DD so i dont need to watch it go down in flames. i have not found the engine or transmission yet. but yeah, pics. this is the only picture i have right now, like i said ill get more tonight. but on a side note, i am also not new to these trucks, my first truck was an all original '87. here is a picture of it. an this is it after being hit by a hydroplaning semi.. a testimony to the safety of these trucks! thanks for looking guys! hopefully this project will go somewhat smooth. Last edited by kSStamp0182; 01-04-2011 at 08:26 PM. |
06-29-2010, 05:43 PM | #2 |
Re: '82 Shortbed 6.0 project
holly hell I can't belive you lived!!!!
1986 Chevy 1/2 ton 4x4 350 Auto Shortbed Fleetside |
06-29-2010, 09:14 PM | #3 |
Formerly- 1972SuperCheyenne
The 6.0 swap will be awesome. 400 horsepower and 20 MPG will be awesome! Should look like this soon!
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
06-29-2010, 10:52 PM | #4 |
LSX addict
Sweeeeeet truck man! Very nice. I'm sure ill have plenny of questions for you. I've been enjoyin the 400 rwhp an 28 mpg out the SS the past year an can't wait to have ls power in the truck.
07-16-2010, 01:40 AM | #5 |
LSX addict
a few updated pics.
07-16-2010, 01:44 AM | #6 |
LSX addict
ok, well i got a damn good deal, LQ4, all accessories including computer/harness with 4L80E shipped all for 2k! should be in next week. but im about 1/4th through the rewiring process, it was a mess. not sure how this thing never burnt to the ground. but the tank is installed and wired, all ready to go. sure hope all goes well with that cuz i DAMN sure dont wanna have to drop that tank again!
07-16-2010, 11:40 AM | #7 |
coming along good.
2014 LTZ Z71 Silverado 82 C15 LQ4/4L80E Conversion 78 Suburban build (SOLD) 83 4x4 Suburban(SOLD) 82 C15 (my first truck) |
07-16-2010, 11:47 AM | #8 |
great job, keep up the work! im about to start the same thing...all those wires make my stomach turn!
1979 c30 3+3 dually 1946 GMC |
07-16-2010, 01:02 PM | #9 |
LSX addict
actually its been surprisingly simple so far. its the EZ 21 circuit wiring harness, and every wire is marked every foot or so with its intended location. im very pleased with it. an it was only $185
07-16-2010, 01:15 PM | #10 |
Registered Cruiser
I have been wondering how nice this kit was for $185... Does that include the fuse harness with fuses as well??
07-16-2010, 02:02 PM | #11 |
LSX addict
the fuse block? yes it does an theyre all clearly labeled. i was very impressed. its filled with all the correct fuses right out the box. an the wires are sectioned into four large sections which help SO much, they are front (headlights, engine, etc) dash (gauges, switches, etc) column (hazard connectors, turn signal, etc) and tail (brake/ reverse lights, etc)
07-16-2010, 02:13 PM | #12 | |
Registered Cruiser
Ya, fuse block. I had a mental block their Sounds like a smokin deal!! Good luck, I will definitely keep an eye on your build. Thanks! |
07-16-2010, 10:37 PM | #13 |
Next project: 1970 K10
I was a firefighter/EMT for 14 years, and if I had walked up on this back then I still would have crapped myself! Amazing.
Good luck with the build, and don't forget we have a new LS swap sub-forum in the Engines section. Ask as many questions as you like!
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
07-20-2010, 03:55 PM | #14 |
LSX addict
got the motor an tranny in today! only one setback an i havent decided if this is good or bad yet. the trans is a 4x4 setup. is it possible i could get a transfer case and the shorter driveshaft, and just leave it in 2H for now, leaving the option of going 4x4 open?
07-20-2010, 05:22 PM | #15 |
I saw on your regualtor you are running rubber fuel lines secured with a hose clamp. I ran my 5.3l this way and when i primed it the first time the lines popped off and leaked fuel. I ended up running "fuel injection" hose clamps which are smooth on the inside and put two on each connection and have been leak free since!
07-20-2010, 05:53 PM | #16 | |
LSX addict
07-20-2010, 06:49 PM | #17 |
Truck and auto performance nut
that wiring looks like some real fun!
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
07-21-2010, 04:54 PM | #18 | |
LSX addict
07-21-2010, 05:23 PM | #19 |
A transmission shop can swap the mainshaft and the tailshaft housing for a 2wd version. Maybe sell the transfer case to offset the cost.
07-21-2010, 07:19 PM | #20 |
chevy runs deep
look'n nice
RAIDER NATION 1969 c10 swb soon 2 b on the road... My LWB is a SWB now http://67-72chevytrucks.com/vboard/s...d.php?t=498241 |
07-21-2010, 07:36 PM | #21 |
LSX addict
07-21-2010, 07:39 PM | #22 |
Lookin good man. I wish I had my LS1 ready for my '01 silverado, cause i'd drop the old 5.3 in my 85 fer sure.
Tyler Texas? I'm about 3 hrs South of you in Lumberton Texas...but still in the Piney woods lol |
07-21-2010, 11:59 PM | #23 |
Still Learning
Looks like a solid start for a project! Hard to believe someone could survive that crash! Wow!
07-22-2010, 03:27 PM | #24 | |
07-22-2010, 04:16 PM | #25 | |
Still Learning
thanks |
