Old 07-19-2010, 05:52 PM   #1
Field and Son
Field and Son's Avatar
Parting out Complete 1972 Long Bed
I am selling parts or pieces off the truck pictured. The body is mostly rough and or rusted, but would have some patches if you need? Engine appears to be complete as does the drivetrain. Ask if you need anything not priced.
Black door panels $85 shipped
gove box door $25 shipped
ashtray $15 shipped
gauge cluster $45 shipped
steering column -3 spd $65 shipped
horn button $20 shipped
one good visor $20 shipped
350 engine complete $250
3 speed transmission $50
Hurst Indy shifter/linkage $75 shipped
complete frame w/rear and front discs $250
Ask about anything else.
Field and Son is offline   Reply With Quote
Old 07-19-2010, 05:54 PM   #2
Field and Son
Re: Parting out Complete 1972 Long Bed
Old 07-19-2010, 05:55 PM   #3
Field and Son
Old 07-19-2010, 06:00 PM   #4
sharpie1972
Heat riser tube and manifold shield and manual throttle assembly with gas pedal? Received payment and shipped your horn cap today. Tried to send PM but your inbox was full. Thanks, Sharpie
sharpie1972 is offline   Reply With Quote
Old 07-19-2010, 06:11 PM   #5
Field and Son
Sharpie, I just got that inbox cleaned out, so sorry for not being able to accept earlier. How does $35 shipped sound for the parts you need??
Old 07-19-2010, 06:15 PM   #6
sharpie1972
Sounds great. Shoot me a PM on payment details. Thanks, Sharpie
Old 07-19-2010, 06:34 PM   #7
nightmare
nightmare's Avatar
what gears are in the rear end? Posi?
Mike
2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip
1972 Chevy Suburban - Turquoise/Black
1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD
Using your turn signal is not "giving information to the enemy"
67-72 FAQ
Originally Posted by GMCMAX View Post
My lugnuts require more torque than your honda makes!
nightmare is offline   Reply With Quote
Old 07-19-2010, 06:41 PM   #8
Field and Son
Not sure of rear end gears or how you tell?? Not marked on glove box as having a posi rear.
Old 07-19-2010, 06:56 PM   #9
michael bustamante
michael bustamante's Avatar
how are them dog dishes looking, can you take a pic of one or 2 of them? I see 3 you have all four?
1967custom
michael bustamante is offline   Reply With Quote
Old 07-19-2010, 06:58 PM   #10
Field and Son
I have all four hubcaps. Three I would call veyr nice and the fourth has some dents. I will post some pics for you in a bit.
Old 07-19-2010, 07:04 PM   #11
nightmare
nightmare's Avatar
the easiest way would be to open the differential. however, you can also jack up the rear of the truck, mark the driveshaft and tires, then rotate the driveshaft. however many turns it makes compared to 1 revolution of the tires is the gear ratio. also with it jacked up, if the tires rotate in the same direction, it should be a posi, however, if they rotate in opposite directions, it's a one tire fryer.
Mike
67-72 FAQ
Old 07-19-2010, 09:10 PM   #12
Field and Son
michael bustamante,
Here are the caps. Two are pretty decent and one fair, and one bad. $25 for all shipped.
Old 07-20-2010, 10:17 AM   #13
gcburdic
Restoration Virgin!
gcburdic's Avatar
is that wood grain bottom trim??.....what condition is it in?
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 07-20-2010, 10:33 AM   #14
Field and Son
It is woodgrain bottom trim. Condition varies from some being acceptable and good driver condition to some being bad and or dry wall screwed on. If you need any specific pieces let me know.
Old 07-20-2010, 10:48 AM   #15
gcburdic
Restoration Virgin!
gcburdic's Avatar
I'd be interested in anything that's good from the back of the cab to the front clip (not interested in the bed stuff)....if it's not too much trouble, maybe pictures of the good stuff before you remove it???
Geoff with a G
Old 07-20-2010, 11:10 AM   #16
hoss67
hoss67's Avatar
Does it have a front sway bar? If so, what size. Thanks
hoss67 is offline   Reply With Quote
Old 07-20-2010, 12:08 PM   #17
michael bustamante
that last one is pretty bad. I dont think its fixable, can you do 20 shipped? If so Ill take em
1967custom
Old 07-20-2010, 02:00 PM   #18
Field and Son
The one is bad and has a tear in the metal. If I can just send the three to cut down on shipping I can do $20 for them.
Old 07-20-2010, 03:47 PM   #19
michael bustamante
you got it, what s the payment info?
1967custom
Old 07-20-2010, 03:50 PM   #20
Field and Son
PM sent for payment info...Thanks
Old 07-20-2010, 04:32 PM   #21
Field and Son
Sway bar is original to the truck according to the glove box label and is about 1" in diameter and goes from coil to coil. $50 shipped.
Old 07-20-2010, 04:39 PM   #22
hoss67
hoss67's Avatar
Thanks but I will pass on sway bar.
Old 07-20-2010, 08:14 PM   #23
Camaro_nut2001
Chevy Lover Till The End.
Camaro_nut2001's Avatar
What kind of shape is the tailgate in?
1969 Chevy SWB Big Block - Under the knife as of 12/26/2011
1989 Chevy Silverado, 4X4 - Daily Driver
1996 Chevy Suburban K1500 - 4-Wheeler, Campin Truck
1968 Chevrolet Impala Sport Coupe - 327/350hp, TH400, all original.
Members I've met: BamaBaxter,
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=500359
Camaro_nut2001 is offline   Reply With Quote
Old 07-20-2010, 09:59 PM   #24
Field and Son
Tailgate is pretty dented up and bowed. Would sell for $20 plus shipping if interested.
Old 07-21-2010, 12:39 AM   #25
yellowGT
yellowGT's Avatar
Not sure if that pass. ram horn exhaust manifold will fit the 283 but if so how much shipped to 75040?
Also how much for the radio complete with knobs and all?
'84 swb chevy
'69 swb chevy
'68 swb chevy
'95 Impala ss-sold
'89 chevy crew cab dually 3+3
yellowGT is offline   Reply With Quote
