Old 08-31-2010, 04:55 PM   #1
robnolimit
robnolimit's Avatar
Make it handle
If you guys (and gals) want, i'll try to keep responding to your handling questions.
Making these trucks handle is easy at first, but the more you want to get out of it, the more work it becomes. The are several things to consider. Tires, Wheels, Weight, Suspension, Brakes, Gears, ....... Set your goals before you start, as some of the parts change the deeper you go. Also, decide how streetable you want it to stay. The more you want to pull one 'G', the stiffer it's going to get. Drop spindles are better, in general, than short springs, this helps to keep the suspension in the sweet spot. In the rear, (trailing arm) blocks are better than short springs for the first 2 inches. Then go to springs. For leaf trucks, use de-arch springs or a flip kit, no blocks. Go BIG on the sway bars. And, spend $$$ on shocks. Doetsch, KYB, or Bilstien, this is where it happens.
Give me some questions, and I'll be more specific on the details.
robnolimit is offline   Reply With Quote
