09-05-2010, 01:30 PM | #1 |
unigue to 67'
was looking for info on parts and pieces that would be specific to 67's
such as,no side marker lights,kick panel vent pulls,wing vents etc... my 67'project has only one visor and no holes where the passenger one would have been,.... also on the use of a 327 engine,history and usage,what was the last year they were used in these trucks thanks, |
09-05-2010, 05:58 PM | #2 |
Re: unigue to 67'
If you have only one sun visor, this means the truck did not have the custom comfort option, which mainly consisted of extra insulation, dual visors, and full foam seat. The custom comfort option was available even on base model trucks. The 327 was introduced in Medium Duty trucks in 1962, became a standard option in mid '65 on 3/4 tons. Became a standard option in the whole light duty line in '66. Reworked in '68 with larger bearings. 1969 was replaced by the 350 in the pickup line.There are cases where the 327 was special ordered thru COPO on early models.
09-05-2010, 06:27 PM | #3 |
Re: unigue to 67'
283's were standard V8 with 327 Special Ordered in 67. 307's replaced the 283 in 68 as the standard V8. I thought. Some 67's passenger door arm rest wasn't installed in addition to no visor. (That's really cutting back on comfort.) The ignition bezel is a different size than the other models. What about bullseye clear back up light lens and the chrome around the fleet tail lights are slightly different than the rest of the years?? I think the west coast mirrors were only available in 67 and 68. Tripods 69 and later.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
09-05-2010, 07:22 PM | #4 |
People know me
Re: unigue to 67'
Mine has a differnt rearview mirror bracket, I had no armrests on either side, and no passenger visor. I believe the auto columns had a metal shifter indicator and a shorter pointer as well.
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels 1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels |
09-05-2010, 08:13 PM | #5 |
Sisyphus was my mentor!
Re: unigue to 67'
Non-recessed ignition switch, the clips that hold the sunvisor up are different - (they have a larger hole than later years) & knurled interior switches. Also, 67's have the cool factor that the later years didnt have either...
passthebuck #5642 -TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4. -a 2013 Honda Civic as my "sensible" car Last edited by passthebuck; 09-05-2010 at 08:14 PM. |
09-05-2010, 08:21 PM | #6 |
Re: unigue to 67'
When you make a list it gets longer than you realise. I looked in my stash found my 67 Tail B/U Lens the top one is later years and repo's are similar. The rare CST Chrome 67 only Mirror, most were black.
09-05-2010, 08:29 PM | #7 |
Re: unigue to 67'
Fuse box is mounted sideways. Last year for the small window cab. No Aux battery boxes. Paint on dash face & glove box is wrinkled. Door exterior handles are different internally. No ACC. position on ignition switch, only off/on/start. Also last year for the SM420 4 speed.
09-05-2010, 08:29 PM | #8 |
Re: unigue to 67'
Ashtray is also one year only. CPNE schooled me on the fact that the outside door handles are 67 only. Seatbelts are 67 specific. Inside door handles, wing window latches. This is going to be a fun thread! Keep them coming! Sharpie
09-05-2010, 09:30 PM | #9 |
Grandpa in the rustmobile...
Re: unigue to 67'
I pulled a mirror from 67 gmc and it looks nothing like the one posted above.....
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
09-05-2010, 09:57 PM | #10 | |
Re: unigue to 67'
Posted via Mobile Device |
09-05-2010, 10:11 PM | #11 |
Re: unigue to 67'
Exterior door handles have a different angle to the mounting bolts (doors have a reinforcement plate inside). Ashtray is flatter, not near as much "puff" to the sheetmetal. Sharpie
09-05-2010, 10:12 PM | #12 |
Re: unigue to 67'
I believe the jack and accesory storage is specific to 67. All under the seat instead of accesories in the cab corner. Sharpie
09-05-2010, 10:23 PM | #13 |
Junior Member
Re: unigue to 67'
Frame is not dimpled for steering box.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
09-05-2010, 10:56 PM | #14 |
Re: unigue to 67'
67 only GMC tidbits. Only year with GMC on the grill and no adjustment access on the headlight bezels. Sharpie
09-06-2010, 03:11 AM | #15 |
Re: unigue to 67'
'67s have parking lights that go out when you pull the Lights knob all the way out. The glove box door is flat black. '67 K/10s use "Power Assist Steering" --and only rarely-- with a hydraulic ram assisting the manual gearbox. The vent window latches are a holdover from the "Task Force" '60/'66s. K/10 front brake drums (on closed knuckle Corp front end} are very rare, hard to get, and expensive when you find them.
09-06-2010, 03:24 AM | #16 |
Re: unigue to 67'
I pulled a chrome rearview mirror bracket like that off my Dad's '64 Olds station wagon when we junked it (with a blown out 455). That was in the early '70s. When I bought a '67 K/10 Suburban in '93, the P.O. had a cheap repop '72-style glued-on-the -windshield mirror. It shook so bad you couldn't see out of it. I rememberd my souvenier of the old station wagon and dug it out. It mounted on the '67 like it was made for it. Still there. Although the Sub is lying fallow "until my ship comes in."
09-06-2010, 04:15 AM | #17 |
Re: unigue to 67'
cigarette lighter is not bezeled or rescessed last year for buddy buckets being factory on all csts
09-06-2010, 08:45 AM | #18 |
Re: unigue to 67'
wow!thanks for the great response i knew there were a few differences' but you guys take the cake!! "dimples on a frame rail" this is cool!!
09-06-2010, 08:49 AM | #19 |
Re: unigue to 67'
so if a guy was to pick up a 66' would alot of these parts be there,should i be going back a year or two in catologs to find these "unique" items.
09-06-2010, 09:03 AM | #20 |
Junior Member
Re: unigue to 67'
Checking various year's catalogs is a good idea.
I keep the catalogs on hand from LMC for reference. 67-72 and the years just before and just after. They have helped us a lot while we are working on these old trucks. I have a '68 swb stepper bed with a '62 GMC tail-gate.
09-06-2010, 10:12 AM | #21 |
Re: unigue to 67'
This was a great thread. I wondered where the pass sun visor hole went :-) My 67 had only 2 line items on the glove box sticker. As bare a model as you could get.
09-06-2010, 10:22 AM | #22 | |
Re: unigue to 67'
09-06-2010, 11:15 AM | #23 |
Re: unigue to 67'
when did the emergency/parking brake handle change? I had a '68 so long ago I can't remember.
Dad always said, "Son, WISH IN ONE HAND, and ......." -------------------------------------- -------------------------------------- Current toy trucks: '71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C '72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt Last 10yrs of hobby vehicles, had a FEW more in the 50yrs. before these: '66 Plymouth Belvedere City of Miami cop car clone. '70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!! '67 C10 short/step side mount spare -- SOLD!! '72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!! '69 Nova 350, 4spd, A/C, ps, p.b, ...SOLD!! |
09-06-2010, 11:27 AM | #24 |
Re: unigue to 67'
69 was the changeover. 67/68 style had the cool park brake cover accesory as well, usually on higher end trucks. Sharpie
09-06-2010, 11:38 AM | #25 |
Re: unigue to 67'
Here's a few shots of 67 dashes and knobs. Plain, tach, and that elusive speed warning (set at 82 mph!) . Sharpie
