Ahhhhhhhhhhhhhhhhh, A/C in the Burb!
I finally got motivated to install the aftermarket A/C in the burb. I purchased it a year ago on ebay from someone on the board that lives in Texas. Im sorry, but I don't remember the screen name.
With the help of HJAlbert and a little panic trying to find a correct water pump pully, it is up and running an blowing nice cold air. By the way the pully that worked for me was a 3 grove oldsmobile pulley. Everything lined up perfect.
Just sitting here contemplating contemplation. |
Cool !!!!! :p
KEEP ON TRUCKING
gotta luv that ac lol
72 cheyenne 2wd lwb 71 k20 sons bassett va |
Hhhhmmmm, I wish my 69 had a/c. Oh well, someday.
its all about the +6 inches
I am kinda wishing the longhorn was an A/C truck, but I doubt I will ever do anything about that.
![]() Join Date: Mar 2000
Boy is that ever gonna kill that high MPG you're always working to get LOL. So what's it gonna be good mileage or ridin' in comfort? I like good mileage but when it's a scorcher I say crank up the air
Saskatoon, Saskatchewan Canada |
Actually, the EPA has done tests (with newer more aerodynamic vehicles) and say that you'll get better MPG on the free way with the A/C on instead of having the windows down. The windows really upset the air flow.
AMA....Arizona Mobile Air
You ever heard anythng about their aftermarket A/C systems 68 Suburban? I am needing to get the cold air blowing in my burb. Getting air for the just the front from AMA is gonna cost me about $1200...........$1700 for front and back. Do you have just the front unit....and does it cool down the whole vehicle?
'71 GMC Suburban C1500 |
#9 | |
Also, like longhornmail said, the windows down doesnt help with the MPG. And by the way, all my MPG stats were done with the windows down!!! Maybe I will gain some MPG!!! ![]()
#10 | |
Re: AMA....Arizona Mobile Air
As for how it cools? Im sure it would cool a lot better in the back with the secondary unit....lol. It is blowing out the vents at 35 degrees when it was 105 out. (Not bad for 134a)I have only had it hooked up for 1 day, so I can not give you all the answers you are looking for. I also need to fix some things on my truck. I need a new fan shroud, install the gromets on the firewalls to keep the hot air out, cut of the circulation of the hot water to the heater core. It would also help if I had new seals on the doors.
68 Suburban - was your "motivation" the 100+ degree temps in Phoenix lately? They sure motivated me.
I just got my original AC working again last week. Turned out to be a broken wire... cost me nothing! (that never happens!) I was only getting about 10 MPH before, and it's definitely worse with the AC running.
Paul 72 Cheyenne Super Custom Camper greenaz@hotmail.com |
#12 | |
![]() As for my motivation? It was because of my trip back to Chicago. I dread that humidity in the mid-west. Plust I thought I would give the Dingoes a break from the heat ![]()
Just sitting here contemplating contemplation. Last edited by 68 Suburban; 06-08-2003 at 02:30 PM. |
14.1 @ 96MPH
I really need to convert my factory air to an aftermarket 134a setup one of these days. Between the price of freon and the price of gas (that old setup is a big drag...I have to raise my idle in the summer to keep it from chugging at lights when the A/C never gets shut off!)
What would a complete 1970 factory air setup (minus one bracket, probably...the one from the compressor to the intake) go for used? Only way I could afford the $1k-plus for an aftermarket would be to sell all of the stock setup...
Project1970 - LS1 Swap Complete! ![]() |
Project 1970, keep your eyes out. There are better prices to be had if you watch.
That was one thing I was shocked about, was that I did not even have to adjust the idle with this new compressor. It is like it isn't even on.
#15 |
would this work?
is this a good deal.....for what comes with it? and could I make this work for my 'burb? I am trying to spend as little as possible while still getting something that wil actually keep me cool.
http://cgi.ebay.com/ebaymotors/ws/eB...&category=6765
#16 |
The most important thing is the correct brackets for your engine. I also don't see a compressor in those pictures.
#17 |
compressor
so i need to match up a compressor to the system..or to the motor? and then the brackets and pulley,lines and a condensor too?theres another $300 eh?
#18 |
14.1 @ 96MPH
![]() I was driving around and heard the fan drop in speed...felt the toggle, felt warm...felt behind it, TOASTY! ![]() This'll easily be the third or fourth one I've toasted since I've been driving it...I've already replaced the blower motor, the high speed fan relay (which is also disconnected because the power feed wire gets HOT!) and the connector to the switch as well...I really really want a new A/C setup.
#19 | |
huh?
![]() Join Date: May 2000
![]() TJ
Someday when I'm lonely, Wishing you weren't so far away, Then I will remember Things we said today. RIP El Jay |
#20 |
Or a relay to take the load off your swich!!!
#21 |
14.1 @ 96MPH
Either way would probably work (the relay would pretty much be the new harness right there, heh!)...right now, no money, no time, and no garage. Hell, I've had to go 300mi beyond when I should've for my oil change because of those at the moment.
#22 |
I need a vacuum pump to service my A/C. Harbour Freight has one for $16. This seems very cheap. Says it'll pull a full vacuum in 2 minutes. Does this require an air compressor? It says something about 90psi.
Also, my blower switch goes out evry 2 yrs. and has to be replaced. The hi position always works though. Strange.
69 C10 longbed: 357c.i. /TH400/3.73s/AC/ beige primer/saving $ for paint ______________________________ |
#23 | |
#24 | |
The high position of the switch is straight through as in not going through a resistor. The bearings on your evaporator fan motor might be shot and causing it to draw more current than normal. This causes the lower-speed resistors to open up. Richard |
#25 |
Thanx guys. I used to borrow a friends pump in Houston, but it was electric, not pneumatic. I always put in on for an hour and then watched gauges another hour for any leakdown. I built my own system. It uses a 1987 evaporator and condensor except its still the old "Long" type compressor and R134.
