09-19-2010, 12:01 AM | #1 |
Best Paint for Rally Rims??
I picked some up and wanted yer opinons on a paint that will last some years...
1993 Chevy Silverado. 1984 Chevy Z28. 1972 Chevy Custom 10. 1965 Custom 10..FOR SALE |
09-19-2010, 12:22 AM | #2 |
Grandpa in the rustmobile...
Re: Best Paint for Rally Rims??
powdercoat would look good if ya can afford it, other than that idk
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
09-19-2010, 09:45 AM | #3 |
Tot Roddin'
Here's what I used:
Krylon (Metallics) - 1403 Dull Aluminum It's tough to find be I picked it up at O'Reilly's. Check out this link (post #185) for an after shot with the paint on the wheels: http://67-72chevytrucks.com/vboard/s...k+slate&page=8 Let us know if you end up using something difference, and your experiences with that product.
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
09-19-2010, 11:50 AM | #4 |
The correct color is argent silver, many mail order part houses carry it. Silver Alumimun Rust-oleum is very, very close and can be found at Home Depot or Lowes. Shoot a coat of clear coat and it will last a long time.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
09-19-2010, 10:24 PM | #5 |
Parts and more parts
Unless you clearcoat the rims, use the rim paint that duplicolor sells for the different rim colors. Go to OReilly's
Frank |
09-20-2010, 08:59 PM | #6 |
the truck on my avatar has rallys & I sprayed them with silver rattle can paint & they look marvelous cheers, Pat
09-21-2010, 08:28 AM | #7 |
for a daily driver i've always l;iked rustoleum because its cheap and readily available so you can touchup easily
09-21-2010, 08:56 AM | #8 |
Redefining LowBudget
if the rimds are a little pitted ot your not looking for hat perfect finish I used the rustoium Hammered finish and there holding up very well aftter a year of DD
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. Mikes Sandwich Fair Run OCT 8th 2011
09-21-2010, 03:17 PM | #9 |
x2
1977 Camaro 468 BBC - SOLD - 1972 Chevy SWB....in the works!! 2006 Crew Cab Dmax/Allison Summit White-SOLD- 2009 Toyota Tacoma V6 Pre Runner - daily driver - my build thread -http://67-72chevytrucks.com/vboard/s...95#post4774595 |
09-22-2010, 12:48 AM | #10 |
Appreciate all the tips...
09-25-2010, 09:41 AM | #11 |
I did like most have already stated,had them blasted ,sprayed with Krylon primer inside and out.Sprayed faces with aluminum silver then a coat of hammered finish they came out looking pretty good.That hammered silver is a pretty tough finish.Also been running almost a year.Good Luck!!
09-26-2010, 08:19 PM | #12 |
who makes and where did you buy this hammered finish paint? Any pics?
09-27-2010, 09:27 PM | #13 |
low n' slo
i got mine at lowes, made by rustoleum i believe. i used it on my control arms and tank/compressor mounts. just make sure you prep good. i wish i would have used a primer too...but it does look good!
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] Last edited by kev2809; 09-27-2010 at 09:29 PM. |
09-27-2010, 09:31 PM | #14 |
any close ups kev?
09-27-2010, 09:55 PM | #15 |
low n' slo
these are the only ones i have i think...
heres the drop spindles.. and heres the lca, with the paint can next to it..
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
09-28-2010, 06:51 PM | #16 |
These are the pics just as I got finished painting the wheels,right before getting tires mounted.The paint I used was Krylon bright silver for a base then used Krylon hammered silver over to finish off.
09-28-2010, 06:58 PM | #17 |
low n' slo
^^^ what did you prep the metal with (wire wheel, sand paper, blast) and did you use any primer?
09-28-2010, 07:51 PM | #18 |
Wheels were sandblasted,primered,base coated then hammer coated.Used all Krylon paint.Oh yeah,forgot to state that the wheels are painted satin black on inside and back side.
01-12-2011, 02:43 PM | #19 |
low n' slo
i know this is a little old..but is there a cheaper way other than blasting to get the rim sanded and prepped?
01-12-2011, 03:38 PM | #20 | |
needs more $$$
.Also, we painted a buddy's 4-Runner wheels (his daily driver) gunmetal grey using the wheel paint at O'Reilly's at the beginning of the summer. We sanded, primpered, painted and cleared using all the same brand and still to this day there's no chips, cracks or peels. He even had new tires installed 3 weeks later and either the paint held up well or the tire shop took good care on putting them on
1970 2wd Blazer |
01-12-2011, 04:21 PM | #21 |
low n' slo
did u sand to bare metal? im using valspar one stage black. i heard it sticks pretty damn good. i was thinking rough it up with 180, spray a few coats of primer, 400 wetsand, then shoot 2 coats of paint
01-12-2011, 04:53 PM | #22 |
needs more $$$
Nope..they were alloys so we just roughed up the top clear coat with some scotch pads, and smoothed the areas where the clear was gone and shot it. No sanding at all between any of the coats and didn't bother wet sanding the clear. The looked good though as is.
1970 2wd Blazer |
01-12-2011, 10:21 PM | #23 |
low n' slo
ya i cant go that route. these older rims i believe are painted? mine are white...
i really hope i dont have to get down to bare metal...there is a lot of nooks and crannies and curves to have to get to bare metal..
01-22-2011, 01:29 AM | #24 |
Any more pics of the rims on the truck?
01-22-2011, 08:52 AM | #25 |
hey Kev try taking your wheels to your local head stone carver...yea you know the guy who makes tombstones ( there everywhere) they sand blast all the time and will ussually do them for next to nothing...since they arn't in the buisness....just ask them whne the next time they will be doing it or drop them off and have them give you a call when there done
