10-11-2010, 10:28 PM | #1 |
1964-66 chevy Power steering
I'm sure theres already been a thread here some place but I have not seen it yet so I'm asking:
Has anyone here done a Power steering conversion on the 1964-66 trucks? What did you use to do it? How did you like who it turned out??
Measure with a yard stick Mark with Chalk Cut with a torch Built it yourself, don't count on others to to do it for you or with you. It will never get done |
10-12-2010, 12:24 AM | #2 |
Re: 1964-66 chevy Power steering
I did it to my 64 inline 6... To put it simply. BEST MODIFICATION TO DATE. I love it! I used the CPP kit, original chevy power steering pump brackets, old style chevy pump, O'reilly auto replacement pressure hoses and a rebuilt steering box. The worse part about the hole thing... the CPP kit... The parts quality is meh and several of the fasteners where the wrong length, thread, size or all three. I'm lucky I had a shop on hand with all that kind of stuff in reach or I would have been screwed. BUT there are other options... I highly recommend getting in touch with LILRED66 on here, his name is Tony. He is a avid restoration expert on these trucks and makes a power steering kit that is much more complete. I've seen the kit first hand and realized I made a big mistake buying the "name brand"
10-12-2010, 09:35 PM | #3 |
One foot in front of the other
CaptainFab also makes the plate.
Good Info here: http://67-72chevytrucks.com/vboard/s...d.php?t=381321 and here: http://www.persh.org/pickup/steering.htm |
10-13-2010, 12:45 AM | #4 |
60-66 Nut
Thanks DPowers
A power steering conversion is definitely worth the effort. The parts are readily available and it is easily done in a weekend. The only exception is if you have a 292 I6. The power steering pump brackets for those are extremely hard to find and $$$$$ when you do find one. Let me know if you're interested in a steering box plate, or anything else that I offer. Links are in my signature line.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 10-13-2010 at 12:47 AM. |
10-13-2010, 12:07 PM | #5 |
Junior Member
Do you have any pics of your brackets? I made some work on mine...but am unsure if they are correct.
1966 Chevy C10 Longbed I'm Bob....ol Curt was my Grandpa The truck was his and he sure as heck wouldn't understand why I took a perfectly good truck and tore it down! |
10-13-2010, 10:20 PM | #6 | |
HOW long until spring??
Details and pictures are in my build thread "Bubba's recyling project" 60-66 build section. I am very pleased with the way it turned out, and it drives wonderfull. Recommending you put the disc brakes on also , you will not regret it. Captainfab makes a quality product and it is easily installed to use the newer style 70s gearbox. PS> find a sway bar off a mid 70s truck- It improves the cornering tremendously and takes away the "push" and "roll".
69 chevelle convertible 71-C-10 short-wide and low 64 C-10 custom shortbox "Bubba"s Recycling project" Last edited by bubba327; 10-13-2010 at 10:23 PM. Reason: Added text |
10-15-2010, 04:13 PM | #7 |
Power steering???? Bleh!!! U just need to learn how to drive that truck. I never had a problem.
Cheers David 66 LWB Fleet (on hold) 64 LWB Fleet (daily driver) 65 SWB Fleet (almost finished as a driver) 64 SWB Fleet (just started - "Tommys Hot Rods" tribute truck) Nothing worth doing, is easy. |
10-15-2010, 05:20 PM | #8 |
My '66 is currently using a, shall we say "rigged," power steering setup. It works, but it's not pretty and it leaks. When we go through and rebuild the truck properly (soon) we will be using the front pieces/parts and such off of a newer model truck so that things work a bit better.
10-15-2010, 07:48 PM | #9 | |
I consider power steering is a modern option well worth considering in a street rod. I consider power disc brakes a requirement. Safety should always come first.
69 chevelle convertible 71-C-10 short-wide and low 64 C-10 custom shortbox "Bubba"s Recycling project" |
02-05-2011, 06:08 PM | #10 |
If I was to use a power steering gear box off of a 87 model truck, will i have to use all of the steering components off of the same year truck?
02-05-2011, 06:31 PM | #11 | |
Can you sent me a PM and explain what's a PM. I really need to order the adpator plate for my 64. All the steering system is from 87. thx |
02-05-2011, 06:38 PM | #12 | |
ron Last edited by padresag; 02-05-2011 at 06:39 PM. |
02-05-2011, 11:01 PM | #13 |
1965 C10 SWB Fleet Two owner LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880 |
02-05-2011, 11:49 PM | #14 |
60-66 Nut
In my opinion it is easier that way. If you don't have the complete '87 steering linkage, you can use your original without much problem. If you're converting to front disc brakes, you will likely need a special adapter type adjusting sleeve for the tie rods. There was a member that not llong ago mentioned that he may have founf outer tie rods that would eliminate the need for the adapter sleeve, but I haven't heard a comfirmation on that. I typically just convert to the later model steering linkage. Even though you will have to drill holes for the newer idler arm, it is still simpler IMO.
02-05-2011, 11:56 PM | #15 |
60-66 Nut
I sent you a PM.
Up in the top right hand corner where your user name shows up, including the last time you visited this site, it says 'Private Messages' Click on that and it will take you to your inbox. If you would rather place an order via email, my email address is captainfab454@hotmail.com
02-06-2011, 06:43 AM | #16 |
O. K. I have a 292 I6 so what are the options?
Does someone have a photo of one? Do they make aftermarket options? |
02-06-2011, 11:45 AM | #17 |
Lucky, if you can fab some, there is an option to the original factory brackets and pump. Its what a lot of street rodders do, and it's my plan on my 292. Use a later generation GM Type II pump with remote reservoir! You may have to fab some for a mounting bracket, but you can mount the pump down low below the alternator.
292 + TKO500 |
02-06-2011, 12:23 PM | #18 | |
01-28-2014, 03:40 AM | #19 |
I have already installed front disc brakes with drop spindles, how exactly does that affect the power steering installation?
01-28-2014, 01:11 PM | #20 |
Rickey-Lee.
The 2 different installs won't affect one another. However now you have the best of both worlds. Easy steering for the parking lots and easy breaking for when that kid pulls out infront of you. Cal. |
09-22-2014, 05:36 PM | #21 |
I will be completing the conversion on my 66 pretty soon. I rounded up my donor parts that were pulled from an 82 1/2 ton ( steering box and pump/w hoses) that have been sitting in the shed for three years. I have no idea how the pump mounts but I think I'm missing a bracket for the backside of the pump. This pic shows the same front bracket but for the life of me I cant locate any rear brackets. The pump does have the stud sticking out of the back of the pump. Looks like I need to hit up a salvage yard......
PM me for any info on this bracket and what year it came off of Last edited by CustomCab66; 09-22-2014 at 05:38 PM. Reason: Request info |
09-22-2014, 05:58 PM | #22 |
this is an old thread but you can u any of the brackets from a 68-mid 80's truck with SBC
09-22-2014, 11:55 PM | #23 |
60-66 Nut
The long water pumps weren't used until '69 in the cars and '73 in the trucks. I would look for a truck application for the PS pump brackets.
11-30-2014, 12:36 AM | #24 |
But Found Her 25yrs Later!
Is this a long or short waterpump?
Is it the long or short waterpump that is needed for mounting a power steering pump?
11-30-2014, 02:24 AM | #25 |
That would be a long water pump.
http://www.chevytech.com/2c41o2.html You can use either style as long as all the pulleys and brackets are the same. Just make sure the pump, pulleys, and brackets match. The long pump setup would be easier to find in a salvage yard since they were all long pumps since 1969. Tip - a short water pump hugs close to the timing cover where a long pump will have some space between the pump and timing cover.
Doug Old Build Thread - 383/T56 http://www.67-72chevytrucks.com/vboa...d.php?t=540838 Updated Build Thread - Modern Relic - 66 C10 536 Dark Aqua 5.3/4L60E - BTR Stage IV Truck Cam - Vintage Air - Dakota Digital http://67-72chevytrucks.com/vboard/s...d.php?t=778784 |
