Old 10-18-2010, 06:20 PM   #1
70chevytruck
My Barn Find
Okay...so I know its not a 67-72 but I stumbled onto it looking at a rust bucket of a 69.
This is a 75 camper special with a 454 and a legitimate 57,000 miles. Been parked for at least 15 years.
My question is this: What needs to be done to it to get it running?
Spray the cylinders with some good lube and try to turn over the motor or just go ahead and pull the heads and put in new gaskets?
I know the tanks will have to be cleaned out and the Carb rebuilt.....thoughts?
Best thing about it is the price and no rust!!!
70chevytruck
70chevytruck is offline   Reply With Quote
Old 10-18-2010, 07:30 PM   #2
TheWhiteElephant
God is good!
TheWhiteElephant's Avatar
Re: My Barn Find
Looks like a '73-'74 model. I'd definitely drain/change all the fluids, clean/flush the tank, rebuild the carb, change the hoses and belts, and it "should" start right up if it ran when parked.
TheWhiteElephant is offline   Reply With Quote
Old 10-18-2010, 07:49 PM   #3
RandyP
Getting Old; Going Broke
RandyP's Avatar
Re: My Barn Find
Has a 73/74 grille, also 73/74 park lights, has a drip molding, so I'm guessing it's actually a '74. Awesome find, anxious to see what it looks like after a bath.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 10-18-2010, 09:45 PM   #4
Chlsnk
Chlsnk's Avatar
Re: My Barn Find
Make that a shortbed and that would have been a dream find for me. Looks like a super solid truck cant wait to hear how well she runs
when you get it started.
***My 84 short bed build up*****
http://67-72chevytrucks.com/vboard/s...68#post3481968
Chlsnk is offline   Reply With Quote
Old 10-18-2010, 10:02 PM   #5
THE "10" SILVERADO
THE "10" SILVERADO's Avatar
Re: My Barn Find
When you said it had been parked for a while you weren't kidding! You can't even see through the windows! A little cleaning and it will look great! Can't wait to see more pictures
Michael
Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9
THE "10" SILVERADO is offline   Reply With Quote
Old 10-18-2010, 10:43 PM   #6
irishman999
irishman999's Avatar
Re: My Barn Find
My 85 sat for 15 years in hot Arizona sun, For under 1k I got it back on the road and still running strong.
Here is what I did to mine. It was very simple.
Get a fire extingusher.
Pull carb off, soaked in a bucket of gasoline and changed out all the gaskets and the small parts that came with kit.
Take your fuel line loose going into the fuel pump and run some hose from the line going to the fuel pump into a container you want to fill with bad gasoline.
If you have compressed air grab a blow gun and wrap a rag around the end and stick it into your fuel filler. Pressurize the fuel tank and the gas flows out of the lines into the container, this takes a while.
Put on your rebuilt carb and change your fuel pump, the diaphram is most likely dried up and bad in your fuel pump so save the trouble and just change it.
Instead of using the metal line going from the fuel pump to carb just get some nipple fittings and run a rubber hose from the fuel pump to carb and put a clear plastic filter in. It will get plugged with crap often and after a while clears out, the plastic filter is just easyer to change and dignose fuel problems.
Change your engine oil and filter and add half a bottle of sea foam. Fill the tank with fresh gas and add the rest of your sea foam to that.
Pull your plugs and squirt some Marvels Mystery oil into your cylinder walls. Replace with properly gaped plugs.
Change out your wires, cap and rotor.
crank your motor without starting to slowly build oil pressure and evently let it start and idle. for a while, watch your temp guage.
If it runs decent move onto the cooling system and oils in your Trans, transfer case and differentials. If it does not run good pull your valve covers and check all your push rods. My engine had stuck valves that broke the push rods.
On top of all that I replaced: water pump, Radiator, hoses, belts, and the power steering pump.
irishman999 is offline   Reply With Quote
Old 10-19-2010, 07:31 AM   #7
walkerb
walkerb's Avatar
Re: My Barn Find
Nice find! god I love those 73-78 trucks.
Keep us updated!
1973 k20 Suburban 350
1974 Custom stepside c-10 250
1975 Chevy stepside 454
1986 K30 Crewcab SRW 350
R.I.P- glimmertwin01- board member and good friend, you will be missed
walkerb is offline   Reply With Quote
Old 10-19-2010, 08:51 AM   #8
JohnC
JohnC's Avatar
Re: My Barn Find
Nice find man. Looking forward to the progress.
JohnC is offline   Reply With Quote
Old 10-19-2010, 09:38 AM   #9
68Timber
I know the pieces fit
68Timber's Avatar
Re: My Barn Find
Wow. Looks like the chrome hubcaps might survive. Nice find.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 10-19-2010, 10:00 AM   #10
Jonboy
Slots go on anything!
Re: My Barn Find
kinda like a time capsule. Very cool.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 10-19-2010, 10:04 AM   #11
JimmyFloyd
Re: My Barn Find
can't wait to see what waits underneath the dust...
1970 Blazer 350/SM465/205 SOLD! | 1998 Z3
JimmyFloyd is offline   Reply With Quote
Old 10-19-2010, 10:11 AM   #12
motornut
78K & 79C Jimmys
motornut's Avatar
Re: My Barn Find
now thats a find
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 10-19-2010, 02:16 PM   #13
babyJay
Arrived on a Pale Horse
babyJay's Avatar
Re: My Barn Find
Build a plastic dome over it and let off some insect bombs to de-spider it....
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
Old 10-19-2010, 02:22 PM   #14
Pop's C-10
Pop's C-10's Avatar
Re: My Barn Find
A low mile big block square...nice find
Pop's C-10 is offline   Reply With Quote
Old 10-20-2010, 03:18 PM   #15
70chevytruck
Re: My Barn Find
The other great thing about it is the 8 track tape player and the CB radio....you remember what those are, right? Even comes with a few 8 tracks.
70chevytruck
Old 10-20-2010, 07:13 PM   #16
str8axle55
Re: My Barn Find
Awesome find, I want to see it outside and clean. Wish we had those around here.
03 GMC Yukon XL 2500 Quadrasteer, wife`s DD
84 Chevy K30 CC SRW
55 Chevy 210 2dr post
str8axle55 is offline   Reply With Quote
Old 10-20-2010, 07:18 PM   #17
1LoC10
Insert Title Here
1LoC10's Avatar
Re: My Barn Find
nice find, but why was it parked?
BOBBY
_69 SWB_
1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all <<
1LoC10 is offline   Reply With Quote
Old 10-20-2010, 07:20 PM   #18
steppside69
steppside69's Avatar
Re: My Barn Find
Nice find
69 chevy stepside (project)
2006 Silverado Z71 Ext. cab
2005 Saturn VUE (wifes dd)
steppside69 is offline   Reply With Quote
Old 10-20-2010, 08:00 PM   #19
79gmcclassic
79gmcclassic's Avatar
Re: My Barn Find
That would be a dream come true a roundeye big block lwb in a barn or shed!!!!
1979 GMC Sierra Classic
Freshly lowered 5 inches
79gmcclassic is offline   Reply With Quote
Old 10-21-2010, 07:23 AM   #20
70chevytruck
Re: My Barn Find
The owner was getting older and the truck had some minor problem so they just parked it and started working on it...just never finished.
Hopefully the engine is still okay....waiting on title.
70chevytruck
Old 10-21-2010, 09:06 AM   #21
justpball
justpball's Avatar
Re: My Barn Find
nice find, post up some pics of it cleaned up as soon as you can...
Fuzzy Dice Club Member
87 Crew SWB
Build for the crew
http://67-72chevytrucks.com/vboard/s...d.php?t=430082
http://www.cardomain.com/ride/3232925
90 burb 2wd
Build Thread For The Burb!
http://67-72chevytrucks.com/vboard/s...d.php?t=383055
justpball is offline   Reply With Quote
Old 10-21-2010, 11:28 AM   #22
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Re: My Barn Find
That looks like my barn.
Congrats on the find!
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 10-21-2010, 11:55 AM   #23
THE "10" SILVERADO
Re: My Barn Find
I used to have fun with CB's...probably going to put one in my truck when it is finished.
Michael
Old 10-21-2010, 11:59 AM   #24
WigglesTheHoly
IT Guy/ Father/ Chevy lover
WigglesTheHoly's Avatar
Re: My Barn Find
nice find.
78 Chevy (Pictures) SOLD
79 Chevy LWB (pasture)
83 Chevy LWB (crushed rusted beyond repair)
02 TrailBlazer SOLD
03 VW Passat wagonSOLD
95 extended cab silveradoSOLD (still in family)
05 Crew Cab Silverado 5.3 (The Turd)
WTB: 66 El camino
Technology Specialist aspiring to be a gear head.
WigglesTheHoly is offline   Reply With Quote
Old 10-21-2010, 01:18 PM   #25
DBLSPRT68
DBLSPRT68's Avatar
Re: My Barn Find
VERY COOL!!!!!!!!!!!! I can't wait to see it cleaned up also
PROJECT TRUCK: 1985 SWB C10 Silverado Black/Charcoal, 1990 V2500 Suburban, 2018 Suburban, 2005 GMC 2500HD CCSB, 2014 Toyota Camry SE, HAD.....1968 Camaro RS/SS Family owned since new; 350 3 speed SOLD
DBLSPRT68 is offline   Reply With Quote
