10-28-2010, 01:01 PM | #1 |
Re: Silver Dollar
Great job! Where did that "jeep tank" came out of?... A cherokee? Did you use the stock jeep tank fuel pump?
10-28-2010, 02:26 PM | #2 | |
Still Learning
Re: Silver Dollar
How is it mounted in there? |
10-28-2010, 02:36 PM | #3 |
Re: Silver Dollar
Subscribed this looks interesting and your doing helluva nice job.
10-28-2010, 05:16 PM | #4 |
chevy runs deep
Re: Silver Dollar
Nice look'n good anymore info on the tank what year and type of jeep did u get it from
RAIDER NATION 1969 c10 swb soon 2 b on the road... My LWB is a SWB now http://67-72chevytrucks.com/vboard/s...d.php?t=498241 |
10-28-2010, 07:19 PM | #5 |
Grandpa in the rustmobile...
Re: Silver Dollar
nice man! I cant wait to see it!
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
10-30-2010, 10:19 AM | #6 |
Re: Silver Dollar
That Jeep tank was a great idea. I wish I'd thought of it. It could have saved me some $$$.
67 5.3L Build |
10-30-2010, 10:58 AM | #7 |
Re: Silver Dollar
Your doing a great job! Keep at it.
10-30-2010, 01:01 PM | #8 |
Re: Silver Dollar
What size tires are you using? I am trying to decide between 18" and 20" wheels right now.
67 5.3L Build |
10-30-2010, 03:55 PM | #9 |
Re: Silver Dollar
After doing tons of searching, I came up with 87-90 jeep wrangler tank. it is a fuel injection tank so it did have a baffle inside. it measures 25x 18.5 x 11. it fit in the rear area there with no cutting or modifying of the frame. I did however have to use a piece of angle iron across the back to have something for it to rest on.
There is a flange all the way around the tank about a inch wide, so I drilled 1/4 holes in each corner and just bolted it in place. There were a few problems with putting this tank in. when I put the tank in I did it with the bed off and because it went in from the top when I put the bed on, the it hit one of the bed braces underneath. so I had to trim that back a little. Iv since concluded if I had mounted it from the bottom it most likly would have cleared. The fuel fill is only 1". and it is was right where the cross brace was as well. The only place I could find a 1" fuel fill hose, was McMaster Carr. (one could always just have a new fill welded on.) Anyway it worked out for me, but could be a problem for other installs. The sending unit is a stock GM I think I used one from a 85 c/10. I of coarse had to modify it to fit my fuel pump and sock on it. By the way thanks for all the encouraging compliments, I appreciate them! Last edited by mrhino; 07-21-2011 at 09:58 PM. |
04-01-2020, 08:57 PM | #10 |
Junior Member
Re: Silver Dollar
Found your thread looking for tank swap info and ideas. I love this Wrangler tank idea. Where did you end up running your fill tube to?
You also mentioned mounting to a 1" tank flange.. Is that effectively the pinch weld or is there a dedicated mounting flange from Jeep? Super clean install! |
10-30-2010, 04:02 PM | #11 |
Re: Silver Dollar
18's all the way around, fronts are 245/45 18 and rears are 255/45/18. take a look at my profile, there is a photo of my last truck(the blue one) I had 20's all they way around on that, and I didn't care for it. I thought it rode like crap.
10-30-2010, 04:24 PM | #12 |
Re: Silver Dollar
What kind of fuel pump are you using?
10-31-2010, 09:23 AM | #13 |
Re: Silver Dollar
I Had looked at so many at the time I dont remember for sure what kind of vehical it was for. Going back through my notes, I think I used one from a 94 Impala SS with a Lt1.
11-01-2010, 12:48 PM | #14 |
Re: Silver Dollar
10-30-2010, 09:58 PM | #15 |
Re: Silver Dollar
That's what I'm thinkin'. I would rather have a more comfortable ride and not have to worry about denting rims than have the bling of the 20's. I was actually looking at 255/45-18's all the way around as an option.
67 5.3L Build |
10-30-2010, 03:05 PM | #16 |
Re: Silver Dollar
looking good! I like the new motor in old truck. should run good. good to see another person from indiana doin a project
1972 Chevy 3/4 Ton 4x4 2001 Chevy Duramax 3/4 Ton 4x4 1972 Chevy Nova 468 BBC 1944 International K-11 1965 Chevy C-10 |
11-02-2010, 12:40 PM | #17 |
VA72C10
Re: Silver Dollar
Nice! Great score on the sheetmetal and I love those gauges.
Looking for a 67-72 swb or blazer project in or around VA. |
11-02-2010, 02:10 PM | #18 |
Re: Silver Dollar
mrrhino - actually, I think I ended up using the sending unit from a 90 chevy and cut it down because it was too tall. Did your sending unit/fuel pump assembly fit ok? Where did you decide to mount the computer? I mounted mine just above the heater box.
11-02-2010, 04:11 PM | #19 | |
Still Learning
Re: Silver Dollar
Mrhino, Very nice sheetmetal you stole from that nice gentleman! |
11-02-2010, 04:24 PM | #20 |
Re: Silver Dollar
Thanks mcbassin, I see it now.
11-03-2010, 11:04 AM | #21 | |
Re: Silver Dollar
He was a nice gentlemen, I gave him his asking price, not that i didn't try to talk him down. besides I would never steal anything from someone I didn't like. |
11-04-2010, 10:19 PM | #22 |
Re: Silver Dollar
very good looking build so far. subscribing for the ride as I too am in the middle of an lsx swap.
10-05-2011, 11:59 PM | #23 |
Re: Silver Dollar
On your gas tank, there were two small tubes sticking out the side (opposite side of the filler). What did you do with those?
1992 Gmc 2wd 1972 Chevy Blazer 2wd |
10-06-2011, 06:35 AM | #24 |
Re: Silver Dollar
I capped one off and used the other as the vent.
11-03-2010, 10:59 AM | #25 |
Re: Silver Dollar
No the c/10 sending unit didnt work either, I had to cut it to work. I tried to find the one for the jeep tank, but never did.
Tags |
5.3, boss 338, house of kolor, lsx, tank |
