Old 11-07-2010, 01:48 AM   #1
coyote72
coyote72's Avatar
My 14 Bolt Build
I wanted to put a 14 bolt in my blazer for durability and because we got a travel trailer. I didn't want to give up my wheels (6 lug) but I wanted the full floating axle. So I opened up the wheels center hole and got to work on the hubs. I used front rotors and calpiers from a '77 3/4 ton, and fab'd up some brackets. On the hub itself I drilled out the existing 8-lug pattern and tapped it for a 5/8-18 bolt to bolt the rotors to and also to plug two of the holes for the 6-lug overlap. Then came machining the bolt pattern, I used stock 12 bolt rear axle studs and counter bored the hub to accept them. Then turned the outside of the hub down to fit inside the wheel. I did end up having to turn down the heads of the socket head cap screws to get the wheel on. Every thing fit together great! Even my modified Gov-Lock has held up so far.
72 K5 4x4 350
70 Nova 454 5spd 4-link
coyote72 is offline   Reply With Quote
Old 11-07-2010, 01:50 AM   #2
coyote72
coyote72's Avatar
Re: My 14 Bolt Build
More pics
72 K5 4x4 350
Old 11-07-2010, 01:51 AM   #3
coyote72
coyote72's Avatar
more pics
72 K5 4x4 350
Old 11-07-2010, 02:41 AM   #4
Captainfab
60-66 Nut
Very interesting and nice work. It must be nice to have a lathe and a mill so projects like this only cost you some time. Did you have to grind the caliper much to fit the 15" wheels.
Old 11-07-2010, 07:26 AM   #5
Davidmichael
Davidmichael's Avatar
very nice work. love the fact you went with rear discs also.
86 Suburban 2WD = rolled it and totaled it
83 LWB STD Cab 4x4 = went to the scrapper. Was my baby.
84 Suburban 2WD = stripped it/ scrapped it
81 8 foot bed made into a trailer
86 Suburban going to be made into a trailer
91 Suburban 4x4 = that's my baby
00 S10 Xtreme STD Cab
01 S10 ZR2
Davidmichael is offline   Reply With Quote
Old 11-07-2010, 09:11 AM   #6
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Nice! *high five*
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 11-07-2010, 12:29 PM   #7
coyote72
coyote72's Avatar
I did not have to grind the calpier at all (thankfully) but it is real close.... enough to knock off my wheel balance weights
72 K5 4x4 350
Old 11-07-2010, 03:25 PM   #8
snj8198
snj8198's Avatar
very nice. neat to see a 6 lug on a full floating 14.
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
snj8198 is offline   Reply With Quote
Old 11-07-2010, 09:58 PM   #9
mod58
Excellent work for not using an indexer!!!!!!!You just gave me an idea!Thanks!!!!!!
mod58 is offline   Reply With Quote
Old 11-12-2010, 12:01 PM   #10
USSkoval
How much time did you have invested in that? I'm guessing the stock center cap has no chance of fitting?
-Andy
'77 K5 Blazer
'78 K10 Shortbed
'78 C20 Suburban
'79 K30 Crew Cab Dually
'84 C10 Short Stepside
'88 K20 Suburban
USSkoval is offline   Reply With Quote
Old 11-29-2010, 11:52 PM   #11
orbot
orbot's Avatar
Interesting job you did, i might do the same...i have seen several posts about converting the 8 lug to 6 lug but thoose guys usually buy a kit for it, good thing i god a buddy that has a machine shop..
orbot is offline   Reply With Quote
Old 11-30-2010, 02:25 AM   #12
vk_chevy
vk_chevy's Avatar
I guess it goes without saying that having the right tools for the jobs makes a world of difference.
72 Chevy C20 Longhorn
72 Chevy, K20 Custom Camper
67 Chevy, LWB, C20, 350/350, PS, PB,
65 Jag MKII
vk_chevy is offline   Reply With Quote
Old 12-02-2010, 05:05 AM   #13
k5xjfiles
Junior Member
k5xjfiles's Avatar
Please tell me what you are now doing for an e-brake. Ive got a 14 ff that is going under my 72K5 some day and will need some type of ebrake.
72 K5/10/20 Hybrid 350, 465/205 44/14 bolt 35s, Detroit locker
89 XJ Pioneer, 4.5" 32s.
98 ZJ DD.
Parting..87-01 Cherokees
I bore throttle bodies-PM me for details!
k5xjfiles is offline   Reply With Quote
Old 12-02-2010, 05:13 PM   #14
SeventyOne
I am swapping a 14bolt with discs in my Blazer and will be using a High-Angle-Driveline T-case ebrake. You can also use Caddy Eldorado calipers that have a built in ebrake but I hear they are expensive and hard to adjust.
SeventyOne is offline   Reply With Quote
Old 12-02-2010, 06:09 PM   #15
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Very nice job Coyote72! I'm guessing you could start doing this service for other member's hubs real easily.
Ryan
1969 Chevy milk truck
Old 12-02-2010, 08:25 PM   #16
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
Nice job Coyote! I saw a few people rework 14FF to 6 lugs and yours is definitely the cleanest job!
DirtyLarry is offline   Reply With Quote
Old 12-05-2010, 11:20 PM   #17
coyote72
coyote72's Avatar
For the E-brake I am thinking of using a hydraulic valve... kinda like a line lock but without an electronic solinoid. There is a company that makes a valve for that purpose. They are kinda pricey that I remember, I was going to try some alternative routes, maybe like grainger or something. I thought about the caddy calipers, but the cost of them new, or going through junk yards and rebuild didn't appeal too much to me. I was hoping to find a valve with a lever and use my parking brake release to set and release...
72 K5 4x4 350
Old 12-05-2010, 11:33 PM   #18
DirtyLarry
DirtyLarry's Avatar
Keep us all posted. Several of us want to go the route of rear disks but need a park brake without dealing with the hassles of the Eldorcrapo rear calipers. I really wish someone would come up with a kit to retrofilt the rear disk brake set up like what is on the 2001 and later Silverado/Sierra HD trucks that has a park brake drum inside the rotors.
Old 12-09-2010, 02:51 AM   #19
Franks Fab Shop
Franks Fab Shop's Avatar
i see your in orange. in HB theres a place called vw parts specialties ... i think off warner and newland. and they have those inexpensve and adaquit line locks.
i think bugpak makes them
Franks Fab Shop is offline   Reply With Quote
Old 12-09-2010, 10:55 AM   #20
fayettecopa
http://www.jbugs.com/product/3155.html
fayettecopa is offline   Reply With Quote
Old 12-09-2010, 09:08 PM   #21
msgross
msgross's Avatar
do you think it weakened the rim by removing the inner lip?
they also make disc e-brakes for the driveshaft... not cheap either.
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 12-17-2010, 05:59 PM   #22
coyote72
coyote72's Avatar
Thanks for the input on the parking brake. I think I will try the vw place, I've seen it before. I'm sure it will be ok as a parking brake, sometimes you just need a little extra. If I had a manual trans it would be a different story.
As for the wheels I did some research on reproduction wheels and they are made without the lip. The wheels no longer locate on the 'hub' anymore, but on the wheel studs. I figured if there are 6-lug wheels made out there with a 4.25" hole, it would be ok to machine mine.
72 K5 4x4 350
Old 12-17-2010, 11:19 PM   #23
TheWhiteElephant
God is good!
TheWhiteElephant's Avatar
Speedway Motors has a similar e-brake lock.
Mando
"It takes a smart man to know when he's stupid." -- Barney Rubble
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=430367
TheWhiteElephant is offline   Reply With Quote
Old 12-20-2010, 11:12 AM   #24
Burt4x4
Burt4x4's Avatar
http://www.mico.com/products/displaysubinfo.php?id=43
This is what I have been using for years now. Mostly as a third foot when wheelin but I do use it for temp parking brake...I wouldn't want my calipers to be at pressure for long periods of time..seams too me the seals would were out quicker but that is just my opinion. I did test it overnight when I first installed the lever lock and I did not loose any pressue to the calipers. Also I never did hook up the low pressuer alarm switch it comes with, buzzer or light type..
Good Luck and awesome job on the 6lug conversion!!
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 12-20-2010, 02:02 PM   #25
propanemudtruck
Local Redneck Authority
propanemudtruck's Avatar
Not to step on you and I've never done a rear disk conversion, but wouldn't a standard caliper e-brake apply pressure to the seals of the calipers too? This is a good topic! The build and the 6 bolt conversion are pretty interesting!
-Kevin
four on the floor feel the beat in your soul
movin to the rhythym pumpin til ya cant take no more
dance if you want to do what you came to
you cant ignore the feeling of that four on the floor
propanemudtruck is offline   Reply With Quote
