12-16-2010, 07:53 PM | #1 |
Project black-ops
I have wanted a 1970 C10 for 10 years now. I finally made the decision to go for broke and find my truck. I live in Utah, so finding a rust free truck under $10,000 is about inmpossible. I searched far and wide for months before finally finding my truck in Bellevue, Nebraska. I got a great buy on the truck, so I convinced my buddy Mike to go with me on the 2 day journey to get it. Outside of Cheyenne, Wyoming we got caught in a hail storm that destroyed Mike's Duramax. Luckily his insurance company took care of the damage or I would still feel bad. It was quite an adventure getting to Nebraska but finally I loaded up my dream truck and came home to Utah. We pulled it home on a trailer because the previous owner (Rick) said it had been sitting for a few years in his garage. Rick built the truck for the track and the engine and transmission only had 500 miles on them. I purchased the truck for $7000 dollars which I feel was a steal. There is a little rust starting to show on the bottoms of the doors and the passenger floor brace. The truck fired right up and runs like a champ. This truck will smoke the tires right off the rims if I am not careful. The transmission shifts way hard and about throws my poor wifes head through the back window, but remember it is a work in progress. I wanted to start a build thread so I can share my passion with everyone on this board. Heres a little info about the truck I have found out:
1970 Chevrolet C10 2WD SWB (All this information is from the previous owner who put a lot of time and money into the truck before I bought it.) Previous owners: Cape Gerardo MO, Wentzville MO, Lake Saint Louis MO, and Bellevue NE Engine: Engine Block Casting Number: 3970010 (1968-1979) 2&4 Bolt Main Truck Hi-perf The engine was carefully engineered to be a street-able 375-400 hp The engine was blueprinted and balanced with 9.5:1 compression. The heads were opened up to 2.02 intakes 1.86 exhaust with hard seats installed so that pump fuel can be run. Heads were ported and smoothed. The engine had a high lift cam installed (5/8 race cam) 1:1.5 roller rocker arms installed. The timing chain is a double roller. The oil and fuel pump is a stock Z-28 spec unit. Intake is a Holley 750 double pumper vacuum secondary’s. Long Tube Headers New heavy duty 4 core radiator Transmission: TH 400 Rebuilt 3,500 RPM Stall Converter Transm (shift kit added) Suspension/Drive: Springs were replaced with stock ones. A frame bushings, Ball Joints and tie rod ends were all replaced. 12 Bolt Rear End with stock Posi Track New U-Joints Balance Drive Shaft Brakes: Brake cylinders were rebuilt Rotors were turned and new brake shoes installed. Master cylinder was replaced Used power booster was added to give the truck power brakes. Body: Rocker panels replaced Moldings removed and holes filled Stake pockets welded up Body stripped to bare metal All body filler removed Truck was primed and painted with 8 coats of enamel black 4 coats were buffed off to create a clear coat shine Bed was sprayed with enamel clear coat Interior and under hood was painted New front bumper New rear bumper Interior: New door moldings New windshield New cardboard tank cover New glove box cardboard New duct work New rubber floor mat New dash pad Seat was recovered |
12-16-2010, 08:55 PM | #2 |
Re: Project black-ops
nice truck ,great story its always good to drag that truck home for the first time
12-16-2010, 08:55 PM | #3 |
C-10 Club Member
Looks like a nice solid truck with some extra goodies....
What are the plans? BTW...I had to drive to utah to find my solid truck...haha
1969 Short Fleet 350/SM465 4.5/6.5 ECE drop 20" Raceline Wheels 1998 2dr Tahoe 5/7 drop 20"/22" Coys-sold Build thread...http://67-72chevytrucks.com/vboard/s...d.php?t=401910 |
12-16-2010, 09:37 PM | #4 |
Cole,
Funny you found my thread! I have read yours from start to finish. I grew up in Kanab, Utah, very close to where you found your truck. I just ordered my front disc brake kit from ECE. I stayed with 6 lugs just like you did. I also ordered the 4/6 drop kit from ECE. I have my new wheels in my garage also, but I am waiting until spring to put my tires on. I went with the Summit Racing Legend 6 classic Torq Thrust look. I am planning on pulling the motor this year and re-painting it chevy orange, with new Pro Form valve covers. I am also going to dress it up with some chrome here and there. The exhaust needs done so I will throw on some Sanderson CC10 headers along with a full magnaflow dual exhaust. I need to dress up the engine bay a little while the motor is out. I bought the rust converter kit from Eastwood, along with some of their black frame paint so thats in my plans for spring also. I will eventually put new interior in the truck. I have plans to keep it black, but put a new paint job on it. It looks great, but it has no clear coat and I want to make it my own. I have considered going two-tone, but the last owner spent a lot of time smoothing up the factory trim holes and stake pockets. It has lots of small cosmetic stuff that needs done, but overall its a clean truck. Keep in touch and I will follow your thread as well. You and Nate have done a great job in detailing your work. |
12-16-2010, 09:41 PM | #5 |
I can only hope mine looks that good when I am done. LOL Very nice truck to start with.
70 Chevy SWB Fleet Project. 06 Lancer Evolution MR SE, stupid fast! 03 Ford f-250 crew cab, 6spd, diesel 56 ford f100 project My build thread. http://67-72chevytrucks.com/vboard/s...d.php?t=426739 |
12-16-2010, 10:09 PM | #6 |
VA72C10
very nice start! awesome truck!
Looking for a 67-72 swb or blazer project in or around VA. |
12-19-2010, 10:22 PM | #7 |
Tot Roddin'
Diggin' the project and the plan you have for it.
My FIL installed a set of the Sanderson Headers on his '69 and they look and perform great! Be sure to keep us posted on your progress.
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
01-11-2011, 10:35 AM | #8 |
I finally got around to pulling my truck in the shop and putting on my ECE disc brake upgrade, and the 4/6 drop kit. I could not believe how good it turned out. ECE makes very high quality parts, and I will do business with them every chance I get. The kit went on pretty easy, with the help of my good buddy Jeremy. I will not post too many pictures of the install since you can go to project blankslate like I did for helpful tips. I will have to do my exhaust sooner than expected, because my long tube headers are about 2" from touching the ground. I sent back my 17" wheels and upgraded to the 20's. I hope to have them on in the spring. My truck does not see any winter driving here because the salt would take a toll pretty fast. I also painted all the brake components with Eastwood Disc Brake Gray paint. Heres a few before and after pics.
01-11-2011, 11:12 AM | #9 |
VA72C10
looking good!!!
01-11-2011, 03:58 PM | #10 |
I have a set of stock springs out of this truck I would sell if somebody is interested. They were replaced when the truck was built about 10 years ago and seem to be in great shape.
01-11-2011, 04:03 PM | #11 |
Tot Roddin'
Much better...
03-26-2011, 08:08 PM | #12 |
I finally put the new wheels and tires on this weekend. I went with TOYO PROXES ST II tires. 295/40/20 on the back, and 255/40/20 on the front. I wanted to keep a classic look, and the six lug, so I went with the American Racing AR 604 Torq Thrust wheels. I could not be happier with the look of the truck. The disc brakes make a big difference in stopping power also.
03-26-2011, 08:21 PM | #13 |
'67 C-10 LWB Driver
looks great!! sweet ride!
'67 C-10 LWB - My Build Thread '67 C-20 LWB - My Donor/ Parts truck - SOLD! '92 GMC SAFARI VAN - My Parts Go Getter '06 KIA SPORTAGE EX - My Commuter "All of this crap better make a truck!" - my wife Sue. Proud U.S.M.C. Dad! |
03-26-2011, 08:23 PM | #14 |
VA72C10
Looks awesome! Love the torque thrust ST's (6 lug) Had a set myself but never got around to finishing the project so I sold them.
Yours is only the second 67-72 and first 70 I've seen with them on!
04-11-2011, 04:01 PM | #15 | |
C-10 Club Member
Hard to go wrong with that drop/wheel combo. Keep up the good work I know I have about a million things I want to do to the truck and most are hindered by my lack of $$$...lol
04-12-2011, 10:26 PM | #16 |
We are building a house so my truck might be on the back burner for awhile. I want to get my headers and exhaust on soon, but we will see how the house goes. Even when you start with a clean truck it can nickle and dime you to death.
04-15-2011, 11:10 PM | #17 |
Decker looks good in his future truck!
05-15-2011, 09:37 PM | #18 |
Hey Dan, Cute kid! Here's a few pics of my engine compartment that you requested. I really just tried to keep things clean and simple, and tried to hide as many wires as I could. Good luck on your truck!
06-01-2011, 06:45 PM | #19 |
BigSnookMaster,
I love your engine bay. Thanks for all the ideas. I am still in the process of tearing things down. It seems like I just keep finding more stuff to buy and more parts I want to replace.
BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=436046 |
06-01-2011, 07:04 PM | #20 |
Here is some updated pictures of my engine bay makeover. We are painting the engine with POR 15 Chevy Orange Enamel. I am in the process of installing a 700R4 as well. Here is the list of new parts going on the truck:
PROFORM ORANGE SLANT EDGE VALVE COVERS TAYLOR SPIRO-PRO IGNITION WIRES HOT ORANGE EDLEBROCK PRO-FLO AIR CLEANER CHROME LOGO FRAM AIR HOG AIR FILTER SANDERSON-CC10 HEADERS CHROME PULLEY’S BILLET DIP STICKS MADE FOR YOU PRODUCTS VERTICAL WIRE LOOM KIT 700R4 TRANSMISSION W/ COAN 3500 STALL TCI 700R4 TV CABLE CORRECTOR KIT KUGEL KOMPONENTS SHIFT LINKAGE EARLY CLASSIC ENTERPRISES TRANSMISSION CROSSMEMBER FUTURE: MAGNAFLOW DUAL EXHAUST (If my wife lets me)
06-02-2011, 02:17 PM | #21 |
C-10 Club Member
nice....your really going for it!!
06-13-2011, 07:05 PM | #22 |
Finally finished up the engine this weekend. I tried spraying plastikote chevy orange on the engine and it was like orange tinted clear coat. I ended up taking the paint off with aircraft stripper. I think I might have lost some of my skin in the process. I decided to go with POR 15 brush on paint and it turned out really nice. I installed the 700R4 and now I have to wait until I can save enough money to put on my magnaflow exhaust. I have a guy coming to the house tonight to measure my driveline so I can cut it and install the new yoke. I added a ton of new parts I have collected over the past year, and I couldn't be happier how it turned out. Here is some pics:
06-13-2011, 08:12 PM | #23 |
VA72C10
Super nice!!!
06-14-2011, 06:48 AM | #24 |
Wow motor looks great
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
06-14-2011, 07:44 PM | #25 |
Tot Roddin'
Beau-tiful!!!!
That motor looks amazing.
Tags |
1970, black, c10, fleetside, swb |
