Shlong Bed Club
Pipe C Notch
stupid question, but does anyone have pics of a 60-66 with rear bags and just a pipe notch? (preferably aired out)
"If it ain't broke, hit it with a hammer, then fix it.." ![]() |
Re: Pipe Notch
Heres my pipe notch welded in
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
Re: Pipe Notch
I did a search, but does anyone have a link for a good 'how to" on the pipe notch?
Re: Pipe Notch
I've always just unbolted the rear hangers or coils and let the truck down on the axle to get my mark. Easiest way for me to figure out where to cut. Then just measure how much farther you have to go to reach the lowest point, laid out or wherever and cut ur piece of pipe to give you that much notch. Trace it on the frame, cut it out and weld it. It goes pretty quick that way. Has for me anyway.
Re: Pipe Notch
I thought about notching my frame with the simple cut out and welding in of a piece of pipe until I ran the numbers to see how it would effect the strength of the frame. It is really a dramatic change.
Notching a frame in the method shown above reduces the rear frame strength (behind the axle) by about 75%. ![]() Now, that being said, depending on how you end up using your truck that may not be a big deal to you: On a truck arm design frame, the coil springs are ahead of the rear axle, so the suspension load on the frame is negligibly affected by the c-notch.The above drastic strength reduction is the reason why purchased kits have heavy structural steel members that are added to the existing frame rail. I am not preaching, do what you like, I just wanted to make sure you knew what these changes do to the strength of the frame, behind the axle. |
Resistance is Futile
Re: Pipe Notch
lakeroadster; with out going into a complete engineering seminar, how do you make that calculation? Just curious.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
#7 | |
Re: Pipe Notch
Also.... What if a pipe notch similar to what is pictured above is boxed on the inside? What effect would that have to restore that strength?
#8 | |||
Re: Pipe Notch
The change in height radically effects strength because in the equation the height is exponentially to the 3rd power. Height is the major determining factor, which makes sense, but changing it effects strength to the 3rd power which derates its capacity really quick. For a stock frame b = 3Crunching the numbers, S = 6.22 in^4 With a C-notch you have changed the height, d = 2.375, S = 1.30 in^4 So the notched frame has about 20% of the strength of the stock frame. That is the reason why purchased kits have heavy structural steel members that are added to the existing frame rail. Quote:
Modify a stock channel type frame, making it a tube frame: Quote:
As far as the gas tank goes, it's not so much the weight as it is the moment arm. A 300 lbs gas tank mounted behing the rear axle on a long bed truck adds a lot of moment. Assume 3 ft to the center of gravity: 3 ft x 300 lbs = 900 ft-lbs. Like I said previously I am not preaching, do what you like, I just wanted to make sure you knew what these changes do to the strength of the frame, behind the axle. Just trying to help.... don't shoot the messenger. ![]() ![]() |
Re: Pipe Notch
Ok, thanks John.........that's cool!! Now my question is what is the difference from boxing to '' heavy structural steel members that are added to the existing frame rail.''?
Isnt that just the same as boxing on the outside of the frame? And, do the bolt holes reduce the section modulus of the frame?
#10 | ||
Re: Pipe Notch
I did consider the strength impact when reducing the height of my frame channel. I figured the use of the heavier walled material (.250" steel plate c-notch) w/boxing it in (using .1875" steel plate) would restore the majority of the strength. Seeing those numbers crunched, I'm going to re-evaluate/scrutinize my set-up & consider the possibility of plating the outer wall of my frame for additional assurance.
#11 | |
Re: Pipe Notch
Yep, from a "calculation standpoint" adding the structural steel member is about the same as welding in a boxing plate. Most of the bolt on kits use a steel plate that is considerably thicker than the stock truck frame thickness. That helps but I still would like to run the numbers on one of the kits to see if it is as strong as the original uncut frame when all is said and done. As for the bolt holes, they don't effect the strength very much as long as they are spaced away from each other. I took a little time this morning and made a solid model using Inventor Cad software. (See attachments below) First I made a model of a stock frame rail.Using FEA is more realistic than the simple channel and tube calculations that were discussed in the previous posts because it looks at how all the parts work together as a system. And the cool thing about this type of analysis is it gives you a warm fuzzy feeling about how different modifications effect the strength of a part. Kind of neat, don't ya think? |
#12 | |
Re: Pipe Notch
But regular bolt holes, lets say 9/16" dia. don't effect the structure much. I plugged in (4) of them and it reduced the stock frame strength by about 10%. Normally though if there are bolt holes, there is some structure being bolted to the frame, and that structure will likely stiffen things back up... depending on how strong the structure is. So using the re-pad concept I added a half re-pad to the c-notched frame that had the boxing plate and it is as good as the stock frame. Use a 3/8" thick boxing plate, a 3/8" thick 7" dia. half re-pad and 4" 0.237 wall pipe. |
Shlong Bed Club
Re: Pipe Notch
is this workable? sorry its so crude. and yes, the extra 1/4'' wall pipe is used above the frame and plated on both sides with 3/16" steel.
#14 | |
Re: Pipe Notch
With the 6 inch pipe notch the frame has about 17% of the original frame strength. Modified in the configuration you sketched out, with the remaining 6 inch pipe on top and boxing plates, does little to strengthen the frame. This configuration has about 22% of the original frame strength. The frame still needs more section strength. I took the liberty of proposing an alternate design. This has pieces made from 3/16" plate and this version is stronger than the the original frame. Basically it is a box structure that extends 2" above the frame, 12" long and ends are angled at 45 degrees and they are also boxed in. |
#15 |
Re: Pipe Notch
No problem, glad I could help. Make sure to box the inside of the frame with the 3/16" also.
#16 |
Re: Pipe Notch
Scoti sent me some data on the c-notch he did on his frame. This one is a bit tricky. The notch isn't an arch, it's kind of squared off at the top. The tight radius at the bend makes for high stresses at the bend line.
The frame itself is strong since Scoti added a boxing plate and the materials used for the arch is 1/4" thick. Take a look at the attachment below of the stock frame and of Scoti's frame. Take note of the colors and the corresponding scale at the left hand side. Notice that most of the areas have a safety factor of between 1 and 5, which is good when comparing to the stock frame. But even if we add material to the top to make the overall frame section stronger that darn tight radius is the "hot spot". This is called a stress-riser in engineering lingo. And the kicker is, depending on how much the frame is loaded, this hot spot may never rare it's ugly head. But this spot is likely where a problem would occur in an overload condition. I will "noodle" over this a bit more... maybe add a post later with some updates pending any good ideas ya'll might have. |
#17 |
Re: Pipe Notch
Scoti,
How is you overhead welding abilities? If you were to add a piece of 1/2" solid round bar to the notch as shown in the attachment and then grind the welds such that they feather into the notch it helps a lot. Plus I would suggest that you grind a radius on the notched edges as shown in the attachment, that also helps. As a rule, radius edges when you can, that always helps reduce stresses. The upper truss is 10-1/2" overall length, is boxed in, made from 3/16" plate, and ends are angled 45 degrees. I hope this helps. |
#18 | |
Re: Pipe Notch
#19 |
Re: Pipe Notch
1-1/2" high on the upper truss... see attached.
Be sure and let me know how this works out for ya. |
#20 | |
Re: Pipe Notch
#21 |
Re: Pipe Notch
There was previous discussion here about commercially available c-notches.
From what I have seen Beltech has a very good notch kit, but they don't offer them for our 60-66 trucks. Take a look at the pictures below and the followig link: http://www.belltech.com/trucks.php Basically they have a heavy formed c-channel with a welded notch. Then this bolts through the frame and there is a heavy backing plate. This essentially triples the wall thickness of the frame. Interesting. If any body has one of these I would be interested in knowing how thick these components are. |
#22 |
Re: Pipe Notch
A couple things to keep in mind:
The base line I used was my stock c10 frame geometry above the rear axle. I believe this geometry is also the same for a C20. So I created a model in cad and loaded it using FEA to get a safety factor of a stock non-modified frame. Then I modified the model based on scot's c-notch dimensions to determine the safety factor of his frame as modified. So all we are doing is comparing a stock frame to a modified frame. The stock frame is very very strong. Also be aware that modifications to a long bed truck puts more stress on the c-notch area.. Longer lever arm bending this area. But everything relates back to how you use your truck. For me I want any modification I make to be at least as strong as it was when the truck left the factory. Might be overkill, but that is my baseline. As for the "kit" notch, see posts #89 and #90 above, I re-ran the model assuming formed kit channels made out of 1/4" plates and the 1/4" backing plate. The FEA says this "kit" it is still a 40% reduction of frame strength. From an "Engineering" standpoint of beam analysis the height of the beam is the driving factor of the strength. Thickness matters, but not nearly as much as vertical web height. If you want the frame to be as strong as stock and you want a notch deeper than the 2" one shown in thread #35 there is simply no substitute for adding some sort of truss above the frame, or replacing the frame section with another structural member that has the same section height as the original frame. Whenever someone starts talking about a deep c-notch and state that just by adding thicker plates to the sides of the frame rails this makes the frame stronger than it was in its original condition, yet they are and not adding vertical height, they do not understand beam analysis. |
#23 |
Happy to be here
![]() Join Date: Mar 2000
Re: Pipe C Notch
Edited version for FAQ. Original version located here- LINK
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 12-27-2010 at 06:40 PM. |
#24 |
Garage wrench
Re: Pipe C Notch
I know this is kind of off topic, but how does a step-notch factor into this? Would they not suffer from decreased strength because they're still the same section (frame) height through the notch?
-Adam 90 V1500 GMC Suburban 350/700R4/NP241..... 01 Saturn SL1 stock DD..... Last edited by SBTork; 12-27-2010 at 08:38 PM. |
#25 |
Re: Pipe C Notch
That's what you want... the same section height to maintain the strength. Plus the step-notch is fully boxed.
