01-06-2011, 11:17 AM | #1 |
motor exploder
Rollcage pics anyone?
Hey guys, I'm toying with the idea of putting a cage in my '69 C10, but I don't plan to run tubes out the back of the cab to the rear frame rails. I would love to see some pics of what you guys have done and your thoughts about where/how to attach this to the frame. I do have a welder (Hobart Ironman 210) and the tools to cut/notch all the tubing, but I don't know if I should farm this out or try it myself. My primary motivation is really to stiffen things up for cornering, as this will be a 'Pro Touring' type build, but it will see some 1/4 mile action too. The motor and trans is in my sig, and I will be putting out around 600hp- so when I things dialed in, I will be running fast enough to need a cage anyway.
Thanks in advance for the pics, input and advice!
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
01-06-2011, 11:40 AM | #2 |
It's Better With Nitro
Re: Rollcage pics anyone?
If you are going to install a cage in your truck, I would strongly recommend running at least a pair of rearward bars off of the main hoop. Depending on how fast/quick you end up going, the cage will not certify without those rearward structures. When I worked at Gale Banks, we built a couple of trucks that placed the rearward bars through the window, so there were no holes through the cab structure. The windows were Lexan/polycarbonate, so it was easy to notch or cut holes. This photo is of the S-10/15 that Don Ness built that uses the same concept:
Also, if this is your first roll cage build, I would work with a professional chassis builder, or contract it out.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
01-06-2011, 05:02 PM | #3 |
I agree w/vin63, you should run them out the back now. It's going to be easier now rather than later plus it sounds like you already know you'll need them later anyways.
I installed my cage after the fact, as I was building my '70 as a driver and I had already painted the inside of the cab, jambs, firewall etc..and started assembly...then decided to change everything and go do a little racing with it. Here are some pics of mine. Made it a little tougher because of the finished paint, but I think it will work.
1970 c-10 short/step box morphing into street/strip 1967 RS/SS convertible Camaro 1932 Henry Ford steel 5 window coupe highboy hotrod 1931 full fendered model A sedan AV8 traditional hotrod. 1934 Ford 5 window coupe and a (pile-of-parts) 1929 Model A coupe, plus our "normal" people vehicles. |
01-06-2011, 05:34 PM | #4 |
Doesn't Marv have his rear bars tucked out of sight...like below the window? I saw one other truck done something like that, but it was a full tube chassis truck.
Anybody got any pics or details about doing the sidebars where they connect in the front floor?
1982 Silverado - SBE, cleaned up GM heads, small cam, TH350, 850 Demon, 4.56 gears, and caltracs. Best time so far 11.8@XXXMPH |
01-06-2011, 07:57 PM | #5 |
sorry wrong button.
01-06-2011, 11:00 PM | #6 |
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
01-07-2011, 11:26 AM | #7 |
motor exploder
Thanks for the closeup and detailed pics. That's the kind of stuff I needed to see,like where/how to attach it to the frame.
Ratteon - I'm kind of in the same situation as you, I got into my build and realized I needed to make some changes. I haven't paintedmy cab yet, but I have painted the frame already, which now I'm glad I painted instead of powdercoated, so I can fix it after welding the cage it. As for the rearward bars, I know they do offer a lot more rigidity and that's what I need, but man I really wanted kind of a subdued look to my truck (eventhough I have 335 rear tires out back!), and those bars poking out the back glass blow that out of the water. Maybe I can kind of hide them like team39763 said, but I don't know how that would affect their legality at the drag strip.
01-08-2011, 04:55 AM | #8 |
as far as i know for the cage to be legal the rear bars have to be at the highest point of the main loop. and the main loop has to be all one piece.
01-08-2011, 11:38 AM | #9 | |
Registered Truck Offender
Yes I do, BUT,, that's also why I have to slow it down to 11.50 and slower. IT AIN'T NHRA LEGAL. You can see the rear bars going through the bed, into the back brace, instead of the main hoop, in this picture The ROLL BAR OR A CAGE cage MUST have the rear supports, the they MUST attach within 5" of the top of the main hoop, THE MAIN HOOP must be NO MORE THAN 6" above the drivers helmet. You can put a secondary bar across the uprights 5" below the main hoop to attach to, OR you can bend the rear supports to come inside the cab (through the window) and then turn up the 6" to meet the main hoop. Option is a funny car cage like Kevin's, I think you can get away without the rearward supports with that type of structure. But even then you will typically see the rear supports through the cab to make the structure rigid. At that level aesthetics are less important than safety! Of all the welders, grinders, angle finders... the most important tool in building a cage or a bar is the RULE BOOK. Seriously,, have the rule book in your left hand when your cutting tubing stock with the right. That NHRA rule book is a slippery slope.
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. Last edited by Marv D; 01-08-2011 at 11:39 AM. |
01-09-2011, 10:44 AM | #10 |
Hey Marv, will yours pass for just test'n'tune sessions?
1982 Silverado - SBE, cleaned up GM heads, small cam, TH350, 850 Demon, 4.56 gears, and caltracs. Best time so far 11.8@XXXMPH Last edited by team39763; 01-09-2011 at 10:44 AM. |
01-09-2011, 12:02 PM | #11 |
Absolutely not for anything quicker than 11.50 . It's a issue I fought with NHRA and was able to win over the techs here in Az with help from Division 7 senior tech. The rule states all equipment must pass tech. In short if you 'HAVE' a piece of equipment, it must pass tech, be current, etc.
An example we put a set of expired 3" belts in my son's 14 second camaro. Tech would not pass him because of the expired belts. Now mind you a well installed, but expired 3" harness (and 3 years old) is a heck of a lot better and safer than the stock 1985 GM belts being 20 years old. The rule just did not make sence. But the techs stance was "ALL" equipment must pass inspection. And he was right! They didn't say 'IF IT IS REQUIRED" it just says it must pass. An expired piece can't pass because it's expired so,, FAIL. Same issue with this bar. If I run 11.50 and slower the bar isn't required. I called the senior tech for Division 7 in Glendoria and there is some loophole that 'optional equipment' not intended for competition does not have to be removed as long as all 'reguired' equipment is in place and current for the ET ran. Mike pointed out the roll bar on the Cobra kit cars, the Miada and a bunch of other 2-seaters that had a decroative roll bar. This was back before NHRA moved the roll bar rul;e from 11.99 to 11.49 noting that most of these cars would barely break 14's let alone 11's. So I guess the answer to what your asking is not a blanket NO,, just NO to anything quicker than 11.50. Slower and it's 'decroative'
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. Last edited by Marv D; 01-09-2011 at 12:05 PM. |
01-09-2011, 09:08 PM | #12 |
See below
01-09-2011, 09:08 PM | #13 |
I have pondered the idea of the funny car cage deal ! I gettin too old to bend that much when I get in and out . My opinion is the rear strut bars add alot of structural integrity to the truck . I can put a jack under one framerail and jack the truck up and the other frame rail doesnt sag hardly any at all. You can look any of my wheels up pics and my truck doesnt twist .
NHRA Super Street 469C It only runs 10.90 at 156 mph |
01-09-2011, 09:40 PM | #14 |
01-09-2011, 09:41 PM | #15 |
01-09-2011, 09:43 PM | #16 |
01-09-2011, 09:45 PM | #17 |
01-10-2011, 11:53 PM | #18 |
Pics of roll cage. Main hoop is a S&W and rest of cage was custom bent.Also has a removable driver swing out.
'72 SWB 534" 10.5:1 W/GMPP 290CC Ovals, Wilson Pro flow 2 stage,Transking man. rev T400 W/Trans brake,Moser Dana 60 w/4.30,,Indigo blue W/ghost flames,shaved,smoothed and low,9.40's @ 138 |
01-11-2011, 12:03 AM | #19 |
Nice looking setup.
01-11-2011, 12:07 AM | #20 |
motor exploder
Thanks for all the awesome pics guys - eventhough I wanted to try and keep a subdued look, it looks like I'll have to just bite the bullet and run the bars through the back glass. From a rigidity standpoint, I know its the best thing to do and from a safety and rulebook point I HAVE to do it. Now I just have to find someone around the greater Little Rock area to do it. Since I'm currently building my truck now, when would be the best time to have the cage built? After the cab is on but well before paint and interior? What about cutting the glass for the rear supports? Should I use Lexan instead?
Sorry if some of these questions seem stupid, but this is all new to me.
01-13-2011, 11:12 AM | #21 |
You can't cut a hole in that glass. Lexan.
1987 2 ton 1982 250/TH350 beater in progress Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping Plus a mess o' tractors |
01-14-2011, 10:23 AM | #22 |
Check the local glass/window store for Lexan, you'll probably get the best deal on it. I used to order mine through Ebay and my local glass/window shop beat the Ebay price by 50%.
01-21-2011, 11:58 PM | #23 |
anyguys got more pics on how they are connecting the main hoop to the frame?
01-22-2011, 07:54 AM | #24 |
Look at the diagonal bar that goes behind the seat in LJ534's pics . Thats the one you need to go to the frame with . The four corners of the cage just need stitch welded and bolted plates on the floor of the cab .(if you still have the steel floor) and of coarse you need solid cab mounts .
01-22-2011, 11:39 AM | #25 |
Regan,, I surely wouldn't argue with someone of your calibure, and you see the toughest tech in NHRA so I'm 'asking' here, not arguing. The way I read the rules was that IF the vehcle has a 'frame' the main hoop and front down bars must be attached to the frame, not the floor (with plates) via outriggers of some sort. I did much the same as rattelon (and is probably the only thing I thought was 'legal' at all about my cage!!)
(darnit, can't link the picture from above) Are you saying the main hoop and front down bars of the cage don't have to attach to the 'frame'? That would be Soooo much easier!
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. Last edited by Marv D; 01-22-2011 at 11:57 AM. |
Tags |
rollcage |
