01-16-2011, 05:31 AM | #1 |
69' Chevy Stepside
Air Intake, what are you guys using on your swaps?
Well I'm sure theres a couple other threads about this but I just can't seem to figure out what air intake would work/look good under the hood of my truck. I've always just had a 90 degree tube with the MAF and air filter off the end of it. First it doesn't look good and second the super hot air from the Efans blows right into it. Not good for the IAT's I'm sure.
Here's a pic of the intake right now, I was think of running a intake tube with a box on the end over to the drivers side behind the core support.
-Matthew -69' Chevy Custom/10 Shortbed Stepside 2WD "Copperhead" - Restored, 6.0L LQ9 Built. L92 Heads and LS3 Intake with Comp Cam 223/231 .610/.617 112 LSA, 4L60E with Shift Kit and Circle-D 3200 Stall Converter ~Build Thread -1957 Chevy BelAir 2 Door Post Sedan, Full Frame off Restoration done myself - 6.0L with T56 six speed -1957 Chevy BelAir 2 Door Post Sedan - Nearly rust free AK car, Project in the waiting -2003' Chevy Silverado SS AWD 6.0L! - Daily Driver Last edited by matthew20061; 01-16-2011 at 05:32 AM. |
01-16-2011, 05:46 AM | #2 |
Re: Air Intake, what are you guys using on your swaps?
Great looking engine bay!!! I'm just starting on mine and have a near identical setup in mind but was going to use some black 4" drain pipe, the PVC type not the flexi garbage, and put it over to the corner like you said. I was thinking of cutting some kind of hole in the core support out of sight and behind the headlight sort of. Not to poke the filter into but just so it can get direct cool airflow. Damn your engine looks nice man
1964 C10 Shortened Shortbed Cammed LQ9 P&P 1967 C10 Trophy Truck BB 438 (soon to be worked on again) |
01-16-2011, 06:09 AM | #3 |
TruckincrazY
Hmm, I actually liked yours or one with just the filter. I didn't really think about the heat issue though.
My build thread - '84 2wd w/ a 6.0 swap http://67-72chevytrucks.com/vboard/s...d.php?t=433595 |
01-16-2011, 06:14 AM | #4 |
69' Chevy Stepside
Well its not too bad but I just don't like the angle it has to sit at because it hits the belt tensioner if not tipped up at that angle and the heat issues.
-Matthew -69' Chevy Custom/10 Shortbed Stepside 2WD "Copperhead" - Restored, 6.0L LQ9 Built. L92 Heads and LS3 Intake with Comp Cam 223/231 .610/.617 112 LSA, 4L60E with Shift Kit and Circle-D 3200 Stall Converter ~Build Thread -1957 Chevy BelAir 2 Door Post Sedan, Full Frame off Restoration done myself - 6.0L with T56 six speed -1957 Chevy BelAir 2 Door Post Sedan - Nearly rust free AK car, Project in the waiting -2003' Chevy Silverado SS AWD 6.0L! - Daily Driver |
01-16-2011, 06:19 AM | #5 | |
69' Chevy Stepside
01-16-2011, 05:44 PM | #6 |
69' Chevy Stepside
So anyone have any pictures of there intakes? I know there has to be some...
01-16-2011, 09:47 PM | #7 |
This one is a Spectra kit I got from Pep Boys. It is P# 9900. I took the straight piece and flipped it backwards (from its normal install position) and then cut off the mount to make it bolt to the radiator hold-down bracket.
67 5.3L Build |
01-16-2011, 10:42 PM | #8 |
Addicted to Rust
I used the 9900 Spectre also, but moved the batt to the opposite side.
See it here it is a later truck how ever. http://67-72chevytrucks.com/vboard/s...d.php?t=421589
Current trucks: (48 GMC100 320 inliner) Gone (48 Suburban in pieces) Sold 87 GMC CCSB 5.3 4l60E Daily Driver ECTA National record holder XO/PP We never really grow up, we just learn how to act in public. |
01-17-2011, 01:17 AM | #9 |
69' Chevy Stepside
I like the looks of that, epically because I just checked with the O'Rilleys store and they've got one. might pic that up tomorrow!
01-17-2011, 01:25 AM | #10 |
I like that too. If I hadn't already started on mine I would have probably gotten it! Looks sweet!
01-17-2011, 09:28 AM | #11 |
Here's mine
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap |
01-17-2011, 11:54 AM | #12 |
TruckincrazY
That's another one I like, do you know what the part number is for that?
01-17-2011, 11:58 AM | #13 | |
NOTE: I am running Speed Density, no MAF. the MAF that came with this junk yard van motor was about 5-6" long so it would not fit between TB and radiator. probably have better chance with a 'regular' MAF but I like the SD stuff, one less sensor to mess up.
01-18-2011, 12:23 AM | #14 | |
BMW & ASE Master Certified
clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
01-18-2011, 12:25 PM | #15 | |
67 5.3L Build |
01-19-2011, 12:32 AM | #16 |
1965 C10 SWB Fleet Two owner LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880 |
01-19-2011, 12:34 AM | #17 | |
01-19-2011, 02:35 AM | #18 |
69' Chevy Stepside
Wow that's quite the air cleaner, pretty classic!
02-05-2011, 06:23 AM | #19 |
Hers mine. 2 90 deg big truck steel elbows welded together. Used rubber unions from intakeelbows.com with band clamps from same. Cut hole in core support next to headlight to let in cool air. Battery moved to drivers side.
02-08-2019, 02:48 PM | #20 |
Hey there. Just ran across your thread on your cold air intake and was wondering what top rad hose you used? I'm also using factory 4 core
02-08-2019, 10:16 PM | #21 |
That's gonna depend alot on what truck,radiator,and engine you have...more Info please
02-11-2019, 07:08 PM | #22 |
Here's mine in a '49 GMC
The other side Laid out on the shop floor. Still a little tight with a MAF, but I may go speed/density so it won't matter anyway |
02-12-2019, 09:55 AM | #23 |
I used the original LS one for a while but noticed the baffled silencers hit the fan shroud and kicked the whole thing up a little.
So I found this cheap kit on eBay for $49 an decided to use just the main tube and rubber couplers. I like the stock air box better than the open filter so I merged the two together. Clears the mechanical fan as well. Happy with the results but do not like the shiney pipe. Will probably have powder coated satin black soon.
Jay Gesner Atlanta, GA 1985 C10 Long Bed 4X2 LS 5.3, 4L60E Father/Daughter Project Last edited by Wgesnerjr; 02-24-2019 at 12:53 PM. |
02-12-2019, 09:59 AM | #24 |
I have also started modifying the stock one. Cut off the baffled silencers and started fiberglassing up the holes.
Might go back to this one if it turns out good enough.
Jay Gesner Atlanta, GA 1985 C10 Long Bed 4X2 LS 5.3, 4L60E Father/Daughter Project |
02-12-2019, 10:59 AM | #25 |
Is that a kit for a Silverado? How tight is that elbow? I had to remove my upper shroud because there is not enough room with the factory setup. My engine is slid forward to allow room for the A/C in the lower position. D.D sliders almost all the way forward.
