Old 01-18-2011, 10:19 PM   #1
Tuned55
Tuned55's Avatar
Building this C5 5 Window for my Wife
I started this project in November. I've had this cab for about 10 years and always thought I would build it just after I finished my 55 BelAir. Didn't realize it would be this long to get to it.
I started with a 98 C5 Vette and modified the frame rail width of the Vette to fit under the AD cab.
http://pic60.picturetrail.com/VOL172.../394679247.jpg
Mocking up for the bed
Cell Phone pic, One bed Side tacked on
I cut down a tailgate I had from a 67. I made the stake pockets similat to stack with just a little more detail
The dash was pretty beat up so I tried my skills and made this one
That's about it. The wheelbase is about 10'' shorter that a stock short bed AD
. I'll be keeping the drivetrain mostly stock. Wife really dosen't want a HotRod. Just a "Cute" old truck.
Bruce
So.Utah
Build Pics http://www.picturetrail.com/tuned55
Tuned55 is offline   Reply With Quote
Old 01-18-2011, 10:22 PM   #2
Kabwe
Certified Car Nut
Kabwe's Avatar
Re: Building this C5 5 Window for my Wife
Its looking great.
Kabwe is offline   Reply With Quote
Old 01-18-2011, 11:15 PM   #3
Wheelie
Cool, Nice restomod!
Wheelie is offline   Reply With Quote
Old 01-19-2011, 08:29 AM   #4
duwem
duwem's Avatar
Could you give more details on what you modified to make that tail gate work?
What latchs and straps are you using. Looks good on there!
duwem is offline   Reply With Quote
Old 01-19-2011, 07:09 PM   #5
Tuned55
Tuned55's Avatar
Thanks! vettes make GREAT parts cars
Bruce
So.Utah
Old 01-19-2011, 07:15 PM   #6
Kim57
Kim57's Avatar
This is a really cool build.
Kim
Kim57 is offline   Reply With Quote
Old 01-19-2011, 07:16 PM   #7
Tuned55
Tuned55's Avatar
Well lets see. I narrowed it about 1 1/4''. I used the plug type pivet hinge from the 67. I only used the vertical ribe bottom and inserted it into the gate. I'll used some small square tubing to stiffen up the xertical sided. for latches I have two from the Vette hatch I plan on useing. Their spring loaded when closed. Remind me to post a pic when there are done.
I also plan on using the vette gas strut for the gate if it works out
Bruce
So.Utah
Old 01-19-2011, 08:11 PM   #8
Pop's C-10
Pop's C-10's Avatar
nice
Pop's C-10 is offline   Reply With Quote
Old 01-19-2011, 10:55 PM   #9
pinecrest
pinecrest's Avatar
Looking good, but wasn't it tempting to just play with the 'vette? :-) Or was it hot. haha.
pinecrest is offline   Reply With Quote
Old 01-19-2011, 11:44 PM   #10
Tuned55
Tuned55's Avatar
Thanks and no. Maybe if it were a ZO6 and definetly if it were a ZR1 but it was just a run of the mill Vette. I've got a red one with a 6 speed and a 3 window I'm doing next for myself. I don't plan on trying to keep it cute looking or running like my wifes.
Bruce
So.Utah
Old 02-07-2011, 01:36 AM   #11
Tuned55
Tuned55's Avatar
It seems I have a lot done on the build since last posting.
Bed is done with the exception of some final welding, grinding and floor
Gas door is mounted and plumbed to tank
http://pic60.picturetrail.com/VOL172.../395023766.jpg
I came up with this to hold the tail gate in open posistion. Stainless steel rods retract into a nylon bushing
Here's a shot of the spring loaded gate latch I made
Bruce
So.Utah
Old 02-07-2011, 01:41 AM   #12
Tuned55
Tuned55's Avatar
I got the seat base made and seats in also
Bruce
So.Utah
Old 02-07-2011, 10:06 AM   #13
Fat Mike
Fat Mike's Avatar
Very nice build. Do you have any picture of how you built your spring loaded gate latch?
Fat Mike is offline   Reply With Quote
Old 02-07-2011, 10:36 AM   #14
JimmyFloyd
Wow. Looks great. Aside from widening the frame, did you have to do anything else to it?
1970 Blazer 350/SM465/205 SOLD! | 1998 Z3
JimmyFloyd is offline   Reply With Quote
Old 02-07-2011, 10:53 AM   #15
no moa
no moa's Avatar
subscribed.
1972 C10 Deluxe.Shortbed. 402/400. A/C, white interior, needs complete restore. Project Red, white and blue. Used to be a Longbed apperently.
http://67-72chevytrucks.com/vboard/s...d.php?t=451950
1971 c10 step 250 3 OTT
1969 c30 TOW-MATER. 307 4 speed, holmes 440 body.
http://67-72chevytrucks.com/vboard/s...d.php?t=451082
2006 CTS-V LS2 6spd.
no moa is offline   Reply With Quote
Old 02-07-2011, 10:53 AM   #16
Kim57
Kim57's Avatar
Looking real nice.
Kim
Old 02-07-2011, 03:20 PM   #17
Tuned55
Tuned55's Avatar
You know I didn't take any pics as I was making it. This is how I made it. I used a piece of SS tube and milled out a J type slot about 1'' from the end. I welded a plug on the end. I then made a rod on the lathe to slid inside that with a smaller dia. to fit inside the spring. Just down from that I tapped a hole and threaded in a a small handle. So, spring goes in first then plunger, than the handle gets screwed. Tack weld it in the gate. Used some persian blue on the end of plunger to mark where to drill the hole in bed side. That's about it. An evening project.
Bruce
So.Utah
Old 02-07-2011, 04:00 PM   #18
VA72C10
VA72C10
VA72C10's Avatar
very nice work....love all the details and it should be a super nice drive!!!
Old 02-07-2011, 04:12 PM   #19
Kabwe
Certified Car Nut
Kabwe's Avatar
You the man tuned55, another great build. Great work.
Old 02-07-2011, 07:35 PM   #20
R.A.D
i'll be watching this one.details and pictures!!!!!!!!!!!!!!!!
R.A.D is offline   Reply With Quote
Old 02-07-2011, 10:37 PM   #21
1lo67
1lo67's Avatar
That's cool man!!!!!!!!!!!!!!!!
1lo67 is offline   Reply With Quote
Old 02-07-2011, 11:33 PM   #22
Tuned55
Tuned55's Avatar
I actually narrowed the width of the frame about 10'' each side. The wheelbase remains stock C5 just over 10'' shorter than an AD short bed. As far as anything else I had to add to the lenght in the rear and shorten the front. The usual stuff like core support. cab and bed mounts. The next one will go much faster
Bruce
So.Utah
Old 02-07-2011, 11:35 PM   #23
Tuned55
Tuned55's Avatar
Thanks for all your kind words and interest!
Bruce
So.Utah
Old 02-08-2011, 08:05 AM   #24
R.A.D
there's always a reason for interest. could it be what your doing is appreciated?
Old 02-10-2011, 10:04 PM   #25
Hart_Rod
Hart_Rod's Avatar
Sweet build!
Hart_Rod is offline   Reply With Quote
