02-05-2011, 03:14 PM | #1 |
Junior Member
No Limit 63-72 Rear Shock Kit
NO LIMIT ENGINEERING
New Rear Shock Kit to fit 1963-72 Chevy Pickups!! "Quote per Rob" - I'm feelin pretty good about this. After dropping another 2" in back, we ran into the same trouble as everyone else. The shock issues. After researching the other kits, and solutions, and thinking about it, we came up with a plan. Here are some of the problems we noted. 1. No room for a longer shock, even with reworked or 'dropped' mounts. 2. shock angle gets worse, the lower you go. 3. If we go another 2" (8 total) we're screwed again. 4. the exhaust is a nightmare. 5. the inboard shock design doesn't handle that great. With this in mind, we set out for a fix. This is the whole idea behind the JT, to come up with tested components that WORK, and will HELP get more trucks on the road to be enjoyed.
Michelle No Limit Engineering Authorized Dealer for: Ridetech, Vintage Air, Painless, Ididit, Accuair, Flaming River, and many more |
02-05-2011, 03:17 PM | #2 |
Junior Member
Re: No Limit 63-72 Rear Shock Kit
We are also using this forum, and site to set the record straight. I am sure we will be copied. Now there is lasting, dated proof, and those who 'knock-off' will be called out. This kit will come with 2 different length shocks. A 10" stroke shock for the stock to 4" drop guys, and a 8" stroke shock for the 6" to 10" drops. Once the stock shocks and mounts are gone, the new lower mounts are a direct replacement.
02-05-2011, 03:20 PM | #3 |
Junior Member
The new upper mounts locate to the frame with a factory 5/8" hole. We provede a big bolt to hold and align the new mount. You have to drill the two 3/8" holes.
02-05-2011, 03:29 PM | #4 |
Junior Member
Then your all but done. Just bolt on the shocks and mount studs, all included.
02-05-2011, 03:30 PM | #5 |
Junior Member
Quote per Rob, "After somt drive time, I am happy to report that the difference is clear. Body roll is reduced, and the ride is very smooth. The outboard location is a benefit in many ways. With a good quality monotube shock, these kits wil run about $185.00 I think thats a good deal for the gains. Just remember, You saw it here FIRST."
__________________ "It's not who starts first, its who FINISHES FIRST"
02-05-2011, 04:33 PM | #6 |
Definitely interested. How long before they go up for sale?
02-05-2011, 05:35 PM | #7 |
its all about the +6 inches
simple, and it works.
02-05-2011, 05:54 PM | #8 |
Nice, will you offer a kit with the adjustable track bar,lowering blocks & u bolts ?
Posted via Mobile Device |
02-05-2011, 06:01 PM | #9 |
Always on the hunt...
Looks like a well designed and built product, have always wondered why the lower shock plate hasn't changed in the area circled below. I have seen these lower shock stud holes get wollerd/elongated on the aftermarket pieces also, is there a reason they have stayed the same? Mel
02-05-2011, 06:55 PM | #10 |
looks to be pretty close to the ground . whats the smallest dia wheel you have to have to be safe ?
'70 k-10 longbox- mid 70's drivetrain 350/350 487x heads 10.1:1 flowmasters ,35's 3.73's auburn posi ,rear shackle flip. '72 short stepside U.S. forestry truck, '73 455 buick,400 turbo,dropped 2"-4 1/4" ,3.07 posi,:'89 silverado 1500 ,OK truck ,5.7 holley tbi ,trick 700r4 3.07 auburn posi ,and my '66 skylark ,'73 centurion and my '84 monte carlo imca stock car |
02-05-2011, 07:08 PM | #11 | |
C10 addict
02-05-2011, 07:19 PM | #12 |
Min scrub is at 8 1/4", so a 17" wheel or bigger is safe, if you are not using a lowering block, then 15" are OK. The upper and lower mounts are 1/4" thick steel, thicker than the stock mounts from GM. All of the rear suspension parts that we are working on will be avail wed. - after we track test, and have proven results.
GoodGuys 2012 Pro-Truck Champion 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion Proud to put our products up against all others! Last edited by robnolimit; 02-05-2011 at 07:21 PM. |
02-05-2011, 07:25 PM | #13 |
Grandpa in the rustmobile...
Wow. Really diff. I think its really cool to have diff. products out there What other suspension/brake pieces do you guys put out?
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
02-25-2011, 06:34 PM | #14 | |
Edit 03-03-2011: No Limit Engineering: Are you at all concerned about the strength of the shock mounts, especially the lower one? The factory mount captures the shock bolts on both sides of the shock. Your design cantilevers the bolts. While the upper mount looks quite strong the lower looks like it may be a problem, long term, for folks that use their trucks for hauling and towing where shock loads are significant. Perhaps some additional gussets on the lower mount would be advantagous? Quote:
If you have 5" or less drop springs, for a few bucks, you can simply make your own new top mount that bolts into the original upper mount rivet holes and use Monroe shocks 32207. Including shocks, I have less than $60 in the set-up. See Post # 56 here: http://67-72chevytrucks.com/vboard/s...=444378&page=3 Last edited by lakeroadster; 03-04-2011 at 12:40 PM. |
02-26-2011, 01:19 AM | #15 |
60-66 Nut
John, the '67-'72 trucks use a similar lower shock mount with the lower end of the shock in single shear. I agree that a bracket providing double shear would be better.
This shock relocation kit appears to mimick the '60-'62's. Those years had both shocks mounted to the rear, much the same as this kit.
02-27-2011, 05:38 PM | #16 | |
The gusset and short bent leg on the brackets below go a long way in helping to reduce bending stresses in the bracket. I ran a quick FEA just to see how the addition of gussets effect this type of design: Assuming a safety factor of 1 on a lower shock bracket without any gusstes, by adding gussets, such as those shown below, the safety factor increases to nearly 3.5. Wow, now that is a pretty dramatic safety factor increase! Interestingly enough the start of this thread is duplicated here and this same topic is being discussed: http://67-72chevytrucks.com/vboard/s...d.php?t=444928 I thought double posting of a thread was "Verboten"? Last edited by lakeroadster; 03-08-2011 at 09:29 AM. |
02-27-2011, 07:37 PM | #17 |
Happy to be here
We allow a reasonable degree of flexibility in posting to our Forum Vendors. Especially when they are bringing a new product to our members.
02-28-2011, 08:32 AM | #18 |
I added a post on the duplicate thread so those guys could join in over here, and vice-versa. http://67-72chevytrucks.com/vboard/s...Rear+Shock+Kit
02-28-2011, 09:13 AM | #19 |
The only issue I can see with this, is if someone (like myself) who is running a rear mount fuel tank. Without dropping the tank, those upper mounts aren't easily accessible.
01-03-2017, 05:37 PM | #20 |
I just ordered this shock kit for my 72 with a 6" drop. No limit said to call back to order the shocks after parts are installed for correct measurement. I need to do this all at one time, anyone done a 6" drop setup and what shock did you use?
Thsnks, |
01-03-2017, 09:41 PM | #21 |
Old member
Don't know about the 6" drop but I have been running this kit for 3/4 years now and it's awesome!
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
01-04-2017, 08:58 AM | #22 |
What drop do you have and do you recall the length of shock you used?
1970 C10 Short Stepper with 71/72 front clip. |
01-04-2017, 10:19 AM | #23 |
I know this sounds odd, but some of it has to do with how the drop is done. Block or spring, and, is it would be, all springs are not created equal. So, we could guess, and get it right 80% of the time, or, we could do this in a two step process, and get it right 100% of the time.
GoodGuys 2012 Pro-Truck Champion 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion Proud to put our products up against all others! |
01-04-2017, 12:27 PM | #24 | |
01-04-2017, 12:46 PM | #25 |
Old member
Mine has un know 4" springs in back and 3" up front. I have helper air bags in all 4 of them. Between the shocks and the helper bags my truck rides as good as any new truck out there.
I have a 08 Tahoe all factory a 11 Terverse all factory and I'll drive my truck anytime over either one of those weather permitting. No I do not have the measurement on the shocks but they are the blue shocks that Rob offered in the kit when I bought it.
