Old 03-13-2011, 09:48 PM   #1
VA72C10
VA72C10
VA72C10's Avatar
Re: 1972 Cheyenne Super Short Fleet Big Block build!
Originally Posted by 67chevy1series View Post
what....you're not coming???
My only other progress.....took out the lenses. They're actually super nice. Going to see if I can clean up/polish the red ones and use them since they are guide and no chips/scratches/fading. I will get new reverse lenses since they are slightly cloudy....
....but the buckets behind are super nice and not even surface rust in there. Never see metal this nice around my area!
Old 03-13-2011, 09:52 PM   #2
67chevy1series
67chevy1series's Avatar
Originally Posted by VA72C10 View Post
Yeah, two places quoted me that. both included etch priming after blasting but still...outta my price range.
Sure, come on over
Here's a pic of the NOS swaybar mounts/bushings I just got from Tim Christian. Trying to put only the best parts on this thing. Some of the factory parts are nice but I wanted to get all the new stuff for when I re-do the front suspension on the truck.
those are nice!!!!!
haha sure ill be over in 10 minutes.... i am not gonna say anything about the metal we have over here..... haha
67chevy1series is offline   Reply With Quote
Old 03-13-2011, 09:59 PM   #3
VA72C10
VA72C10
VA72C10's Avatar
This bed came from Cali....
Old 03-13-2011, 09:41 PM   #4
VA72C10
VA72C10
VA72C10's Avatar
Originally Posted by no moa View Post
800, WOW! Guess you have the right idea!
Originally Posted by JasonBird View Post
looking good! we should start sanding the cab club! LOL
Sure, come on over
Old 03-13-2011, 11:33 PM   #5
heeroyue2002
fat old dude
heeroyue2002's Avatar
looken good. 2nd time suscribing, dont know what happened to the first one.
1972 c-10 shortbed 350/400
build thread http://67-72chevytrucks.com/vboard/s...d.php?t=389157
1968 workhorse http://67-72chevytrucks.com/vboard/s...d.php?t=446216
Accepting part donations
heeroyue2002 is offline   Reply With Quote
Old 03-14-2011, 09:57 AM   #6
67cheby
67cheby
67cheby's Avatar
keep up the good work , it took me about 25 hours of non stop stripping and i didnt do the inside of the cab, just the jambs, that does include firewall and outsides of the doors, there is a disc called a whizzy wheel about 4 inches round that you put on your die grinder it kind of feels like a stout red scotch brite pad , it works awesome for stripping door jambs and around window frames and rain gutters it is awesome , saves alot of time and doesnt eat away at the metal !!
67cheby is offline   Reply With Quote
Old 07-11-2011, 12:31 PM   #7
68 TT
Still plays with trucks
68 TT's Avatar
Where did you find the whizzy wheels?
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 03-14-2011, 12:20 PM   #8
VA72C10
VA72C10
VA72C10's Avatar
I'll have to look into that wheel for when I am over at Jason's shop. I only have a small compressor that doesn't keep up with air tools so this is all with two 4 1/2" grinders. One with a twisted wire cup for the curved areas and to knock off things like the leftover adhesive from the side moldings/the rust bubbles.
Then I use the paint removal disc (looks like corral) on all the flatter/larger surfaces. That takes the paint off instantly and from what I've read does not damage the metal at all. It takes the paint off almost instantly all the way to bare metal.
Like I was saying the door and both sides took me about 2 1/2 hours with a worn down paint removal disc. Hoping it doesn't take me 25hrs total
Old 03-14-2011, 03:06 PM   #9
heeroyue2002
fat old dude
ive used both the wire wheels and the paint discs. got mine at autozone made by 3m. worked quite well. where you getting yours?
Old 03-14-2011, 04:49 PM   #10
VA72C10
VA72C10
VA72C10's Avatar
Got the wire wheels from harbour freight in a pack, and got the paint removal discs online from an industrial supply place (can't remember the name now)
Old 03-14-2011, 04:52 PM   #11
72k5zl1
72k5zl1's Avatar
got you boxed and the wife is headed out the door to ship it for me. thanks again. truck is looking good!
72k5zl1 is offline   Reply With Quote
Old 03-14-2011, 04:55 PM   #12
VA72C10
VA72C10
VA72C10's Avatar
Thanks and thanks
Old 03-14-2011, 11:15 PM   #13
VA72C10
VA72C10
VA72C10's Avatar
Minor update....tkorinek is going to have the front fenders and the door blasted for me. So when they get here they will be ready for final body work and priming....I will work on having the cab ready when they get here
Old 03-15-2011, 11:43 PM   #14
VA72C10
VA72C10
VA72C10's Avatar
My brother in law came over for a couple hours tonight. Probably got a solid hour of actual work in between talking
He's coming over Thursday and we hope to get more done then. My wire cups and my paint strip discs are all worn so I'll get more tomorrow....
Took the front clip off for easy access to the firewall and since I have two new blasted original fenders on the way
Unbolted the e-brake and brake booster brackets from the firewall. will climb in the truck and finish removing them tomorrow.
Limited progress from this evening...
Gave my brother in law the dirty work of all the curves of the firewall/cowl with the wire cup
and I used the limited remainder of my paint strip disc to get the area above the rear window stripped and the area on the roof above the cab seam (about 8-10" worth)
Old 03-16-2011, 12:41 AM   #15
VA72C10
VA72C10
VA72C10's Avatar
At this point I've been considering my paint options. The firewall will be white on the outside...but I think it looks better if the inner firewall is painted satin black and also the windshield wiper cowl area. also considering painting the underside of the cab with undercoating. Opinions on this? Should it all be white? Will I hurt value one way or the other?
Old 03-16-2011, 12:53 AM   #16
IndyRich
IndyRich's Avatar
I like the original look of a body color painted firewall. When they are black it just looks jerry-rigged to me. As far as the underneath.....I don't blame anyone for using a rubber undercoat if the truck is to be driven at all. The only way I would stick with paint only underneath is for a strictly trailor queen. JMO
IndyRich is offline   Reply With Quote
Old 03-16-2011, 01:01 AM   #17
VA72C10
VA72C10
VA72C10's Avatar
So you're saying the inner firewall white also? I just don't like looking in and seeing where the carpet ends and the padding starts and seeing a crack of white through there....can't picture if that's the case now that I type that but I seem to remember blue showing through on my blazer....
I am pretty much to the point of building this into a trailer queen
The interior is going to be top rate, I have super nice AZ/CA sheetmetal I'm going to sand to bare metal before painting, I have a bunch of NOS parts I'm throwing on it, I'm getting a show quality restored A/C setup, and all original engine brackets, show quality painted inner fenders, and I'm taking apart a nice painted frame to make it into a show quality frame
So I'm thinking I better paint it all correct and white to get top value for it. Next owner could easily spray undercoating or a spray in bedliner under it if they decide to drive it....
Old 03-16-2011, 09:43 PM   #18
Zoomin
Man of Mini-Talents
Zoomin's Avatar
I'd say no on the black on firewall - keep it white. No on the undercoating - let the purchaser do it if they want it.
The theme of your truck seems to me to be a restoration, given all the awesome parts you're throwing at it. The only thing off on this truck is going to be a frame. If you want top dollar for this, you're going to have to keep it as pure as possible to overcome that. As a rule of thumb, I would keep any deviations from stock limited to things that can easily be undone.
If you were doing a resto-mod or keeping it forever, then no problem with what you want to do.
Zoomin is offline   Reply With Quote
Old 03-16-2011, 09:49 PM   #19
VA72C10
VA72C10
VA72C10's Avatar
Thanks. I have decided to do it all factory correct. Looking now at all the pictures I find to make it look as close to factory as possble. I am going to paint the underside of the cab and bed white also so people can see it's a total frame off done the right way
Old 03-17-2011, 09:02 PM   #20
Zoomin
Man of Mini-Talents
Zoomin's Avatar
See my advice above? Disregard.
Check the truck in this link
$31,100 and still hasn't met the reserve. If you do something first rate, the market will recognize it. Do as you will, just do it first class...
Old 03-16-2011, 01:18 AM   #21
VA72C10
VA72C10
VA72C10's Avatar
What about the kick panel areas? This semi-custom cheyenne has them in black and I like how it cleans up that area....
Old 03-16-2011, 09:38 AM   #22
67cheby
67cheby
67cheby's Avatar
Paint on the firewall and kick panels, my upholstery guy said he can order my carpet kit with extra carpet left on the front to run further up the firewall
Old 03-17-2011, 10:09 PM   #23
gcburdic
Restoration Virgin!
gcburdic's Avatar
Zoomin'....does this interior picture look familiar???.... I think VA72C10 is watching and is being inspired by your ebay link
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 03-17-2011, 10:24 PM   #24
Zoomin
Man of Mini-Talents
Zoomin's Avatar
I completely missed putting the two together. When I saw the pic in this thread I thought it looked familiar....
Old 03-17-2011, 11:59 PM   #25
VA72C10
VA72C10
VA72C10's Avatar
I actually had that saved to track it before I saw the thread
Wanted to see how much a lightly resto-modded one would sell for....
