Old 02-24-2011, 07:03 PM   #1
Slammed66
Needs a Big Block
Slammed66's Avatar
Project: Tall Grass
Hey guys, been around here for a while, but Finally getting around to the rebuild of my slammed 66 er 64
My buddys have been calling it project tall grass, as one of my favorite sayings goes, throw it in the tall grass never to be seen again. any one with a farm knows wha I mean.
the truck has sat idle for a two long.
as it sits now its on a frame with a 3" Z and 10" notch and a two link.
never really happy with that im now starting fresh using a dropmember , pb arms, notch and 4 link.
here she is before the z 1.5 sectioned crossmember spindles and bagged .
in action
after the Z and some 20's
1964 Short box
On dropmembers and billets
1962 Suburban family cruiser
1972 K10
Slammed66 is offline   Reply With Quote
Old 02-24-2011, 07:14 PM   #2
Slammed66
Needs a Big Block
Slammed66's Avatar
Re: Project: Tall Grass
jump ahead. here she is laying in the tall grass
so fast forward a bit, I finally bought a house. crudely finished the garage with some insullation some osb and a couple coat of paint .
and here we are today. sitting idle collecting debris and dust while the new frame gets thown together
1964 Short box
1972 K10
Old 02-24-2011, 07:29 PM   #3
Slammed66
Needs a Big Block
Slammed66's Avatar
The Bullet. carb,d 5.3 to a th400.
1964 Short box
1972 K10
Old 02-28-2011, 12:25 AM   #4
Slammed66
Needs a Big Block
Slammed66's Avatar
Got a bit more work done today........
mounted the 4 link brackets I got from Porterbuilt
removed all previous leaf and 10 bolt junk this frame came with, the truck was prostreet.
then I spent an hour battling the shock mount crossmember and the crooked crossmember, the c notch was boxed in on the inside and welded to the crooked one, took some serious grinding and beating but its all out now.
NOTCH TIME!!!
Hmmmmm leave it , and bury this thing over some 35inch all terrains???
Nahhhh trim it to fit, if your wondering, the notches came from porterbuilt, and it they look lower than usual its beacuse they are, I want to put em as low as I can to keep the maximum bedspace , and im limited in tire size being a step side.
so this is all for now More tommarow.
1964 Short box
1972 K10
Old 02-28-2011, 12:43 AM   #5
creep
Registered Loser
creep's Avatar
Very cool! I'm really starting to like them bagged steppers.
'63 GMC lwb, 383, th350, lays frame, genuine patina.
The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267
'88 Astro cargo bagged, shaved, phantom grille. *SOLD*
'50 Chevy 2 door sedan awaiting attention.
2014 Silverado Ext cab, 5.3, daily driver.
creep is offline   Reply With Quote
Old 02-28-2011, 12:53 AM   #6
Slammed66
Needs a Big Block
Slammed66's Avatar
Thanks me too, I was going to go fleet side. But, I used up my box when I turned this>>
into this!!
after that I figured it was born a stepper, might as well leave it alone.
1964 Short box
1972 K10
Old 02-28-2011, 01:01 AM   #7
creep
Registered Loser
creep's Avatar
Wow, that's quite a transformation! And I thought I was crazy for bagging a 3/4 ton.
Old 02-28-2011, 01:13 AM   #8
nachodog2
Hell yeah!!!
nachodog2's Avatar
into this!!
Doesn't even look like the same truck. Much improved.
Stock is good but custom is the sh*t!
nachodog2 is offline   Reply With Quote
Old 03-18-2011, 02:11 AM   #9
Slammed66
Needs a Big Block
Slammed66's Avatar
well, im back from work, and ive got both the rear notches welded in , I just need to trim out the frame and cap them,... I forgot to take pics. Ill grab some in the am, but for now, some new parts showed up!!! things are getting exciting now
1964 Short box
1972 K10
Old 03-18-2011, 05:08 AM   #10
coulter
coulter's Avatar
looked pretty good before... cant wait to see it finished.. btw ur utility truck looks pretty hood to!!!
coulter is offline   Reply With Quote
Old 03-22-2011, 10:42 PM   #11
Slammed66
Needs a Big Block
Slammed66's Avatar
Thank guys you've both got some sick trucks..
not much progresss but burn in one notch ,
hung some more front junk, still need to buy a rack and install the notches.. baby steps....
took a couple pics of the old frame and my lack luster z.
thats it for now, off to work for a week then 26 hours of driving and portland swap meet Booooya !!!!!!!
1964 Short box
1972 K10
Old 03-23-2011, 12:49 PM   #12
Corts60
Just here to tinker
Corts60's Avatar
That truck is gonna be sweet man. I am hoping to make it to the Portland swap meet as well.
Old 03-23-2011, 06:36 PM   #13
Slammed66
Needs a Big Block
Slammed66's Avatar
Thanks Cort. Your last truck was awsome I loved the look, can't wait to see how your burb progresses!!!!
Hopefully you can make the swapmeet looks like your a bit closer than me lol
1964 Short box
1972 K10
Old 03-24-2011, 11:52 PM   #14
Delmo
Delmo's Avatar
Cool man. Looks great.
Delmo is offline   Reply With Quote
Old 04-05-2011, 10:02 PM   #15
Notch1988
Notch1988's Avatar
Any updates? Pics of your swap meet finds?
Notch1988 is offline   Reply With Quote
Old 04-05-2011, 11:53 PM   #16
Dinos63
chevy only
Dinos63's Avatar
duuude glad your back this is one of my most favorite trucks!! killer job on both
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 04-08-2011, 12:05 AM   #17
Slammed66
Needs a Big Block
Slammed66's Avatar
Wow thanks dino, that means alot coming from you!!
I just finished another set at work and im headed back home in the am, so progress pics soon and maybe some of my parts scoress from portland..
The lil red 66 gmc has moved to a new home a while ago, im pretty stoked to see Dave AKA Notch1988 take it all the way!!!! build thread dave lets go!!!!!
1964 Short box
1972 K10
Old 04-15-2011, 03:05 PM   #18
Slammed66
Needs a Big Block
Slammed66's Avatar
Update?? dont mind it I doooooooo.
Got the notches in 4 links mounted and tacked, gotta check on the proper way to set up and mount the brackets on the diff. also tacked up the watts link. gotta get a couple tubes bent for the notch that I can attatch my upper bag mounts to, then shocks cycle it and finish weld everything.
Portland was awsome, bought, a mint grille support, new tailgate a roll pan, new steering wheel, a traffic light lol, a set of rims and a front bumper for my 06.
New parts have started rolling in too, yesterday these showed up!!!!
and fedex left this on my porch this morning!!!!!
unisteer power rack, ohhh yeaahh
1964 Short box
1972 K10
Old 04-15-2011, 03:16 PM   #19
Slammed66
Needs a Big Block
Slammed66's Avatar
Also not sure if I made the right move or not, as the torque thrusts looks awsome on everything, especially my truck. but I have a verbal sale , of my 17's to PHAT TONY, they'll look great hes building a killer 72 2wd blazer
pics of his ride can be found in here...
http://67-72chevytrucks.com/vboard/s...ad.php?t=39938
Ive always wanted a 18's and 20's combo , and im gonna get this thing on the road this year , so boyds or intros werent in the budget, so I ordered up a set of 18x8 and 20x10 eagle 225's the front are back ordered, but they claim theyll be out this month sooo we'll see...
if they show up ill be puuumped, should look good!!!!
1964 Short box
1972 K10
Old 04-16-2011, 08:34 AM   #20
coulter
coulter's Avatar
ya those should look really nice!!! looking good man
bagged 66 longbed build
http://67-72chevytrucks.com/vboard/s...d.php?t=449548
my favorite colors.. black, rust, and shiny!!!! instagram: @coulter918
Old 04-16-2011, 02:02 PM   #21
creep
Registered Loser
creep's Avatar
Dang, I'm really diggin' those rims! I'm still torn between big rims or steelies.
Were the upper arms on the wrong side in the first pic of the new front set-up?
Old 04-16-2011, 11:30 PM   #22
Slammed66
Needs a Big Block
Slammed66's Avatar
Yep hahaha, you noticed eh
Burnt I'n the rack notches test fit the rack, then broke it down. Got most of my pieces, primed and painted. Pics tommarow after I get more painted and some reassembled.
Play safe tonight kids!!!
1964 Short box
1972 K10
Old 04-17-2011, 12:08 AM   #23
C10CORIE
C10CORIE's Avatar
DAMN!!! Lookin good Matt!
One of my favorite trucks too.
C10CORIE is offline   Reply With Quote
Old 04-17-2011, 02:04 AM   #24
shrunken66stroker
shrunken66stroker's Avatar
Is the steering wheel going on a stock column? If so, will you post a pick of what the adapter looks like and give me a rough idea of how deep it is? Your truck is really coming along. I can't wait to see the progress pics.
shrunken66stroker is offline   Reply With Quote
Old 04-17-2011, 11:28 AM   #25
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Im in.......... I have always wanted a step side and this one looks like its gonna be pretty damn nice..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
