02-25-2011, 12:51 PM | #1 |
63 GMC Short Fleet
Hello my first post. I am building a 63 GMC I bought for 1400 bucks drove it for a year. so far I have tore it apart!. the fun part. I am adding a 84 GMC front beem susp. big disk brakes, power steering, 10 bolt rear, 5 lug, fliped rear, drop spidles, older camaro column,350/700r4 any help would be great due to this is my first build thanks
02-25-2011, 01:08 PM | #2 |
Re: 63 GMC Short Fleet
Cool! nice VC's also!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
02-25-2011, 01:25 PM | #3 |
yeah I liked the 305, but I have already sold it, just really couldn't get the performance out of it. Plus it sucked gas like crazy
02-25-2011, 02:03 PM | #4 |
Oh I understand, they will run forever but suck gas and like you said no performance at all.
so what are you got planned for the power plant?
02-25-2011, 03:30 PM | #5 |
Here is a pic of the donar truck now stripped to nothing
02-25-2011, 03:33 PM | #6 |
some pics of my teardown progress
02-25-2011, 03:35 PM | #7 |
More to come this weekend if weather permits
02-26-2011, 04:26 AM | #8 |
Nice! I'll be watching your build as I too want to do a 350/700r4 combo in a 63 although mine's a chevy should be pretty similar I think? and I'm currently in process of swapping out the entire front end of the suspension with disc brakes from an 80 c10 with power steering so I'll be tuned in!
1963 Destiny Build Log |
02-26-2011, 10:35 PM | #9 |
Your right not much difference rear suspension is about all
Posted via Mobile Device |
02-27-2011, 01:43 AM | #10 |
60-66 Nut
Welcome to the forum
You're going about this the right way with buying a donor truck. You chould have most everything you need to update your GMC
02-27-2011, 01:48 AM | #11 |
Sounds like the drive train is really good. My truck is the same way all that i need to do is the metal work from here on out. Is your front grill in good shape? |
02-27-2011, 01:58 AM | #12 |
Just here to tinker
Boy there are a lot of GMC guys that would kill for those valve covers. Great to see your building it the way you want it though.
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/showthread.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 73 Chevy C20(Daily)http://67-72chevytrucks.com/vboard/s...d.php?t=852767 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(sold) |
02-27-2011, 08:47 AM | #13 |
Good luck and have fun!
"Do what you want to the girl, but leave me alone!" |
02-27-2011, 11:42 AM | #14 | |
nice grab man, enjoy! IMO i hate those valve covers.
02-28-2011, 10:14 AM | #15 |
Thanks for all the replies, hey Captinfab do you have any of your power steering adapters if so send me some info I need one
02-28-2011, 10:23 AM | #16 |
my grill is in pretty good shape, it has a couple of dings above the pass side headlight, not bad though, it needs a rechrome too, but my hood is another story lol.
02-28-2011, 10:26 AM | #17 |
hey paul i think it will, if not I will just do alot of cutting, I plan on some interstate driving and I want that overdrive
03-01-2011, 01:19 AM | #18 |
03-08-2011, 10:51 PM | #19 |
hey guys sorry no progress weather has been awful! As soon as it breaks I will be getting the front beam off and start prepping for the 84 beam
03-08-2011, 11:23 PM | #20 |
04-10-2011, 10:44 AM | #21 |
Hey guy sorry no progress, on my tear down, I've had health issuses and im back, I've been working on the front end got the suspention off, lol PO welded the dang springs in it was a nightmare! but with some cussing and a cutting tool I got them out, also got the cross member out so I can get ready to put in the 84 crossmember
04-11-2011, 09:16 AM | #22 |
UCA63
Coming along nicely 63
When I did mine it was a tight squeeze (3/4"narrower than the frame),but 2" ratchet straps (looped around and back into itself) fore and aft sucked the rails in just enough to slip the crossmember in. T
member#7816 "63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt '61 GMC in progress '63 GMC to use for parts '90 Chevy Ext cab sbfs 5.7l (current d d) |
05-11-2011, 09:49 AM | #23 |
well I finally got to work a little on my pickumup, the parts fairy brought my c notches, got the rear off frame is stripped down ready to cut
05-11-2011, 12:58 PM | #24 |
It would probably be a good idea to support the frame from both sides of the cutting area. Less chance of it sagging before you get it all drilled and bolted up.
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. |
06-09-2011, 09:11 AM | #25 |
Finally got to work on the pickup got one side cut c-notch just sittin there but its a start should I bolt or weld them in?
