Old 07-09-2003, 04:05 PM   #1
chargedstang89
Question Electric or Manual Fan?
I currently have an electric fan on my truck, but since it's gotten hotter, the truck heats up to about 240 degrees or so when idling. The electric fan that is on there was on the truck when I bought it, so I have no clue what kind it is or how many CFM's it can flow. The engine is a brand new crate 350 from GM, and i put a new water pump and thermostat in it as well...including a new radiator. I have no problems with temperature as long as I'm driving, but when I pull a trailer or idle, it heats up a lot. I'm getting ready to put a brand new A/C system in it and I know that is going to add heat as well. Should I put a bigger electric fan or possibly dual electric fans, or should I put a flex fan in it? The truck has a 3.5" body lift on it, so a manual fan doesn't seem to line up without me modifying the shroud. What do ya'all think? Also, I was thinking electirc fans would help with power in my truck since it's lacking. If I should go electric...what kind should I get???? Josh
chargedstang89 is offline   Reply With Quote
Old 07-09-2003, 04:12 PM   #2
78SilveradoSWB
78SilveradoSWB's Avatar
Would stay with an electric fan, but wonder why your temp is getting that high. What temp thermostat you have in there? Seems to be some other problem than just the fan.
Mitch
1978 Chevrolet Silverado C 10
454 BB, TH400
78SilveradoSWB is offline   Reply With Quote
Old 07-09-2003, 04:33 PM   #3
chargedstang89
well, when it was cooler outside, the truck could idle all day long and stay cool. as it got warmer and warmer as the seasons changed, it started to slowly idle warmer/warmer as i let it sit and run or if i'm stuck in traffic. now it's 90-100 degrees and the truck heats up bigtime idling...especially after i tow a trailer. Like I said, I have no clue how many cfm's the fan that is on it now pulls. It isn't that big of a fan, doesn't seem that high quality either. I believe the thermostat is a 180 degree thermostat. My oil and coolant are full, and again..the water pump was new too.
any clue on which fans to get?
Old 07-09-2003, 04:38 PM   #4
PHOENIX
How is it wired up, on a thermostat, toggle switch, or other?
I really like the toggle switch I have setup. I can control it anytime, just need to pay attention to whats going on. Living here and having a truck that used to always overheat has trained me to always pay attention to outside temp., engine temp, and sitting still or moving. Its a siccness. Anyway........
Are you using a relay?
Does the fan sound like it is working properly?
Is it a pusher (grille side) or puller (engine side)?
Eitherway can you feel air being blown from the fan?
Do you have a shroud on the radiator now?
Where is the fan mounted in relation to the shroud (inside, outside)?
Your timing and carb are set correctly?
You have changed oil on time?
Fan Details:
Diameter of blades?
Number of Blades?
Curved, straight, etc. ?
If you need to replace the fan, i would go with electric. Make sure to buy one for use on a v-8 engine of your size (5.7L+)
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION *
PHOENIX is offline   Reply With Quote
Old 07-09-2003, 05:16 PM   #5
chargedstang89
The fan is a puller style fan. There is no shroud around it. The fan is wired into a toggle switch, and i keep that switch turned on as soon as I get in the truck so it is blowing constantly. Yes, I can feel air being blown from the fan and it sounds like it normally does. I do not know the diameter of the fan, but I can tell you that thickness wise, it's only about 3/4" thick. It just doesn't look anywhere near big enough to cool a 4x4 truck with a 5.7L. When I get a new fan, I want to put relays on it so that I do not have to worry about someone else driving my truck and frying it. The oil is changed, so that shouldn't be a problem either. I'm just thinking that this fan is a wuss fan. The timing and carb were adjusted and set by my local shop. I know the guys there and they drag race, so they know what they are doing. I had them do it since I am new to carbs and adjusting them is kind of like Greek to me. The guy I bought the truck from is a complete moron and had everything messed up. I spent days fixing his "jimmy rigging" of many electrical parts in the truck. I think that he just stuck this fan on there because it was something local he could find.
Old 07-09-2003, 05:18 PM   #6
C&C Chevy
C&C Chevy's Avatar
If its only a single fan, it should be atleast 18". Dual 14" fans are the biggest you can go with a stock size radiator.
Robert
Current:
1986 SWB Silverado 4.3 / TH400
Past:
1985 SWB Silverado 305 / TH350 - sold 1995
1987 1/2 ton Silverado - FI 350 / 700R4 sold 2007
C&C Chevy is offline   Reply With Quote
Old 07-09-2003, 05:26 PM   #7
PHOENIX
About what percentage of the radiator does the electric fan cover?
Here is a picture of the fan I have in my truck.
It is from a Jeep (5.9L).
This fan covers all of the radiator top and bottom and allows a little gap at each end 3-6". This little flaps allow air to flow through when driving down the road. Fan works great, but wasnt used on a lot of Jeeps/Dodges. I would recommend that if you do not buy a new fan, you should buy a used stock fan off a v8+ engine.
Anyway you could get a picture of your fan?
Old 07-09-2003, 05:29 PM   #8
PHOENIX
Inside, shows flaps.
If you can find a fan similar to this in a yard somewhere I would snatch it up. Its a very powerful fan and works great even in this hot Phoenix weather.
just heard on the radio tomorrow should be around 115-117 <---- it feels like this without the smile
Old 07-09-2003, 05:35 PM   #9
C&C Chevy
C&C Chevy's Avatar
Atleast that's "dry" heat.
Robert
Current:
Past:
Old 07-09-2003, 06:19 PM   #10
Eyegore
What Hump?
Eyegore's Avatar
I would check on the size of your radiator. How many rows does it have. True it may be new, but the size does matter espically when you change the configuration of the truck. Here in the desert they sold what was called desert tanks (radiators). I had them in my blazers and boy did you need them when four wheeling and it gets over a 105 with the air on. So perhaps you might check your radiator size, see if you can get something larger.
Tom
Lil red 86 c-10
99 Sub
78 Camper Special w/ 454
Eyegore is offline   Reply With Quote
Old 07-10-2003, 11:06 AM   #11
chargedstang89
the radiator is a 3-core radiator instead of the stock 2-core. Also, the fan does not cover anywhere near as much of the radiator as the one in the above picture. I will take a picture of it with my digital camera and post on here tomorrow. I appreciate all of the input. What are some goo vehicles to check in yard for electric fans? i.e. vehicles that have high volume electric fans.
Josh
Old 07-10-2003, 11:45 AM   #12
LOHRTBT
BeWarE tHe eViL CrAnkTOe!
LOHRTBT's Avatar
Dual Electric Hayden's with Hayden Thermo controller... Under $175 New from O Reilly. Very nice upgrade for the money!
~Dave~
You can call me Mike, Mike Oxlong
- 1986 Chevy SWB - Stock for now
- 1986 Chevy Custom SWB *Stolen 6/26/05*
- 1985 Chevy SWB SOLD
- 1999 T/A Some mods
www.cardomain.com/id/ramairdave
AIM Screenname - Jester84
LOHRTBT is offline   Reply With Quote
Old 07-13-2003, 09:07 PM   #13
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Web page write up.
I would add a four core radiator and upgrade to two fans.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 07-13-2003, 09:55 PM   #14
87 STEPPER
STILL PLAYS WITH TRUX
87 STEPPER's Avatar
Question
I can't belive no one has asked this ? yet!
What year is this truck????????
If you have a new GM crate eng. why would you have to replace the water pump? Or did it come without one?
And why is the truck down on power with a new GM crate motor in it that's tuned properly by drag racer mechanic's?
Besides needing a new and bigger fan i think you need to find out about that H2O pump!!!
Did you buy this pump? and did you install it?
If so then get the P/N and make shure it's not a reverse flow H2O pump.
Your truck may need a normal rotation H2O pump thats why the year is important to know and this could be the reason your over heating.
Im running a Ele. fan off of a '90's berretta and iv'e had no prob's with it down here in summer with a/c going and a tranny cooler up front.
Also look for a fan off a corsica it's just about the same as a beretta.
I also removed the relay and related wireing for the fan from that same car.
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
87 STEPPER is offline   Reply With Quote
Old 07-13-2003, 11:36 PM   #15
chargedstang89
The truck is an '85 gmc sierra. 1/2 ton 4x4. the crate motor is a stock, 190 horsepower 350 from gm goodwrench. the truck is properly tuned. again...it doeesn't run hot at all when driving down the road, it's only when i idle. it just started doing this as the summer has gotten hotter. all fall/winter/spring, the thing ran like a champ. as for being down on power, 190 horses in a 4x4 that has 33" tires and 3.08 gears is why it's down. i need steeper gears. when i romp on the engine, the secondaries kick in like they should, the tranny kicks down, but the truck just doesn't go anywhere. when i take off from a stop pulling my ski boat, the damn thing takes forever to get up to speed, and forget passing someone. no way. I should have known better than to put a stock motor in the truck. i should have at least gotten a 300 horse crate motor, instead of a wimpy 190 horse, but oh well...too late now. i've been thinking about putting a cam and intake in it, but don't want to void the warranty. but anyway...about the fan...i think i'll get duals. i measured the electric fan that's on it now, and it's only 14"....definitely not big enough for the truck.
JP
Old 07-14-2003, 01:51 AM   #16
CustomChevy
Guess I'll add my 2cents...
If you stay electric, get one that pulls at least 2400-3000cfm.
Throw on a new thremostat just to be sure.
Get a radiator flush if it's been a long time, best to keep your system clean. Also, don't use too much anti-freeze. Use 80% water. You only want enough a/f to raise the boiling point.
Check that radiator cap, make sure you got the right poundage.
Best to have a 14 or 16lb cap.
Good luck!!
CustomChevy is offline   Reply With Quote
Old 07-14-2003, 05:16 PM   #17
chargedstang89
Would dual 12" electric fans be a good setup for my truck? From what I'm understanding, it seems like that would work well. What does everything think?
Old 07-14-2003, 05:28 PM   #18
C&C Chevy
C&C Chevy's Avatar
nope. get another 14" fan and set it up like Mikes, Gchem's, or Lohrtbt's and it should cool alot better! Your single 14" fan usually puts out 1500-2100 cfm's. Just add another and it should stay very cool.
Robert
Current:
Past:
Old 07-14-2003, 05:37 PM   #19
C&C Chevy
C&C Chevy's Avatar
Here's a link to Mike's write-up. It's the last article. Mike is a Chevy Truck God!
Pic of Mike's setup.
Robert
Current:
Past:
Old 07-15-2003, 01:15 PM   #20
chargedstang89
Okay...now I'm in limbo. A guy I work with told me that a Flex fan will pull more air across the radiator, condenser, and tranny cooler than dual 14" fans will. Anyone have any input on this? I was thinking about getting the dual 14" fans from O'Reiley's that were mentioned a few posts above. Any thoughts or statistics?
Old 07-15-2003, 01:22 PM   #21
bigblock73
yeller
bigblock73's Avatar
Flex fans suck..well not literally...just figuratively! They don't cool worth a damn and have had a reputation of "coming apart" and causing damage or injury.
I have never run an electric fan, always had a clutch fan and never had any problems. Some say they take away some HP, but I bet it isn't even enough to notice.
...jeff
bigblock73 is offline   Reply With Quote
Old 07-15-2003, 01:32 PM   #22
LOHRTBT
LOHRTBT's Avatar
Flex fans suck!! haaha Just what Jeff said
Believe it or not..when I took off my clutch fan and went to elec. I noticed quicker throttle response.
~Dave~
Old 07-15-2003, 01:32 PM   #23
LOHRTBT
LOHRTBT's Avatar
and to clarify mine are also dual 14" haydens.
~Dave~
Old 07-15-2003, 02:41 PM   #24
rockman20
"The dude abides"
rockman20's Avatar
Clutch fan does rob power.
I ran a flex fan for about 5 years on my Cutlass. Never had a problem except for keeping belts tight. Converted to a dual electric fan setup and noticed quicker throttle response and also better mileage. I want to do this to my truck, but I need to get my radiator tanked and everything first.
RockMan
1993 Chevy Silverado C3500 1 ton dually
1994 Honda Civic
1969 Oldsmobile Cutlass S
1953 IH Farmall Super M
New to the fleet:
1992 Subaru Loyal
rockman20 is offline   Reply With Quote
Old 07-15-2003, 03:05 PM   #25
chargedstang89
So, which pulls more air....a clutch fan, flex fan, or dual 14" electric fans. Keep in mind, I live in St. Louis, so it's very hot and humid during the summer, and there's lots of traffic to sit in. The fan will have to pull air across the tranny cooler, condenser, and then radiator....so, which one out of the three will pull more air????
