10-13-2015, 01:32 AM | #1 |
Re: 66 4x4 my sons new project
Chris,
Here is the view at 0 and at 65 mph. No major vibrations.
Jason M. @argonaut62 1972 K5 Blazer CST, Turquoise 1966 K20 Short Fleet Pickup, Big Ugly 1964 C10 Short Fleet, Gertrude 2001 Porsche 911 Carrera 1996 Ford Bronco XLT 1980 Jeep Wagoneer 2008 Honda CBR1000RR 2005 Honda RC51 1981 Honda CB750C No dis-assemble Johnny Five! No dis-assemble! |
10-13-2015, 12:28 PM | #2 |
What?
I have the square aftermarket mirrors, and they are solid as a rock at speed.
Nor do they make any wind noises. I like the convex mirror idea.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
10-13-2015, 12:41 PM | #3 |
They're nice because I have no blind spots.
10-13-2015, 01:36 PM | #4 |
I must have picked up some crappy ones. Jason, are your mirror arms aftermarket too? If so, where did you get them.
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
10-18-2015, 12:05 AM | #5 |
I think I got them from Truck Shop. But its been a long time.
The ones I bought from Classic Industries seemed thinner and the flat bent part where the mirror head mounts isn't really bent at the correct angle. The mirrors can barely pivot far enough to get into the correct position.
10-18-2015, 07:36 AM | #6 |
Jason I see you went through the trouble of relocating your gas filler to the passenger side.LOL That's what it looked like from the picture taken through the mirror...I had those crazy factory SHAKER'S on my 70 Burb I couldn't see anything those things shaked all the time... those round covex,concave which ever they are do work very well as you said
no blind spots..I know a lot of people add those small ones like that to the bottom of their mirrors to correct that problem I think I need to add them to the wife's Nissan thye will save you from an accident.. I've been close a few times because of those blind spots...
1964 BBC 402 4x4 |
10-29-2015, 04:53 PM | #7 |
Love the truck!! Whats next?
02-28-2016, 09:33 PM | #8 |
Jason when you put that big block in your truck did it bolt right to the v-8 crossmember or did it have to be modified..
1964 BBC 402 4x4 |
02-28-2016, 09:42 PM | #9 |
I forgot you have the original frame so I guess you had to modify, my frame is a 1970..
1964 BBC 402 4x4 |
02-29-2016, 03:22 PM | #10 |
I used the engine crossmember from a 67-72 K10 and a trans/transfer case crossmember from a 73 K20. I estimate that it is mounted about 2" further forward than a small block would be.
I know some people have been able to make it fit in the stock location, but I couldn't. You never know if the motor is sitting a little higher or lower depending on their engine crossmember, or more or less tilt depending on their trans crossmember. You'll just have to try to get it in there and see what works for you. Hope that helps...
07-05-2016, 10:59 PM | #11 |
Jason you been mighty quiet, any new updates...
1964 BBC 402 4x4 |
07-06-2016, 01:27 AM | #12 |
What?
Jason, hit me up on PM re Brothers show.
Your inbox is full.
07-06-2016, 01:38 AM | #13 |
Chris, you've got mail!
Randy, I'very been busy paying off some bills and buying my first house. So no time spent on BU, just driving him. I have lots of parts collected, waiting to go in. Might dig back into it next year...
07-06-2016, 09:22 AM | #14 |
I understand Jason, Buying a house will definitely put a halter on things...
1964 BBC 402 4x4 |
07-14-2016, 01:38 PM | #15 |
Jason--glad to here you're doing well. life goes on and the tk can wait some. Good luck with your new house--enjoy!
Kimble
1961 chevy K10 my build is------------61K10 build |
07-15-2016, 02:19 AM | #16 |
Good luck with the house!
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
08-28-2016, 09:14 PM | #17 |
Super sweet truck. I say keep it a longbed and keep the orange paint. Best of luck with it.
08-28-2016, 10:01 PM | #18 |
Thanks, Brian. But it's a little late to keep it orange and a long bed!
08-28-2016, 11:37 PM | #19 |
Ok Jason, thats twice in a week that Ive seen ya here! Good to see you poppin in. Hows the house coming? Hope all is well!
08-29-2016, 12:18 AM | #20 |
Ya, I'm lurking as always. I'm itching to do some work on Bigetting Ugly but I'm studying for an exam at the end of October (for real this time) so I can't (shouldn't) get sidetracked until it is over.
I need to swap in a new short 32-spline input and twin stick shift rails into the NP205. I want to buy a new centerforce clutch and throw out bearing for use with the nv4500 bellhousing. Then a new hydraulic clutch line and a custom bracket to adapt the nv4500 tail mount to the factory SM465 tail mount. I'm also trying to decide what route to go to make my suspension more compliant. I hesitate to swap in 52" springs up front because with crossover steering I have no clearance to run a sway bar unless I can find one that is really wide, wide enough to straddle the outside of the steering gearbox. I've been looking at the one on my bronco but I'm not sure that it's quite wide enough
08-29-2016, 12:49 AM | #21 |
The 95 and 97 F350s that i had put the sway bar behind the front axle. Drop is on the wrong side for your truck but another angle to look at. Who knows, might be able to get one and flip it on top of the axle instead of under?
Which BH did you get? AA or stock? I was tempted to get a CF clutch but am going to try and see if the Valeo that was behind the 396 will work. The 454 kinda broke the bank.
08-29-2016, 12:50 AM | #22 |
Good luck on the exam!
08-29-2016, 08:58 PM | #23 | |
I'm sure the clutch from your 396 will work on your 454. Do the 454's use a neutral balanced flywheel like the 396 or does it have to be balance with the rotating assembly? I never really understood the logic behind that design...
08-29-2016, 11:16 PM | #24 |
Im gonna try the clutch that I ran with the 396 even though the 454 is ext balanced. I don't think it will be a problem as there are no index marks for the clutch to FW. I figure that hundreds of clutches are replaced at least weekly and Ive never heard of anyone tearing an engine apart to balance it when doing a clutch. I hear you on the AA and the 400 bucks. Thats the way I went and now I don't even have the money to paint the engine compartment. Just gonna have to wait to get a little more OT under my belt.
Get crackin on those books! Ive got an exam coming up for work pretty soon too. I gotta hit those books myself!
08-29-2016, 02:20 PM | #25 |
Yeah, sorry man. New to site and realized after I posted that you were past that point.
