03-18-2004, 10:51 PM | #1 |
get layed
Got mine front back together yesterday took a few days w/ all the painting. Painted a-arms body color, frame hammertone silver, and a few brackets etc. flat black. The sway bars front mounts are layed on the ground. Took the rear wheels off and let the jack down, drive shaft crossmember hit the ground and the pinch wells were about 1" off the ground. Should lay hard once I relocate crossmembers and bag the back. Started cutting out all the rear wood floor and tubs this afternoon. By the way this is on a '72 Suburban w/ 20's, 1.5" crossmember drop(Capt's way), 2.5" spindles, and 2600# bags w/ just the upper plates. Will post some pics as soon as I get them. Later
03-18-2004, 10:59 PM | #2 |
Project92 SWB stepside
I would go with a pretty big notch in the rear!!!
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448 |
03-18-2004, 11:18 PM | #3 |
Biggg notch
I think it's going to have to be around 9" of actual notch, haven't really put a tape to it yet. Going to notch it Saturday gotta go get some 3"3" box to build the notch tommorrow and try to get the rear floor cut out before Saturday. already torched out the old springs and bumpstop mounts. Later
03-19-2004, 12:13 AM | #4 |
world class smart ass!
tubbedII's project [/B][/QUOTE]
MMMMMMM, CHEVY II, AAAAAAAAHH..... (That's me drooling all over that) Your bro's truck looks good to, would like to see more pics of that as well..
Aric 75 2WD BLAZER (never ending project) -some day maybe- 02 2500HD CREW CAB 4X (daily drive) -8" lift 37s and 22s- ____ ____________________________ |
03-19-2004, 06:34 PM | #5 |
I did a 11 inch notch to let the frame sit on the ground with my 29 inch tall tire. I need to upload pics of my suburban!
03-19-2004, 08:57 PM | #6 |
I am running a 33 so I may need more notch also!!
03-19-2004, 10:17 PM | #7 |
Under construction!
I had an FBI 10" step notch and when layed out, I still had 5" or so of clearance. I could have gone down 1-2" more but my driveshaft bottoms out under the cab.
BTW, that's w/ 245/35/ZR20 tires.
2001 Silverado bagged on 22's. *Sold* Last edited by BaggedC10; 03-19-2004 at 10:20 PM. |
03-20-2004, 01:57 AM | #8 |
tierods
On my front steering after the crossmember drop my tierods are bent from sitting on the pitman arm and idler when layed all the way out. It looks like I can just have it aligned like this w/ it raised to cruise height. They are not bent excessively so I think it will be o.k. Just wanted another opinion. I only dropped the member 1.5" so I wasn't expecting clearance issues there. Should I flip the tierods or leave it alone.
03-20-2004, 10:42 PM | #9 |
needs more $$$
Went to my bro's today to take some pics, here's what it looks like today.
My brother and I would like to thank all of you guys on here for the help. Without this thread, we would not even be half as far as we are right now! 1.
1970 2wd Blazer |
03-20-2004, 10:43 PM | #10 |
needs more $$$
2.
1970 2wd Blazer |
03-20-2004, 10:44 PM | #11 |
needs more $$$
3.
1970 2wd Blazer |
03-20-2004, 10:45 PM | #12 |
needs more $$$
5.
1970 2wd Blazer |
03-21-2004, 02:07 AM | #13 |
Hey how about a few close ups of the upper shock towers and the motor mounts. Thanks
03-21-2004, 02:12 AM | #14 |
belly dragger
Looks sweet. Keep up the good work
03-22-2004, 11:29 AM | #15 |
needs more $$$
I went through the pics, and all I had that was close to what you want is this one. I'll give my bro the camera to take one of the motor mounts. Let me know if there are any other views you guys want.
Thanks grnddwn!
1970 2wd Blazer Last edited by tubbedII; 03-22-2004 at 12:46 PM. |
03-24-2004, 11:11 PM | #16 |
Anybody laying frame on 22's yet?
'72 Cheyenne super, short-fleet, air-tilt-tach, fuel injected LT1, 700r4, 3.08 posi, 4WDB, step notched and bagged. "the one i wish i still had" |
03-25-2004, 02:07 AM | #17 |
I could if I wanted too. Mine lays frame on a 29.5 inch tall tire!
03-25-2004, 10:27 AM | #18 | |
03-25-2004, 12:31 PM | #19 |
www.loweredd.com
Heck, mine lays rear on a 32"!! It will lay rocker in a few weeks on 32" as well.
03-25-2004, 08:53 PM | #20 |
oh yeah my dad can beat your dad up!! No really I will lay in the rear with a 33x21.50
01-17-2013, 10:23 AM | #21 | |
GoatLube Experss
Re: Crossmember Drop
I think a small cross member notch with a small "Z" would look the best , allthough over all it would be more work I think it would be less modifacation's. gotta keep in mind these guy's were run'n 29" tall tire's back then, I think most of us have taller tire's these day's.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn. '87 R30 dually 454/TH400 '85 1/2 ton CCSB '92 S10 350/350 '84 MonteCarlo 383/PG/9"ford '78 Malibu wagon 350/350 '78 Cutlass (project family car) '96 S10 Jimmy (Moma's) |
01-22-2013, 01:44 AM | #22 |
Ha this is a classic!
Posted via Mobile Device |
03-25-2004, 08:54 PM | #23 | |
03-25-2004, 10:20 PM | #24 |
www.loweredd.com
Phantom, you're funny. I want to see this as well.
03-25-2004, 11:58 PM | #25 |
belly dragger
I wanna see it too!
