Old 04-24-2011, 10:36 PM   #1
coops714x4
coops714x4's Avatar
anyone used expanding foam in there cab ???
As we all know our trucks were not built like modern trucks and they are noisy on the inside I have thought about using expanding foam insulation in the cab! has anyone done or tried this before ??
1971 K20, Coop's beast (project)
1972 C30 wrecker, "Big Ernest" (SOLD)
1975 K5 Blazer (wife's toy) she got it in the divorce
2014 Street Glide Special
1983 K20 Big Block, auto (work horse)
coops714x4 is offline   Reply With Quote
Old 04-24-2011, 10:41 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: anyone used expanding foam in there cab ???
i would think it would hold water and/or moisture.
Old 04-24-2011, 10:48 PM   #3
Hommer
X2!!! I've seen plenty of rust holes caused from this.
Hommer is offline   Reply With Quote
Old 04-24-2011, 10:48 PM   #4
67/72junkie
It will make it rust.Not a good idea .I have seen the results.
67/72junkie is offline   Reply With Quote
Old 04-24-2011, 10:55 PM   #5
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Do not use that crap ass foam it will rust your ride faster than salt water..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 04-24-2011, 10:57 PM   #6
Baggerjohn
Baggerjohn's Avatar
I have never tried this but someone said they used white RV roof sealant as a noise barrier and for insulation. Any feedback on this? Thanks
"Arrive, Raise Hell, Create Confusion, Leave".
Baggerjohn is offline   Reply With Quote
Old 04-25-2011, 12:50 AM   #7
coops714x4
coops714x4's Avatar
thats what I was affraid of. the RV roof sealant might work but isnt it kinda heavy ? there has GOT to be some way of insulating the cab w/o causing rust I would like to do the cab top and B pillars
Old 04-25-2011, 01:29 AM   #8
Pop's C-10
Pop's C-10's Avatar
I think you have to use closed sell foam..i thing that's tha stuff that hold water.. not tha spray can kind you get @ home depot
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 04-25-2011, 09:12 AM   #9
mbgmike
the new cars come with foam in the body cavities for sound proofing. Foam comes in many formulas. what you buy at the store(Great Stuff by Dow Chemical and others) is not made for vehicles. You have to get the correct product, so many times people buy the wrong stuff and say it does not work or is a crappy product. Most times its miss used. The new vehicles have better coatings on the parts and properly applied they work. The correct foam has virtually 0 absorption but you won't find it over the counter at most stores. These trucks do not have the rust preventive treatment inside like the newer vehicles. If you want to try it reply and I can get the correct product number however it applys to new properly treated metal. I feel like doing a test now on the correct foam with untreated metal like these trucks and see what the results are.
IMPAXX is a dow product that the oem use in the new cars
added
the correct stuff absolutely does not warp panels. if it does you are uisng the incorrect product
mbgmike is offline   Reply With Quote
Old 04-25-2011, 10:21 AM   #10
ls1nova71
ls1nova71's Avatar
Along with the possible rust issues others mentioned, don't underestimate the force that stuff produces when it expands. I had a buddy of mine spray it in the trunk lid of a very nice Cutlass, and it warped it beyond repair. It did stop it from rattling though (loud stereo), but I wouldn't try it on the roof of my truck.
ls1nova71 is offline   Reply With Quote
Old 04-25-2011, 10:47 AM   #11
68gmsee
Active Member
68gmsee's Avatar
True. They can warp door frames also...
68gmsee is offline   Reply With Quote
Old 04-25-2011, 10:57 AM   #12
stich626
whats the stuff they put bewteen the inner hood/deck lid and the skin from the factory?
stich626 is offline   Reply With Quote
Old 04-25-2011, 12:06 PM   #13
BIGBLU 72
BIGBLU 72's Avatar
ill tell ya what its good for tho! i used it to fill holes in rusted rockers in my Jimmy before i replaced them! just a little sanding and black primer and you couldnt tell there were any holes lol
68 C10 LWB 2/4 drop 406/th400/3.73posi
04 Silverado SS LQ9 6.0/4L65e/4.11posi AWD
BIGBLU 72 is offline   Reply With Quote
Old 04-25-2011, 12:17 PM   #14
sanford66
sanford66's Avatar
HAHA, one of my brothers does this. He drives rusty 73-78 chevy trucks, fills the holes in the floors and rockers with spray foam and closes the door.....instant weather strip. Just be sure to spray some WD-40 on the bottom of the door or the foam will stick and get ripped out when you open it!! It does work but i would never use the stuff on any of my trucks, it does cause rust! Joseph
1970 Chevelle Nomad station wagon
1966 C-10 lwb,250-six,granny 4speed
1966 C-10 lwb,factory A/C,Custom Cab
1954 Delray 2-door sedan [rat rod project]
sanford66 is offline   Reply With Quote
Old 04-25-2011, 01:00 PM   #15
ol'blu72
If your looking for sound insulation cant you use Dynamat, its a product you can get a car stero shops that deadens sound and is made for vechiles.
Brad
72 Blazer CST 350/350/205
ol'blu72 is offline   Reply With Quote
Old 04-25-2011, 02:00 PM   #16
coops714x4
coops714x4's Avatar
Nope how would you put it between the roof panels?? the only way I see to insulate and sound proof the roof is to use some kind of "LIQUID" that will dry and fill the space. Ive even thought about using the "do it yourself bedliner" just turn the cab upside down and pour it in ! you would have to be able to move the cab around to make it cover evenly, sounds kinda silly and I dont know how well it would "bond" to the cab without prep. there has " GOT " to be SOMETHING that can be used WITHOUT causing rust
Old 04-25-2011, 03:40 PM   #17
Fitz
Dynamat on the inner roof panel will quiet it down considerably. When I did my interior I put it on every surface that would be covered by panels, headliner or carpet. The inside looked like an explosion in a Reynolds Wrap factory but it kills the noise just fine!
Fitz is offline   Reply With Quote
Old 04-25-2011, 04:08 PM   #18
coops714x4
coops714x4's Avatar
sure you can do that on a truck with a headliner mine is a 71 "bare metal"
Old 04-25-2011, 10:23 PM   #19
swamp rat
swamp rat's Avatar
Don't know about any end results but your not the first to think about it, the first thread is pretty informative.
http://67-72chevytrucks.com/vboard/s...ght=spray+foam
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 04-25-2011, 11:51 PM   #20
coops714x4
coops714x4's Avatar
SWAMP RAT thanks for the links I read through them all then did some research here is what I have found out DO NOT use open cell foam it will act like a sponge and let moisture become trapped thus causing rust CLOSED CELL foam will work as long as the brand you choose DOES NOT have a corrosive base "where is a chemist when ya need one" ADHESION the product must " STICK" to bare metal EXPANDABILITY " DONT use a foam that expands more than 2 times its liquid state' there are foams that do not expand but they take alot longer to cure " up to 8 hrs per cubic inch.
NOW that I have done the research Im going to experiment I have a friend who has a 69 cab that the bottom is BAD CANCER but from the body line up is real good, I talked with him and we are going to use CLOSED CELL NON EXPANDING FOAM and turn the cab upside down fill the roof area and see what happens! Ill let ya know how it comes out, we may even wait a while then cut the roof and see what it looks like COOP
Old 04-26-2011, 12:16 AM   #21
swamp rat
swamp rat's Avatar
I think aside form the moisture concerns there is a thread of it expanding too much and having no place to go so it ruins the cab, good thing you have a test piece!
EDIT: I believe in one of the threads somebody was going to give it a try and never came back with the results, if ya find that post (if its in one of the threads i posted) i'd probably PM him to see how it turned out.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 04-26-2011, 10:49 AM   #22
stsalvage
Scrapper 1
stsalvage's Avatar
Smile Re: anyone used expanding foam in there cab ???
Now i'm hearing of a shop in AZ that uses that bed liner stuff they spray the inner rocker panels they spray all of the undercoating I even heard one guy cutting off the roof and having it applied to the piers and both sides of the deuddle panel roof Me i think its too much more Me i would spray the undercoating heavy my 1971 nova has heavy undercoating done and no cancer in the floor
stsalvage is offline   Reply With Quote
Old 04-26-2011, 10:54 AM   #23
N2TRUX
Happy to be here
N2TRUX's Avatar
If it were me, I would Dynomat it and install a headliner. Seems like a lot of work to keep an exposed steel roof.
Another option is Lizard Skin.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 04-26-2011, 11:35 AM   #24
68 IRON
68 IRON's Avatar
Ya dont do it. My son's truck has this foam in every cavity of his hood. Its starting to break down, probably from the heat. Its a mess! Probably holding moisture too. We'll take some time and pick it out slowly but surely. I'm even thinkin' about getting a new hood because of it....we'll see how it goes. PO probably thought it works great around his pipes in his house so why not....
This proves there really isn't a dumb question, huh?
68 IRON is offline   Reply With Quote
Old 04-26-2011, 12:12 PM   #25
coops714x4
coops714x4's Avatar
OK guys let me clear this up I am NOT using the spray foam that you get had the lumber yard or hardware store Im going to use a commercial CLOSED CELL, NON EXPANDING foam that is made for automotive use (READ MY LAST POST) right now I am researching products made by 3M, DOW,and DUPONT once I find the RIGHT product (THE ONE THAT I FEEL MOST COMFORTABLE WITH) I am going to experiment on a old cab first
One thing that concerns me right now is PREP these products seem to suggest that for these to work right prep is important and there is NO way to prep inside the roof panels. does anyone know what, if anything GM did to the metal that wasnt exposed did they use any kind of coating or inhibitor on them ?
