Old 05-01-2011, 10:27 PM   #1
Mr.C
Mr.C's Avatar
What is my truck?
Can someone help me figure out what my truck is considered? I thought that it was a long horn but there are no holes for the emblem on the box sides. it does have the extra long bed. Also has anyone ever seen a paint scheme of med olive, yellow, med olive?
Thanks in advance, C
How about you go over and introduce yourself, build me up, that way I don't have to brag about myself later.
Mr.C is offline   Reply With Quote
Old 05-01-2011, 10:32 PM   #2
tom perrard
Re: What is my truck?
looks like a longhorn to me could have had the fenders replaced or filled then painted just a guess though.
tom perrard is offline   Reply With Quote
Old 05-01-2011, 11:00 PM   #3
Mr.C
Mr.C's Avatar
I've been stripping it to bare and did not find the holes. I did find factory paint under the grey on everything. The truck was olive and yellow with a yellow and black interior.
Old 05-01-2011, 11:23 PM   #4
tom perrard
thats lookin good bro , going all the way down to the metal is what i did also little more work but well worth it
Old 05-01-2011, 11:40 PM   #5
Pop's C-10
Pop's C-10's Avatar
That some good looking metal under that cab..
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 05-01-2011, 11:57 PM   #6
Mr.C
Mr.C's Avatar
I got lucky just a little rust on it. surface rust on the frame was the worst of it. I was going to paint the frame till I found out about POR15. WOW THIS STUFF IS AWSOME!!
Old 05-02-2011, 12:01 AM   #7
Mr.C
Mr.C's Avatar
Thanks! Removing all the old under coating was a real - well you know!
Old 05-02-2011, 02:52 AM   #8
VA72C10
VA72C10
VA72C10's Avatar
Nice job! Truck is looking good and the wheel base and bed tell me it's a longhorn...
Old 05-02-2011, 04:22 PM   #9
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
it's a longhorn, no question about it,
There were 3 part numbers for the longhorn bades, I'm not 100% sure which one was used and when, nor what the differences were, but I know that many of them were glued on, and not bolted.
Old 05-02-2011, 04:58 PM   #10
Sicklajoie
The Niner
Sicklajoie's Avatar
Great looking truck!
"A good racer is one whose head is in communication with his balls." - Richie Evans
1970 C/20 - 402/TH400/3.54s - 74K miles
2003 GMC Sierra 2500 - Wheatland Yellow
Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183
Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/
Sicklajoie is offline   Reply With Quote
Old 05-02-2011, 09:16 PM   #11
turp mcspray
turp mcspray's Avatar
Wow!! I thought all of these trucks came from the factory with rusty floor supports! LOL!
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 05-02-2011, 09:42 PM   #12
ol'blu72
Looks great! What did you use to clean the underside and get it down to metal?
Brad
72 Blazer CST 350/350/205
ol'blu72 is offline   Reply With Quote
Old 05-03-2011, 12:01 AM   #13
Mr.C
Mr.C's Avatar
Thanks guys for the compliments, not bad for a grand.
To clean the underside I presoaked it in BEAN-e-doo (soybean based no gloves or mask needed 100% biodegradable), then I let it dry and hit it with the tools pictured. If you look close you will see a few oddballs - I used a pipe cleaner (used when roughing up the joints on copper pipes) to hit the real tight spots, I also glued a foam pad on to my electric sander so I could use sticky sand paper instead of having to buy the more expensive "hook and Loop" stuff.
Missing from pictures are TIME, ELBOW GREASE, and some GOOD TUNES.
Did this post get moved? Should I post this in another area?
Old 05-03-2011, 12:50 AM   #14
1IR872
1IR872's Avatar
Yep, I agree, it's a Longhorn
1972 C-10 Custom Deluxe
468 BBC w/ TCI 400 Trans
1IR872 is offline   Reply With Quote
Old 05-03-2011, 01:01 AM   #15
Mr.C
Mr.C's Avatar
How about the colors and options(or lack of)? has anyone run across the color combo before? med olive&yellow&med olive with a yellow and black interior and yellow firewall? Also what do the other options mean? Like no slip? is that posi or one wheel peel? This is my first build and unfortunately I have a whole buncha questions. Is there a site you can go to to see what it all means?
Old 05-03-2011, 09:17 AM   #16
Ozark Tim
Ozark Tim's Avatar
According to the color chart, code 573 is primary paint code 525 yellow and secondary or two tone color code 504 medium olive.
So the firewall would have been the yellow as was the entire truck with a medium olive roof and centerband if that was the two toning scheme.
Yes that is a detroit locker diff! Posi!
Cool truck!
Ozark Tim is offline   Reply With Quote
Old 05-03-2011, 11:12 AM   #17
50bomb
50bomb's Avatar
Cheyenne?
50bomb is offline   Reply With Quote
Old 05-03-2011, 12:53 PM   #18
Ozark Tim
Ozark Tim's Avatar
Its a 70 so option code Z84 = CST, same as Cheyenne option in 71 & 72
Old 05-03-2011, 12:59 PM   #19
ricks71pu
ricks71pu's Avatar
does longhorns not have their own vin number to i.d them? odd seeing gas door in seam. mine is not, nor have i seen one this way.
In the words of my favorite poet, singer/songwriter (Paul Thorn):"What ever you believe, you might be wrong"
ricks71pu is offline   Reply With Quote
Old 05-03-2011, 03:57 PM   #20
Longhorn Man
longhorns have there own model number, but not VIN, there is nothing in any 67 - 72 chevy truck to tell what the wheelbase is.
For the 3/4 ton, a six cylinder will be a CS21034, while the V-8 trucks should be CE21034. If you're dealing with a one ton truck, the six cylinder will be CS31034, and CE31034 for the V-8 trucks.
This info and more can be found on my longhorn web site, http://www.longhorntrucks.freeservers.com/
Old 05-03-2011, 05:17 PM   #21
ricks71pu
ricks71pu's Avatar
model number, thats right. thanks for the correction.
Old 10-22-2011, 01:43 AM   #22
Mr.C
Mr.C's Avatar
Longhorn Man, do you know if the side gas tanks were reproduced? Where can I find new ones?
Old 10-22-2011, 02:51 AM   #23
treveiger
treveiger's Avatar
It's a Chevy I couldn't resist its a longhorn, maybe the holes were welded shut or its not the original fenders?
1969 Chevy c20(Miss Hackjob)
treveiger is offline   Reply With Quote
Old 10-22-2011, 05:14 AM   #24
Steve Hafner
Steve Hafner's Avatar
With the 133 inch wheelbase . . . it's a Longhorn !!
Below, is a picture of someone else's "John Deere" 70 C-20.
Steve Hafner is offline   Reply With Quote
Old 10-22-2011, 08:22 AM   #25
NGN
NGN's Avatar
It just hit me !! Now I know what the problem is with them eight foot bed owner's !!! There kind of like the middel child. Not a Longhorn not a Short Bed but the middle bed. lol .Sorry it just came to my head, maybe I sould go back to bed not enuff sleep and that probly cuase my bed's short. lol. Go ahead Longhorn's laugh but we got nothing to hide. lol. O.K-O.K I'm moving on. Nice work on nice truck you got there. Nick
NGN is offline   Reply With Quote
