05-02-2011, 07:38 PM | #1 |
1971 chevy cheyenne 2wd 4wd conversion
i have a 71 cheyenne 2wd long bed. i bought the truck because the body was mint. i want to make it 4wd can i use the 2wd frame and put 4wd springs and hangers on it.
05-02-2011, 09:47 PM | #2 |
Re: 1971 chevy cheyenne 2wd 4wd conversion
does it have leafs in the rear or trailing arms?
if it has leafs it will be alot easier but both still doable. there are lots of threads on here about doing this just do a little searching.
James 94' Chevy K1500 Extended Cab 4x4 5.7 72' Chevy LWB K10, 350, SM465, NP205 Project "Daily Driver" |
05-05-2011, 10:05 PM | #3 |
trailer arms
05-06-2011, 01:17 AM | #4 |
check out my thread.I just bought a 4x4 frame and swapped everything onto it.
http://67-72chevytrucks.com/vboard/s...d.php?t=429098 |
05-10-2011, 09:55 AM | #5 |
hey bud with the 72 lwb k10 355 4spd 4in lift can i see some pics that exactly what i want to make my 71 2wd like when i convert it
05-10-2011, 09:55 AM | #6 |
onebadbowtie i mean
05-10-2011, 11:32 AM | #7 |
i have an 85 silverado that i bought just as a parts truck i know the wheel base is different but could i use the frame off that to put my 71 chevy on
05-10-2011, 07:21 PM | #8 |
there is a link in my signature to my build thread just click on it. if there is not enough pictures there or dont see what you wanting to see send me your email address. i have some on my computer that are not on here that i can send you.
05-10-2011, 07:23 PM | #9 |
you can do that but it never looks as good when you get done in my opinion. both ways require alot of work so why not go ahead and use the right frame.
05-11-2011, 05:54 PM | #10 |
thanks for showing me that link it looks awesome man neat old beater
05-11-2011, 07:08 PM | #11 |
thanks i appreciate. people give me a hard time about putting a flat bed on it but i like it
05-11-2011, 10:02 PM | #12 |
i have the chance to buy a frame complete with 3/4ton axles all the mounts no body motor tranny and axles whats the ball park range of a price.
05-11-2011, 10:03 PM | #13 |
i meant no driveshafts
05-12-2011, 10:55 PM | #14 |
I'm confused. Axles?
The 3/4 ton frame may or may not be different than you 1/2 ton frame. I've see some GM 3/4 tons frames different than 1/2, but most are the same. Price depends on the year. There are some more desirable axles. A 14 Bolt full floater is very desirable, and abundant. Unless you're running big tires or big horsepower, you really need the bigger 14 Bolt full floater. A 14 bolt semi floater is adequate. A 3/4 ton front axle is just a 1/2 ton axle with bigger bearings, brakes, and 8 lug wheels. You'd be better off to find a Dana 44 (slightly bigger bearings and axles). I have no idea what they'd be worth in your area. Just keep in mind that there are difference in axles. |
05-16-2011, 09:40 PM | #15 |
Stick with a 71 or 72 frame, everything is a direct bolt on, and the body swaps right over. I have built several 2wd to 4wd's and they are actually pretty easy to do. Just rebuilt the 4x4 chassis with your motor and everything like you want, then just get some friends over and swap your body over to the 4x4 chassis
72 3/4t Custom Deluxe 402/auto 66k Original paint 71 3/4t 4x4 Custom Deluxe 10k original miles Original paint 71 3/4t Cheyenne 402 70k original paint 72 3/4t 4x4 Custom deluxe 72 3/4t 4x4 Custom deluxe 91k original paint 72 Cheyenne/30 Dually 69 Camaro SS396 4-speed 13 GMC 2500HD Duramax I bought new 05 Jeep Wrangler "Willys Edition" 12k miles (I bought new) 85 3/4 ton 4x4 Scottsdale 33k miles original paint 86 1 ton 4x4 SRW Silverado 454 restored 80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint 95 GMC 1 ton dually 4x4 my dad bought new 95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles 2002 2500HD 4x4 regular cab 6.0L 67k miles 2002 2500HD 4x4 regular cab 8.1L 28k miles 2003 GMC 2500HD 4x4 regular cab Diesel 93k miles 67-72 Parts for sale |
05-21-2011, 02:51 AM | #16 |
6>8 Plugless........
Nothing else find a 67-72 suburban 4x4 frame and shorten it if you can't find a pick up frame. I think Sharpie has one for sale now.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
05-27-2011, 08:37 AM | #17 |
has anyones used a 2wd frame and put the 4wd stuff on it. if so i would like to see some detailed pics of were the rear hanger for the front leaf goes. the hanger tucked back by the cab.
05-27-2011, 09:55 AM | #18 |
Custom Builder
I have a full set of frame suspension brackets from a 1972 Blazer in storage. If interested just send me a pm.
1932 Chevy Roadster Car and Pick-Up - http://67-72chevytrucks.com/vboard/s...d.php?t=465709 1966 K20 Factory 4X4 - http://67-72chevytrucks.com/vboard/s...d.php?t=455484 (Sold) 1972 K5 Blazer (Sold) - http://67-72chevytrucks.com/vboard/s...ad.php?t=87530 2007 TrailBlazer SS - http://67-72chevytrucks.com/vboard/s...34#post4706534 |
05-27-2011, 02:05 PM | #19 | |
http://www.67-72chevytrucks.com/vboa...d.php?t=310493
06-17-2011, 05:45 PM | #20 |
anyone know if there is a trans kit to make your your sm465 granny gear 4spd into a true 4spd without granny gear
06-27-2011, 10:13 PM | #21 |
anyone use a 90's 5spd and put it into a 67-72 4 wheel drive let me know i want to try it
06-28-2011, 09:55 AM | #22 |
I started to convert a 2wd frame to 4wd, but it was going to be a lot of work and I lucked out and found a 4x4 frame. But if you cant find one it can be done. As far as the front hanger on the rear leafs, I was told that a set of brackets off of a 2wd GMC will work as the frames are the same dimensions as a 2wd Chevy. I dont believe that you can take blazer brackets and make them work as the frames at the rear of a 4wd are a different shape than 2wd.
08-15-2011, 09:39 PM | #23 |
anyone know how i could put overdrive in my 72 k10 pickup besides gear vendors.
10-04-2011, 12:54 AM | #24 |
I have a 72 4x4 frame I am wanting to sell. The only things it's missing is the front driveshaft and the linkage to the transfer case. But I live in MO. If your interested though...
1971 Chevy Cheyenne 1972 Chevy Cheyenne 4x4 |
10-04-2011, 02:38 PM | #25 |
Find a NV4500 frm a early to mid 90's chevy and a NP205 or 208 from the mid to late 80's.
