06-04-2011, 08:44 AM | #1 |
My powerplant is here!!!!
well after saving all my extra money i finally got my engine delivered. Its a 454 .030 over, forged bottom end, flat top pistons, 9.25:1 compression, revalved ported and polished 781 heads, and studed. i know the studs are overkill but thats the way it was assembled by the previous owner.
1971 Custom 10 LWB. 461 BBC and built 700r4 to be transplanted 1997 C3500 DRW Ext cab. 454, 4L80E daily driver |
06-04-2011, 09:00 AM | #2 |
~Rest In Peace~
Re: My powerplant is here!!!!
was this just at a machine shop ?
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
06-04-2011, 09:29 AM | #3 |
sweet!!!! that thing sould get down
first track pass with the new motor on motor http://youtu.be/YgrJaEF_TaQ |
06-04-2011, 09:51 AM | #4 |
I'm doing the same thing but in a 69swb 454 .040 over T56 6speed transmission
Man doesn't it cost a ton to build them BBC |
06-04-2011, 09:54 AM | #5 |
06-04-2011, 12:22 PM | #6 |
Actually with the shipping from Foley MN it was $2000 and i got a balancer and a really good timing set. I am super amped to get this thing fired up. next week i am sending out the money for the carb and roller rockers from the same guy.
06-04-2011, 01:21 PM | #7 |
I bought almost everything for mine new forged dome pistons,all ARP Bolts,inside & outside the motor 554 cam roller rockers 850 proform carb & intake,new balancer,3/8 pushrod from Comp,all new alum pulleys and timing cover
06-04-2011, 02:42 PM | #8 |
keep us posted I would like to see what they run. take some time in choosing a cam for what you are going to be doing with the (street/strip etc...) truck that's were the power is. I hate not being able to drive mine back and forth to work/weekends slaying mustangs and camaros.
first track pass with the new motor on motor http://youtu.be/YgrJaEF_TaQ Last edited by bigboybodry; 06-04-2011 at 02:42 PM. |
06-04-2011, 03:13 PM | #9 |
Good luck with the new build!! Hope it runs like you want it too..
I remember when you were selling off your LS parts.. You going to do a name change?
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
06-05-2011, 01:00 AM | #10 | |
06-05-2011, 01:39 AM | #11 |
motor exploder
Gotta love oval port big blocks! Also, if you're gonna go though the trouble to get the heads flowed and pick a cam, are you getting a custom cam? If so, I will recommend Chris Straub (www.straubtechnologies.com). You can check his work out over on www.chevelles.com in the 'performance' section. He cut me a roller cam for my 468, and really knows his stuff, especially when it comes to street/strip BBC's.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
06-05-2011, 11:56 AM | #12 | |
06-07-2011, 11:05 PM | #13 |
Good luck with the build! I have a similar motor for my son's truck. Personally I wouldn't flow the heads or get a custom cam. I think your money could be spent better elsewhere.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
06-10-2011, 01:06 PM | #14 |
here's my builb if you wanna take a look
http://67-72chevytrucks.com/vboard/s...d.php?t=468622 |
06-18-2011, 11:04 AM | #15 |
So does anyone want to take a guess at my torque and hp numbers?
Here are the goodies: 9.25:1 compression Ported and polished 781 heads Hyd roller cam @ .050; 236/242 dur, 521/540 lift 1.7 roller rockers Msd pro billet dist 750 cfm carb edlebrock air gap intake hooker super comp headers 1 7/8 primaries
06-18-2011, 01:50 PM | #16 |
I say 522 hp @ 5900 and 540 ft lbs @ 5300
The TEAL GMC build thread is HERE 1972 GMC SWB 454 oval ports TH400 fastest 1/4 mile time so far 13.05 @ 104 If you think you have too much horsepower you obviously have a traction problem ! |
06-18-2011, 02:26 PM | #17 | |
06-21-2011, 09:58 AM | #18 |
sounds like a solid 500+ combo.
Doug Looking for a 67-72 short bed driver..... |
06-30-2011, 05:30 PM | #19 |
I just got my Hooker Super Comp headers from 70shortwide. These things are awesome. I also got my fuel system and ill post pics tomorrow
06-30-2011, 06:07 PM | #20 |
If anyone can help im also looking for a tall deck 427 block
06-30-2011, 07:13 PM | #21 |
motor exploder
Who ended up doing your cam for you? Specs above look like a Comp Cams grind.
As for a hp guess, I'll say 530hp @ 5500 and 550tq @ 4300
06-30-2011, 08:48 PM | #22 |
you are spot on it is a Comp Cam
07-08-2011, 11:10 PM | #23 |
those things look familiar lol
Posted via Mobile Device |
07-09-2011, 12:24 PM | #24 |
Lol you don't say
07-09-2011, 12:47 PM | #25 |
Registered Truck Offender
Is this motor going on a reputable Superflow dyno,, or are we just 'guessing' ?
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
