Old 06-08-2011, 01:34 PM   #1
djunkie
djunkie's Avatar
Aftermarket tach mounting
Trying to decide where to put mine. Its a 3 3/4 Autometer. Was gonna put it on the column but I think it may block the speedo and gas gauge. Where is everybody mounting theres.
djunkie is offline   Reply With Quote
Old 06-08-2011, 10:25 PM   #2
slugish
Slugish
Re: Aftermarket tach mounting
Put mine here
slugish is offline   Reply With Quote
Old 06-08-2011, 10:47 PM   #3
djunkie
djunkie's Avatar
Ya but what did you do with the fuel gauge?
Old 06-09-2011, 10:46 AM   #4
motornut
78K & 79C Jimmys
motornut's Avatar
a little more to the right if your not using the AC
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 06-09-2011, 10:56 AM   #5
ScottsdaleC20
ScottsdaleC20's Avatar
I attached mine underneath the radio/ashtray.
ScottsdaleC20 is offline   Reply With Quote
Old 06-09-2011, 12:33 PM   #6
Adams74Chevy
Adams74Chevy's Avatar
Mine was put in be the p.o. and he put it on top the dash next to the pillar on the drivers side. I like the placement of it. It's not in the way of other gauges and it's visible looking out the windshield w/o being in the way either. These are the best pictures I have showing it. One from the outside and inside.
2006 Silverado Crew Cab 1500 4x4 5.3L automatic
1986 M1008 CUCV 6.2L Detroit Diesel TH400 4.56 Detroit Locker rear NP208
1973 K20 "Silverado" 350ci, HEI, TH350, NP203 with 2wd conversion, A/C, power windows,tilt wheel, dual tanks. My '73ish K20 thread My 5yo son claims it as his.
1987 V20 Custom Deluxe 350 TH400 NP208 "farm truck" getting parted out.
2016 Nissan Altima grocery getter/commuter
Adams74Chevy is offline   Reply With Quote
Old 06-09-2011, 02:33 PM   #7
kikkegek
kikkegek's Avatar
bottom left:
and a pic at night:
kikkegek is offline   Reply With Quote
Old 06-09-2011, 10:56 PM   #8
slugish
Slugish
Got one from a tach cluster at the bone yard. which is a lot smaller & put it where the clock normally goes on the lower left.
Old 06-10-2011, 12:54 AM   #9
redneckchevy
redneckchevy's Avatar
I put mine on the steering colum, from the photos it looks like its in the way but i have had it there for about a year and its never been in the way.
redneckchevy is offline   Reply With Quote
Old 06-10-2011, 12:55 AM   #10
lbrowne
That smaller tach looks sweet - what bulbs do you have in there? I like how well lit it is.
lbrowne is offline   Reply With Quote
Old 06-10-2011, 01:02 AM   #11
Altec
Getcha Pull
Altec's Avatar
"Back in the day" my truck was setup with a 5" Autometer with shift light strapped to the column covering the fuel level gauge. The fuel gauge could be checked by a simple lean to the left, and you had a easy to see tach. Which was the speedo for a while because the real speedometer was broken, and there was also that time the fuel gauge was broken anyway lol.
Sorry, no pictures. I'm a huge fan of that spot though, and since I could see the fuel gauge with the 5", the 3.75" will be fine. Your gauge will be low, and the fuel needle is near the top.
'81 K10 454/SM465
'86 S10 Blazer
'95 H-D Softail
'96 Integra
Altec is offline   Reply With Quote
Old 06-10-2011, 01:26 PM   #12
Clos'84TX
Foom, foom, foom!
Clos'84TX's Avatar
I have often thought about mounting LED lights behind the bezel with the gauges. In a way that you can't see the actual light but can see the lighting effect..
Has anyone done this?
- Dan
84' LWB C10 // 2.5" from collector back. duel Turbo
Mufflers // 350 w/ TH350
long Headers//3.73 rearend gears
Future Mods
3/4 suspension drop
Clos'84TX is offline   Reply With Quote
Old 06-10-2011, 03:30 PM   #13
djunkie
djunkie's Avatar
Well I put it on the column. Doesn't seem to block the speedo and fuel gauge too bad.
Old 06-10-2011, 03:30 PM   #14
kikkegek
kikkegek's Avatar
if you mean my tach, then the bulb in the tach is teh standard that came with the tach and in my case can not be replaced, because it is soldered in by the manufacturer. I tried to open up the tach, but I could only get the lens and faceplate of, but not the tach out of the house. It seemed glued to the back and I didnt want to damage it.
I backlit my dash like this, here are some pics. I chose soft white SMD's in stead the bright white people usually go for, because this is more authentic to the car and is not white but also not yellow, but really nice on your eyes at night
follow this link to my build and you can see the pics.
http://67-72chevytrucks.com/vboard/s...0&postcount=34
Old 06-11-2011, 12:20 AM   #15
lbrowne
I was gunna do that until the column moved with the gear stick!
Old 06-11-2011, 12:59 AM   #16
Mikec10
Mikec10's Avatar
how i have mine done. makes my truck look mean as hell from the outside lol.
1980 C10 SWB Yukon 5.3/5 speed 3.73 gears.
Mikec10 is offline   Reply With Quote
Old 06-11-2011, 01:22 PM   #17
lbrowne
Kikkegek: What lights are you using in your dash??
Old 06-11-2011, 01:56 PM   #18
kikkegek
kikkegek's Avatar
its an RGB SMD strip. Normally you get in each light point Red,Yellow and Blue. But I got a strip with three whites. And I choose a soft tint of white. So it looks normal and is easy on the eyes at night.
look on ebay for "rgb warm white led strip"
http://cgi.ebay.com/1m-LED-STRIP-505...item3a64df37c4
Old 06-11-2011, 02:04 PM   #19
djunkie
djunkie's Avatar
Mine is mounted higher on the column. I had to slighter modify a hose clamp to make it fit around the turn signal lever but it worked out good.
Old 06-11-2011, 06:29 PM   #20
The prior owner mounted the tach here on my 83.
I cleaned up his wiring mess, but for now I am going to leave it where it is.
Old 06-11-2011, 07:58 PM   #21
djunkie
djunkie's Avatar
Heres a couple more pics. And 1 you can see how I trimmed the hose clamp to clear the turn signal lever assembly. I was worried it may weaken the hose clamp but it ended up working out. I can't tilt my steering wheel all the way up though as it hits the tach mounting bracket but it'll go up a coupe notches.
Old 06-11-2011, 08:01 PM   #22
3r!c84
Badass
3r!c84's Avatar
here is mine..
simple but effective
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 06-14-2011, 12:38 AM   #23
lbrowne
Originally Posted by 3r!c84 View Post
here is mine..
That's a great setup but what is it? Where did you get it?
Old 06-14-2011, 01:38 AM   #24
bluex
bluex's Avatar
Its a 3rd gen camaro tach. Check his build thread in his sig or these:
http://67-72chevytrucks.com/vboard/s...ht=camaro+tach
bluex is offline   Reply With Quote
Old 06-14-2011, 01:48 AM   #25
3r!c84
Badass
3r!c84's Avatar
Originally Posted by bluex View Post
thankyou man!
-00 Saturn 5spd
1/4:13:90
