Old 06-22-2011, 04:35 PM   #1
hotrod1
56 - autocross
hotrod1's Avatar
What radiator?
What size radiator should I use for my 56? Would a griffin for a 67 to 69 camaro work? Or are there better options?
hotrod1 is offline   Reply With Quote
Old 06-22-2011, 07:24 PM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: What radiator?
Camaro is a cross flow and way to wide. Griffin makes one for your truck
Old 06-22-2011, 07:49 PM   #3
Rude Dude
Rude Dude's Avatar
Re: What radiator?
I used a camaro 67-69, bought new on egay, welded 3/8 strap on core support and tapped for fine thread worked good. I didnt like tank sticking up over core support my prefance
Rude Dude is offline   Reply With Quote
Old 06-22-2011, 08:57 PM   #4
candyx
candyx's Avatar
Re: What radiator?
I just placed a order for one from Wizard Cooling and should have it in two weeks.Bolt in direct with a trans cooler built in and a electric fan.Looks good in their ads so in two weeks I'll fine out when i unwrap it,lol.
candyx is offline   Reply With Quote
Old 06-23-2011, 05:42 AM   #5
mbgmike
Re: What radiator?
We offer these. made in the USA aluminum or copper and brass. if interested
mbgmike is offline   Reply With Quote
Old 06-23-2011, 01:23 PM   #6
samdjr74
Re: What radiator?
I bought one a few years back on ebay listed as a 55-59 rad but it's too wide. It still works, I had to make some adjustments to the core support but no big deal. It might be for a 58-59 if they are wider.
samdjr74 is offline   Reply With Quote
Old 06-23-2011, 05:38 PM   #7
55metalmonkey
Re: What radiator?
how much would an alum. one run me? w/ oil cooler for an automatic
I find that I'm unexpectantly in the market for one!
Long story short.....When I picked up my truck the PO included a new one he bought... boxed up never opened and definately never used, recently I opened the box and low-and-behold it's for an AD not a TF.... dohhh!
Cost of shipping included would be great as well, been tramatized by the UPS driver a few times on that one.
55metalmonkey is offline   Reply With Quote
Old 06-23-2011, 06:07 PM   #8
mbgmike
Re: What radiator?
the one in the picture fit. You have to modify the core support see pictures. thes come with the top and bottom bracket.
Old 06-23-2011, 06:19 PM   #9
mbgmike
Re: What radiator?
Make / Model Chevy Truck
Year(s) 1958-59
Engine All
Notes Crossflow Conversion Radiator, Top and bottom mounting plates included. (Must notch support gusset)
Material Aluminum die stamped to eliminate weld related failures
Available Cores High Efficiency Aluminum
Core Size 18-3/4 x 24-1/2
Available Rows 2
Cooler Size 8-1/2x1/4 NPT
Flow Type Crossflow
Inlet Size 1-1/2"
Outlet Size 1-3/4"
made in usa one year warrantee
they run $369.00 each.
i will have to get back on shipping quote
optional shrouds are like $69.00 w/o fans or single and two spal fans also
Old 06-23-2011, 09:19 PM   #10
hotrod1
56 - autocross
hotrod1's Avatar
Re: What radiator?
MGBMIKE:
I am going to run as much as 650 HP and an LS motor.
I heard that you need a model that can accommodate this.
Is this the same price and what is the make?
Old 06-24-2011, 12:23 AM   #11
55metalmonkey
Re: What radiator?
Should have mentioned it's for a 55 GMC, frame has been modified with a Camaro clip so altering the mounts isn't a big deal. I don't imagine the price is much different for 55-57 and 58-59.
the price is pretty good but I find the shipping is what kills me so the most cost effective method is fine, even if it takes a several weeks is fine by me.
Old 06-24-2011, 03:24 PM   #12
mbgmike
Re: What radiator?
Originally Posted by hotrod1 View Post
MGBMIKE:
They are made by US Radiator in Vernon Ca about 1 hour from you. You can pick it up if you want. For Tech info you probably would be better off talking to them as I am not a radiator guru and don't claim to be I imagine that the copper and brass high efficiency cooler would work just fine. its a 4 row radiator that cools better than the aluminum ones. They can answer all your questions.
U.S. Radiator Corp. | 4423 District Blvd, Vernon, CA, USA | Phone: 323-826-0965
Old 06-28-2011, 01:56 PM   #13
xsgene
Re: What radiator?
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWNX%3AIT
$165 including shipping...sitting in my 53 3100
xsgene is offline   Reply With Quote
Old 06-29-2011, 05:40 AM   #14
mbgmike
Re: What radiator?
no comparison to the us radiator. plus theirs come from china and then assembled here. no comparison. but they are in fact cheap
Old 07-06-2011, 09:23 PM   #15
Dan in Pasadena
Dan in Pasadena's Avatar
Re: What radiator?
How many miles on the truck since installation? Any problems? How was the fitment?
I don't mind the $369 for the U.S. Radiator one mgbmike lists and its local to me, but IF (and it's a big "if") I can get one for $200 less AND it works, why not? There are plenty of other uses for that $200 on my truck, unfortunately.
Dan in Pasadena is offline   Reply With Quote
Old 07-06-2011, 11:21 PM   #16
BIG CHEVY 3600
BIG CHEVY 3600 LONGBOX
BIG CHEVY 3600's Avatar
Re: What radiator?
I have heard it is best to change the antifreeze every 15,000 miles to protect your aluminum rad and heads.
"I recommend changing the coolant every 15,000 miles or so, even for extended drain interval coolant. As coolant ages it becomes acidic and can even hold an electrical charge. This charge can change the voltage of the engine temperature sensor giving a false reading to the engine computer. Old acidic coolant destroys the aluminum in the radiator and engine head. " efficientmileage.com
If I were given 8 hours to chop down a large tree, I would spend the first 6 hours sharpening my ax.
Abraham Lincoln
http://s729.photobucket.com/albums/w...cpZZ3QQtppZZ20
BIG CHEVY 3600 is offline   Reply With Quote
Old 07-07-2011, 05:05 PM   #17
poncho_villa
poncho_villa's Avatar
Re: What radiator?
Any opinions on this:
http://www.championradiators.com/page/423744122
There is also a two row.
http://www.championradiators.com/page/430247590
Just noticed that the manufacturer is the same as the Egay one previously posted above.
58 Apache short fleetside ona 64 chassis:
poncho_villa is offline   Reply With Quote
Old 07-13-2011, 07:48 PM   #18
candyx
candyx's Avatar
Re: What radiator?
Well cancel the order when i called Wizard Cooling today because they never did anything with my order after three weeks.All he had to say was that he understood why i canceled my order,so now instead of bolting in a radiator i'm looking to place another order for one.Buyers beware when dealing with Wizard Cooling in NY.
Old 07-19-2011, 02:48 PM   #19
poncho_villa
Re: What radiator?
So......What did you end up using?
Old 07-19-2011, 08:07 PM   #20
candyx
candyx's Avatar
Re: What radiator?
Went through rutters hot rod shop http://ruttersrodshop.com/
and order one from PRC for a 57 chevy pick up with the auto trans cooler built in.He said their running about a week so if thats the case i might have it next week.People at Rutter Hot Rod Shop seamed to be very helpful and their a dealer for PRC and only used them for their builds.
Old 08-02-2011, 12:01 PM   #21
slimneverdies
slimneverdies's Avatar
Re: What radiator?
I hear that the 47-53 gmc radiators are a little different than chevy version. My question is do you guys think that the original radiators for these trucks have sufficient enough cooling to keep up with a hopped up LS motor. I have a line on a very nice reconditioned one for my Gmc that bolts in for $100.
Long live SLIM
At least try to buy American
slimneverdies is offline   Reply With Quote
Old 08-02-2011, 12:19 PM   #22
BIG CHEVY 3600
Re: What radiator?
Walker rads. been building rads for rods for 70 + years. That's where I got mine.
Abraham Lincoln
Old 08-02-2011, 11:45 PM   #23
slimneverdies
Re: What radiator?
Btt. So do you guys think the reconditioned original copper/brass one will be sufficient enough for an LS motor?
Long live SLIM
Old 08-03-2011, 12:14 AM   #24
poncho_villa
Re: What radiator?
I doubt it! That is what I have now and need to upgrade. The stock rad was designed for about 5 lbs. of pressure and about 150 horsepower. Mine has failed three times with a first generation small block and I'm shopping. Great price you found tho. I'd also be tempted.
Old 08-03-2011, 12:19 AM   #25
slimneverdies
Re: What radiator?
Thanks Poncho. That's all I needed to hear. I'll scratch that off my list and start looking for an aluminum one then
Long live SLIM
