Old 10-15-2012, 10:41 AM   #1
jlsanborn
jlsanborn's Avatar
Re: How about some pics of Static Dropped C-10's
Very cool!
'77 K30 3+3 - "The Crummy"
http://67-72chevytrucks.com/vboard/s...d.php?t=640134
'67 C10 L/SWB - Soon to be daily driver!
http://67-72chevytrucks.com/vboard/s...d.php?t=471776
jlsanborn is offline   Reply With Quote
Old 10-25-2012, 11:29 PM   #2
ivorton74
ivorton74's Avatar
Finally got mine dropped... eBay flip brackets and two cut coils. Truck rides better than I thought it would. I still gotta buy drop shocks though. I'll try to post pics soon
ivorton74 is offline   Reply With Quote
Old 10-26-2012, 08:23 AM   #3
MDc10
MDc10's Avatar
My truck is an 86 short wide c10, Silverado. Funny you should ask, im actually waiting on the lowering kit to come in. Hopefully it will be here today so.i can get started this weekend. I would eventually like to lay frame. I'm trying to get it to the point where I can put bags on it. Everyone I've talked to says to lower It first then bag it. I've been looking at bags on the net from Avs. Are they any good? And as for how low do i want to go, I want it to turn heads, not many trucks around here are bagged, especially not c10s. I recently put a new crate motor and tranny in, now my plan is to hit the suspension hard. I've never had bags so im not really to savy when it comes to dealing with them, so all this is new to me. I've had lowered trucks in the past, and now that i have a little bread im ready to take it all the way. Are bags tough to install? Is it one of those things i.should take and have done? I would like to do it myself if possible, I've done everything on my truck to this point. My truck is lowered a little now, it was this way when I got it. I don't really like how they lowered it, as far as I can tell they cut a coil or 2 in front and in.back they heated the springs and put a bend in them on the end, have you ever seen that done? I'll post some pics after work. I appreciate you getting back at me, no one else has shed any light on the bag dilemma. Would appreciate any help you could give me. Like I said I will post some pics of the truck stance and all around after work.
Thanks, Mike
MDc10 is offline   Reply With Quote
Old 10-26-2012, 04:43 PM   #4
ivorton74
ivorton74's Avatar
Tryin to post pics of my truck from my iPod touch but can't. Anyone know how?
Old 10-26-2012, 08:48 PM   #5
502ms
502ms's Avatar
Nice truck. I agree, that cannot be safe (heated/bent leaf springs).
I disagree with spending money twice to lower it.
Determine how low you want to go, and stay on that path. Why? Anything else you do will piss you off. It won't be as low as you want, then you will be removing stuff to sell on Craigslist.
Cry once...spend the money on parts you want and get it done. Once you bag your truck, you won't want it any other way.
People take pics of my truck everywhere I go. I didn't do it for that...but it's a side effect
Best Regards,
Leon M.
502ms is offline   Reply With Quote
Old 10-26-2012, 09:06 PM   #6
MDc10
MDc10's Avatar
what do I need to do to lay frame, as far as bags go? Assuming the back has to be c notched?
Old 10-26-2012, 09:20 PM   #7
lolife99
67-72 parts collector,…
lolife99's Avatar
You won't lay frame with just a c-notch.
Look around in the suspension section.
You front crossmember is the lowest point.
The crossmember has to move up with a frame "Z", or replacement crossmember like a Dropmember from Porterbuilt Street Rods.
Keith
Convert to disc brakes.
Old 10-26-2012, 09:29 PM   #8
MDc10
MDc10's Avatar
I understand that, but im new to bags. I need to lower the truck first right? As far as the crossmember, do I put bags on first then work my way down from there? Just trying to find my starting point.
Thanks, Mike
Old 10-26-2012, 09:39 PM   #9
lolife99
lolife99's Avatar
Thanks, Mike
Bags are just an air spring.
If you want to lay frame,... you have to start that plan from the beginning.
Otherwise you will be spending your money twice.
If you want it low,... I would do a 5/7 static drop.
Laying frame will put you in a completely different price range.
What is your budget?
Keith
Old 10-26-2012, 09:43 PM   #10
lolife99
lolife99's Avatar
MDc10,... if you want to lay frame,... look at these threads.
They will show you the amount of work and money it takes to get these 73-87 trucks on the ground.
http://www.porterbuiltfabrication.co...2-73-87-Trucks
Keith
Old 10-29-2012, 09:05 PM   #11
RustyBillet
Wow, that is scary... I've never seen that done to springs before.
RustyBillet is offline   Reply With Quote
Old 10-30-2012, 10:48 AM   #12
big_al_71
big_al_71's Avatar
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 11-04-2012, 04:51 PM   #13
1971sierragrande
1971sierragrande's Avatar
MDc10,We just put a shackle, hanger kit on my buddys 80' and it had the rear of the spring done the same way. Dangerous!!!! replaced the springs and it rides great now.
1971sierragrande is offline   Reply With Quote
Old 11-13-2012, 08:39 PM   #14
fatgump
fatgump's Avatar
5/7 drop or so, 15" rallys
fatgump is offline   Reply With Quote
Old 11-16-2012, 01:52 AM   #15
ivorton74
ivorton74's Avatar
Finally got a new computer so I can post my pics now. Here's my 74 finally lowered. Ebay flip brackets and 2 coils cut. I'm thinkin 4.5/6 drop. Truck is sittin on bump stops. Am goin to get the front bump stops cut off and remove the rears and get some air shocks for the rear. Also needs an alignment...has a slight camber. Runnin on 235/75s and no rubbing at all. Rides a bit bouncy but not too bad.
Old 11-16-2012, 02:03 PM   #16
s11sean11
my 62 almost finished
s11sean11 is offline   Reply With Quote
Old 11-17-2012, 12:34 PM   #17
502ms
502ms's Avatar
This is hot
Best Regards,
Leon M.
Old 11-25-2012, 01:01 AM   #18
HouldenCaulfield
what are the specs on your 62 Sean11? How did you get it this low?
HouldenCaulfield is offline   Reply With Quote
Old 11-25-2012, 05:48 PM   #19
gearys 5600
gearys 5600's Avatar
COOL truck !!
MY BUILD THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=423629
1969 custom/10 swb--SOLD
1968 swb 50th anniv.--SOLD
1967 camaro ss/rs..LS-6-speed, 16-year long project
1956 chevy nomad
1955 chevy 210 2-dr sedan
1978 el-camino ss 1-owner
gearys 5600 is offline   Reply With Quote
Old 12-31-2012, 10:02 AM   #20
fatgump
fatgump's Avatar
Before and after
Old 08-01-2013, 11:22 AM   #21
dubie
dubie's Avatar
Not a C10 but mine is a static dropped pickup and it's still a solid axle and running 15's
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 08-03-2013, 10:16 AM   #22
jlsanborn
jlsanborn's Avatar
Nice truck!
Old 11-20-2012, 01:19 PM   #23
statiC10
statiC10's Avatar
About a 6/8 drop on 28" tires.
2000 Camaro SS M6.
'81 C10 6/8 drop.
http://farm9.staticflickr.com/8489/8...41d04a64_z.jpg
statiC10 is offline   Reply With Quote
Old 11-24-2012, 11:25 PM   #24
INSIDIOUS '86
INSIDIOUS '86's Avatar
6-8 drop 3" springs and spindles up front. Rear flip with "2 shacke. With 245/50/16 and 295/50/16.
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 12-06-2012, 10:44 PM   #25
ivorton74
ivorton74's Avatar
sid...are those wheels coys or what are they?
