Old 08-18-2011, 02:40 AM   #1
shrunken66stroker
shrunken66stroker's Avatar
Completely reworking the hood
I did a photo chop of what it would look like to have the hood opening smaller and relocated to the top. I've always wanted to weld the cowl ends to the hood to get rid of that body line and this would be one way to make it look good, I think. I made the body lines a little dark so you could tell where they are. Thanks for the pic Dino. What do you guys think?
shrunken66stroker is offline   Reply With Quote
Old 08-18-2011, 05:48 AM   #2
Blue666
Re: Completely reworking the hood
The photoshop looks good to me. If you addded a duct underneath you could use a modern air box or make it a ram air effect hood for a carb engine. Also be able to ditch those heavy hinges & springs.
Blue666 is offline   Reply With Quote
Old 08-18-2011, 07:03 AM   #3
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
It doesn't look wrong, your very talented.
I do however, like the convenience of the original, for working in the engine compartment. But how much time to you spend working on the engine.
Old 08-18-2011, 08:43 AM   #4
Slammed50
It would be cool to make it a one piece front end to get rid of the front seam.
Check out my build thread for my '63:
http://67-72chevytrucks.com/vboard/s...49#post4806049
Slammed50 is offline   Reply With Quote
Old 08-18-2011, 10:58 AM   #5
61TWUK
61TWUK's Avatar
I like the idea... havent seen that before but i do agree with the idea of making the ram air in the front..
1961 Apache
SWB/SBW for now...
Built 327
You need two tools in life: duct tape and WD-40. If it moves and it shouldn't, you use duct tape. If it doesn't move and it should, you use WD-40.
61TWUK is offline   Reply With Quote
Old 08-18-2011, 11:06 AM   #6
gostranger
65 suburban vortec 5.3 bagged
gostranger's Avatar
awesome idea i think a guy from the west coast who had the yellow and white 63 then painted black did something very similar it is bagged and body dropped i think he split the hood at that main seem i will see if i can find a picture
gostranger is offline   Reply With Quote
Old 08-18-2011, 11:10 AM   #7
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
That's one of the things I really like about these trucks. I'd often need a stool to work on my 81, and I'm 5'-11"
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 08-18-2011, 11:12 AM   #8
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
The only issue I see is the radiator may be in the way, but love the idea!!
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 08-18-2011, 06:01 PM   #9
shrunken66stroker
For ram air induction you'd have to run a duct over the radiator and support in the front. It would end up looking like the aftermarket vette or camaro cold air intakes.
I figure the mod will take me about 3-4 days to get the way I want, but I haven't decided weather or not to do it yet. I'll keep photochopping for now. Thanks for the input guys.
Old 08-18-2011, 06:13 PM   #10
suzq044
Resident Photoshop Nerd
suzq044's Avatar
I like it; but what if you made/left that front section as part of the hood? Essentially having the hood open at the grille opening.
PJ - 1966 C10 Panel --
Max˛ - 1964 Jeep Wagoneer Panel-delivery -- Waiting his turn
suzq044 is offline   Reply With Quote
Old 08-18-2011, 06:22 PM   #11
shrunken66stroker
Not a bad idea.
Old 08-18-2011, 06:32 PM   #12
suzq044
suzq044's Avatar
Keeps the body lines cleaner. Good work, now you just need a 3d printer. Lol.. wouldn't that make Modding easier for photoshoppers like ourselves? Lol
Old 08-18-2011, 06:36 PM   #13
gimmy 64
i like the 2nd. one better.
gimmy 64 is offline   Reply With Quote
Old 08-18-2011, 07:06 PM   #14
aerotruk63
aerotruk63's Avatar
#1 innovative
#2 cleaner lines
#3 turn signals in the headlight, when you activate the turn signal, the headlight turns off in the new cars. Take advantage of the housing and mount a turn signal light in the same housing. Cabovers had the turn signal lights beside the headlight for years. Block off the existing turn signal openings as well as the air inlets. Medium duty and heavy duty trucks of our era had an opening behind the headlight with air ducts to the carb.
Old 08-18-2011, 09:55 PM   #15
tommys66
Not a bad idea.
the second one for sure
I love the smell of lead paint!
tommys66 is offline   Reply With Quote
Old 08-18-2011, 10:48 PM   #16
Frizzle Fry
Frizzle Fry's Avatar
Weld the cowl extensions and cowl panel to the hood and make it tilt forward. That's my plan on the 61.
Frizzle Fry is offline   Reply With Quote
Old 08-19-2011, 12:41 AM   #17
shrunken66stroker
It seems like I've been thinking about it for at least a year, Frizzle. It's a monster to try and flip forward. There's no flip kit available like there is for other years, so it would be a fab job. Don't forget gussets on the mounts.
Old 08-19-2011, 01:01 AM   #18
suzq044
suzq044's Avatar
#1 innovative
#2 cleaner lines
I'm pretty sure it's just DRL lights that turn off during signal use, not the actual headlight. A lot of people just use them as driving lights, they're actually high beams at lower power, so they think they're automatic headlights. (at least newer ones are LED-based.. well, in the higher-end market anyways)
Old 08-19-2011, 07:48 AM   #19
aerotruk63
aerotruk63's Avatar
Thank You suzq044, I'm not really up on the technology of the new lights. I found out about them cause I stopped a guy in traffic to tell him that his headlight just burned out and he explained how the new system worked. It makes sense to dim the headlight so oncoming traffic can better view your intention to turn without going to a stronger turn signal light.
Old 08-19-2011, 08:25 AM   #20
fryer1979
Redneck Hillbilly
fryer1979's Avatar
I like how the photoshop concept looks, and it would be cool to see either version actually built. I really like the way molding the sides of the hood to the fenders really seems to clean up the appearance of the truck.
fryer1979 is offline   Reply With Quote
Old 08-19-2011, 04:03 PM   #21
Scot_Douglas
Scot_Douglas's Avatar
Flip the setup you have in #2 photoshop.
Look to a saab 900 for inspiration:
1964 C10 - sold to chris1044
1966 C10
Build 'Fread
Scot_Douglas is offline   Reply With Quote
Old 08-19-2011, 04:07 PM   #22
suzq044
suzq044's Avatar
The flip forward is great; until you actually want to work on the truck, i have heard.
Old 08-19-2011, 05:17 PM   #23
forestb
forestb's Avatar
I hate to be the odd man out. Or maybe I don't? But I am not a fan. I think it makes it look too much like an s10 or something out of mini trucking. Not to say there is anything wrong with that. I just think it takes away from the classic body lines and makes it too modern looking.
forestb is offline   Reply With Quote
Old 08-19-2011, 06:07 PM   #24
awbrown
I have to say that one of the things i like best about these trucks is I do like the lower fender and I can work on it with out climbing up on it .. so I guess if I were to do something different with my hood I might make it hinge in the middle and fold up on both sides .... ah but that would be work and I am , well you know .....
awbrown is offline   Reply With Quote
Old 08-19-2011, 10:47 PM   #25
shrunken66stroker
I put the hood on and roughly taped a line out the would match the height of the top of the bed and match up with the seam on between the front of the fender and piece that surrounds the grill. I'm definitely going go look at for a while before doing anything. We'll see. I've got plenty of other $#!t to do in the mean while.
