Old 08-21-2011, 01:05 PM   #1
Hazieview
Building Dreams out of Dimes!
has anyone removed their coil springs and replaced them with bags?
Hey guys I was wondering if anyone has ever removed their cool springs and just replaced them with bags without modifying the frame.
Any pictures you have would be helpful. Thanks!
1981 Chevy short/wide.
SB400 350th
Hazieview is offline   Reply With Quote
Old 08-21-2011, 01:28 PM   #2
losthope
losthope's Avatar
Re: has anyone removed their coil springs and replaced them with bags?
i dont have a picture but on my old 65 the p/o bagged the rear by using a long bolts that went through the spring hold down bolt holes on each of the trailing arms that bolted to the bottom of the bags and on the top the bags were bolted to a section of c-channel welded upside down to the frame with bolt hole drill in it and also a hole for the air fitting to pass through and then the air line was ran in the space in between the frame and c-channel. worked real well...
Timmy D.
"What that grinding noise?Don't worry about that it will eventually clearance itself!"
1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977
1954 ford customline
H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142
losthope is offline   Reply With Quote
Old 08-21-2011, 01:49 PM   #3
losthope
losthope's Avatar
here i made a pic for you...
Timmy D.
Old 08-21-2011, 02:18 PM   #4
Hazieview
Cool thanks man. I was planning on doing a similar setup but I was wondering if it would work.
Wish someone had pictures of the install....
SB400 350th
Old 08-21-2011, 02:20 PM   #5
65Short
http://67-72chevytrucks.com/vboard/s...d.php?t=129463
65Short is offline   Reply With Quote
Old 08-21-2011, 02:29 PM   #6
losthope
losthope's Avatar
i think the reason mine had c-channel was to add space so when you were aired all the way out the axle didnt hit the frame......in the link posted above the frame is notched.....mine wasnt so thats why they used c-channel i believe
Timmy D.
Old 08-21-2011, 04:57 PM   #7
TR65
TR65's Avatar
I am working on rear bags just to level the bed and allow for heavy loads when I need it, hoping to improve the ride some. Here are the parts. I finished welding today so I will try to install soon.
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 08-22-2011, 11:23 AM   #8
lil_sahara450r
in the process of doing this right now. its a little time consuming due to drilling the needed holes but its not hard at all.
lil_sahara450r is offline   Reply With Quote
Old 09-05-2011, 11:32 AM   #9
kieth
kieth's Avatar
I did my 66 gmc, here is a link to them installed, it is easy and inexpensive: Kieth
http://kieth.smugmug.com/Trucks/66-G...13_zsmuL-XL-LB
kieth is offline   Reply With Quote
Old 09-05-2011, 01:42 PM   #10
rideblue00
rideblue00's Avatar
Kieth, excuse my ignorance but, how much does ride quality change with bags? I was just consdering doing a spring swap.
rideblue00 is offline   Reply With Quote
Old 09-05-2011, 03:31 PM   #11
protrash64
Resistance is Futile
protrash64's Avatar
Here are some more pics.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 09-05-2011, 03:42 PM   #12
Turkey
Turkey's Avatar
I have been reading the "Ride Tech" web page. Looks like they have a bag that replaces the coil spring, so all you have to do is swap the spring for the bag and inflate to your taste. At least that's the way I'm interpreting it.
Turkey is offline   Reply With Quote
Old 09-05-2011, 05:55 PM   #13
kieth
kieth's Avatar
I did it more for ride height than quality of ride, if I lower the bags too much right now, the truck rides on the stock shocks and it becomes harsh, If I raise it back up to the stock stance then it rides great as it did with coils. I think I am going to lower the front 2.5", adjust the bags, then get the proper shocks and I think it will look good and ride even better. Oh yes one does need a rear stabilezer bar with the bags, I have them on the front of my truck but you can tell that they are needed on the rear. (I have them on order) Kieth hope this helps......
ps I have another little project underway, it involves adding air bags to the front along with 2.5" drop spindles, I am trying something different in the air ride height control area to save money and make it work better. will post up after the experiment ends. Kieth
Old 09-05-2011, 06:00 PM   #14
kieth
kieth's Avatar
You are correct but I believe it is for the front of the truck, I have not seen one for the rear.......and they are more expensive......
Old 09-05-2011, 08:15 PM   #15
Turkey
Turkey's Avatar
They have front and rear under the "Level 1" package. Do you need a tank or can you just put in bags and inflate them at home and ride around?
Old 09-05-2011, 08:49 PM   #16
protrash64
protrash64's Avatar
You can install a schrader valve and be good to go. My ride quality is excellent in the 'burb with re7 + re8's and Doestch Tech shocks.
Old 09-05-2011, 09:12 PM   #17
chad64chevy
chad64chevy's Avatar
protrash64 where did you get the top air bag plate at?? keith has the same looking ones and in my searchin i cant find them!!
chad64chevy is offline   Reply With Quote
Old 09-06-2011, 12:33 AM   #18
Captainfab
60-66 Nut
A fellow forum member, jlaird, sells the upper bag plates on ebay. You might try sending him a PM here.
Here is his profile page. Click on the 'about me' tab for a link to his ebay listing for the bag plates.
http://www.67-72chevytrucks.com/vboa...er.php?u=12404
Old 09-06-2011, 10:35 AM   #19
srziemkowski
srziemkowski's Avatar
How low can you actually get just replacing the springs for bags,not just cruising but laying it out a bit more at shows?
srziemkowski is offline   Reply With Quote
Old 09-06-2011, 12:18 PM   #20
jimmydean
jimmydean's Avatar
My '69 had bags front and rear with a 2" cup in the rear (no frame notch) and 2.5" drop spindle discs. Here is a shot dumped.
So figure the front would be 2.5" higher with stock spindles. The ride was awesome with relocated shocks, ECE panhard bar, and KYB shocks.
<edit> Full lift for comparison.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 09-06-2011, 01:09 PM   #21
suzq044
Resident Photoshop Nerd
suzq044's Avatar
What would the difference be between this, and replacing the shocks with air-shocks instead (of springs for air-springs)? O_o
PJ - 1966 C10 Panel --
Max˛ - 1964 Jeep Wagoneer Panel-delivery -- Waiting his turn
suzq044 is offline   Reply With Quote
Old 09-06-2011, 03:05 PM   #22
kieth
kieth's Avatar
air shocks are not a fair comparison, you would still have the coil springs and not be able to maintain a good ride with a lowered stance. Air shocks are used to keep a vehicle level when towing a trailer, air bags do the same thing but also allow one to adjust the overall stance of the vehicle. Kieth
Old 09-06-2011, 03:51 PM   #23
srziemkowski
I would like to see the very lowest someone has gotten with our body style and this method.
Old 09-06-2011, 04:04 PM   #24
losthope
losthope's Avatar
heres a picture with 65 aired out any lower and id have to c-notch the frame
Timmy D.
Old 09-06-2011, 04:11 PM   #25
srziemkowski
That doesnt seem that low,seems like it would get lower,i have just springs and shocks and appears the same if not a pinch lower,especially in the front
