Old 09-10-2011, 02:17 AM   #1
sethv
sethv's Avatar
292 swap?
Hey guys. For those who might of read my 350 build thread, it was failed and I got rid of the motor.
I'm thinking about putting a 292 in my truck. Found a junkyard one for $350. I love inline 6's and I think it would be cool. My buddy's Cherokee turned me onto inline's lol.
What kinda mileage should I expect? And how about driving on the highway? I have 3.42 gears and 245/75/16's.
Also, I know I'll be losing some power.
Would my flywheel from the 350 bolt to the 292? What about accessories? Will I need the 292 alternator and PS pump? Or will my 350 stuff work?
Thanks guys.
1981 K10 Scottsdale
305 ci | TH350 | NP208 |
60k miles
sethv is offline   Reply With Quote
Old 09-10-2011, 12:49 PM   #2
Edahall
Re: 292 swap?
You'll be losing a tremendous amount of power. Here are the specs for a 292
115 hp @ 3400 rpm and 215 lb. ft. @ 1600 rpm
If you really want a good inline 6, I recommend installing a Cummins 6BT. They get excellent fuel economy and have excellent low rpm torque.
1990 ¾ ton 4x4 Chevy Suburban
-Cummins Diesel - 12 valve - factory rebuilt
-6 speed bullet proof manual transmission - NV5600
-Gear Vendors Overdrive - HX35 Holset Turbo
-NP205 iron transfer case
-3.73 gears -2" Lift
Edahall is offline   Reply With Quote
Old 09-10-2011, 02:52 PM   #3
rwhit57
rwhit57's Avatar
Re: 292 swap?
I'm a fan of inlines. The 292 was built for torque and if I remember right they don't get good gas mileage at all. I prefer the 250, with a couple of mods it can run good and get decent mileage. The 250 is probably easier to get parts for also. JMO
rwhit57 is offline   Reply With Quote
Old 09-11-2011, 10:07 AM   #4
dh81k30
Junior Member
dh81k30's Avatar
Re: 292 swap?
IIRC, the 350 and 292 flywheels are different. Think the one in my C20 mounts with three dowel pins and larger bolts and is heavier as well, I think. Your alternator and pump should work, but you will need the 292 specific mounting brackets to mount them. PS brackets can be a challenge to find and I think the alternator bracket is different with PS because of being relocated.
As to mileage, keep in mind that 292's were used mainly in things like school buses and delivery trucks - mileage was never a priority over reliability in heavy, abusive use. The one in my '72 C20 used to get about 11-12 mpg.
Have fun, Don
dh81k30 is offline   Reply With Quote
Old 09-11-2011, 01:57 PM   #5
WarBeard
WarBeard's Avatar
Re: 292 swap?
Get an inline 6 from a Cherokee and you will have tons of power and fuel injection and lots of aftermarket support.
1978 C10 Silverado Big 10 350/350.. play toy
1990 V1500 Suburban 350/700r4..Daily driver
1987 K10 Silverado 383/400.. Wife's rig WRECKED!
1989 V2500 Suburban 350/400.. SOLD!
1974 C10 Custom10 LWB 350/350.. SOLD!
1974 C10 Custom10 SWB 350/400.. SOLD!
1999 Silverado Z71 LS1.. Wife's rig WRECKED!
On the hunt for a new project.......
I'm a Chevy guy.....I'm just not a "NEW" Chevy guy.
WarBeard is offline   Reply With Quote
Old 09-11-2011, 02:38 PM   #6
kwin
kwin's Avatar
Re: 292 swap?
I love big inline sixes! Keep in mind that it is OLD technology ... not that a 350 is a lot better...
There was one in Hot Rod a few years ago in a 1930's Chevy it was turbocharged and ran very quick, so they can make power if you like spending money.
I like different and a 292 would be different for sure!
kwin is offline   Reply With Quote
Old 09-11-2011, 06:07 PM   #7
Edahall
Re: 292 swap?
My dad had a 292 in a 69 Chevy (1/2 ton 3.73 axes 2 wheel drive) that would consistently get 24 mpg on the highway. However, it was extremely underpowered. About 55 mph was as fast as you would want to go with it because it would start burning a lot of oil. He even pulled a 2500 lb trailer with it but would have to crawl up the grades at 10 mph. Anyways, he loved the mileage but hated how underpowered it was.
Old 09-11-2011, 06:09 PM   #8
Edahall
Re: 292 swap?
The 6 cylinder from a Cherokee was an excellent engine. I would take this engine any day over a 292. Another good 6 cylinder engine is the Ford 300 cu in 6 cylinder.
Old 09-11-2011, 06:56 PM   #9
sethv
sethv's Avatar
Re: 292 swap?
It seems like the 292 wouldn't be good in the power department, so based off what you guys said about power, I think it would be better if I just got another 350. I do a lot of running around in the woods, and I haul a lot of scrap.
1981 K10 Scottsdale
60k miles
Old 09-11-2011, 08:49 PM   #10
cjlinkster
cjlinkster's Avatar
Re: 292 swap?
Go for it.
I like the inline 6's too. They may not have as much horsepower, but you really have to compare the torque numbers. I'll take a 292 over a 305 any day of the week.
Some c20's came from the factory with the inline 6, so it should be plenty powerful enough as a truck motor (though not as a drag truck motor).
1984 C20, 454, 4 speed named "Gold Member"
cjlinkster is offline   Reply With Quote
Old 09-12-2011, 06:53 AM   #11
D13
D13's Avatar
Re: 292 swap?
Don't mistake horsepower numbers for power. There are a bunch on 1-ton and 1 1/2 tons running around with 292 power.
They are not particularly fuel efficient. But they will pull like crazy.
You PS and alt will work, but the brackets to mount them are 292 specific. The PS bracketry in particular is not all that common. Be sure the motor you get has all that on it. The flywheeel comments are right on, and motor mounts may be different too. Also V-8 throttle linkages may not work (measure).
The cheapest thing is going to be another 350. The coolest thing is a 292.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 09-12-2011, 07:14 AM   #12
BigBlocksRule
Re: 292 swap?
I hate to commit blaspheme, but here goes...
Run a Ford inline 6. Chevy never built one with a crossflow head (intake on one side, exhaust on the other), all of Chevy's have intake and exhaust on the same side of the head. That'll kill scavenging, makes headers kinda useless.
There are frame and bellhousing adapters available for this swap. Paint it Chevy orange and you'll only have 1 in 100 car guys that'll recognize it as a Ford engine.
As for the 292, it's a bit bigger than the Vortec 4.3, so it's not that much undersized.
BigBlocksRule is offline   Reply With Quote
Old 06-29-2012, 12:34 AM   #13
Inline Fury
Re: 292 swap?
Ford didnt have a crossflow inline in America. The ford 300 was a 12 port head, but not crossflow. A ford 300 in a Chevrolet would be obvious because the intake/exhaust on a ford is on the passenger side and Chevrolet is on the driver's side. Both are good engines.
Inline Fury is offline   Reply With Quote
Old 06-29-2012, 01:29 AM   #14
Inline Fury
Re: 292 swap?
But those specs are for a 1988 chevrolet 292. GM changed quite abit on that engine by 1988. Keep in mind that GM changed the pistons in the 292 from 8.2-1 to 7.6-1 for emissions. The old style pistons had a D-shaped dish and the smog pistons had a full dish, because the quench area on the D-shaped pistons created a lot of HC emissions. The "old" 292s had 153hp @ 3600rpm and 255ft-lb @ 2000rpm. That is NET ratings. Gross ratings are 170hp @ 4000rpm and 275ft-lb @ 1700rpm. So, lets compare this to a 350:
Engine Net HP Net TQ
350 165 HP @ 3800 RPM 260 Ft/lb @ 2400 RPM
292 153 HP @ 3600 RPM 255 Ft/lb @ 1700 RPM
Now the 350 being compared is a 8.5 compression 4bbl. BUT we all know the 350 has more potential for cheap.
Couldnt find a factory dyno sheet from idle for a 350 but i did for a 292. The 292 starts off at 250 ft-lb @ 800 rpm Gross and the torque doesnt drop below that until after 3200 rpm. Keep in mind that this is bone stock info. Ive seen a 292 built with a 3000-6000 rpm powerband and ive built a 350 with a 600-3000 rpm powerband. I compleatly agree with you about the cummins!
Old 06-29-2012, 07:31 AM   #15
Shaun1162
Shaun1162's Avatar
Re: 292 swap?
Don't forget that a 292 has offset motor mounts... You would have to do something different then the stock ones in your truck.
A 250 on the other hand has the same motor mount locations, just needs an adapter to take up the extra space, we have one in our race car a guy built and did it so he could run a 250 in one race, and then switch to a 350 for a different track. Pretty sure 250's have the same bolt pattern, bellhousing, flywheel, clutch, etc. in common with a 250. Also the same oil filter if that really matters haha
- 2010 Silverado
- 1984 Chevy M1028 (K-30)
- 1969 Chevy C-30
- 1933 Ford Stock Car
Shaun1162 is offline   Reply With Quote
Old 06-29-2012, 02:21 PM   #16
beamn7
Re: 292 swap?
We factory ordered our 78 C10 with a 250ci and a 3 on the tree with 3:42's and has been getting 16mpg since the day we picked it up in Michigan fresh off the line. It now has 256,000 miles on it and still runs like a top! Pulled plenty of trailers with it too. You wont get there going 100mph but you'll get there. Very reliable engine.
292 is a great motor as well but as mentioned, motor mount is offset and parts are a little harder to find. All the old UPS trucks were 292's for a long time! Most got converted to 4.3L's in the early to mid 90's. Now we build their trucks with 4.8L's, 6.0L's and a small amount got the 8.1L's. Imagine those driver's going from the 6er's to the 8's! No wonder they love their new trucks!
I say go for the inline. I love 'em and yes, different it will be. Plenty of folks have swapped to a V8 but not many have gone the route of an inline....
beamn7 is offline   Reply With Quote
Old 06-30-2012, 06:16 AM   #17
johnsrob
johnsrob's Avatar
Re: 292 swap?
My wife has a 2002 Jeep Grand cherokee. I have done everything to this Jeep you can think of, I have save alot of labor cost because I do everything myself. I do mean everything under the hood.
LISTEN TO ME WHEN I SAY THIS!!! STAY THE HELL AWAY FROM JEEP INLINE SIX. BOTH MY 73 STEPSIDE AND 86 FLLETSIDE ARE DOW, I DRIVE THIS JEEP THING EVERY DAY AND IT SUCKS, GAS MILEAGE ISN'T ALL THAT BETTER.
can't wait to get back in my truck only a few weeks away
johnsrob is offline   Reply With Quote
Old 06-30-2012, 06:30 AM   #18
cjlinkster
cjlinkster's Avatar
Re: 292 swap?
My old 1999 Jeep Cherokee was decent on power and mpg. It used to get around 22~23 MPG on the highway. I wished that I still had it.
I also owned a 80's Ford F100 with the inline 300, it seemed to have a lot more grunt than the Jeep engine; whereas the Jeep inline seemed to have a much wider RPM range and could run anywhere from 0 to 100 MPH. The Ford engine was good up to 65 to 70 Mph, but perhaps that was due to the gearing.
Old 06-30-2012, 07:59 AM   #19
big10ratrod77
big10ratrod77's Avatar
Re: 292 swap?
Man I love six cylinder engines that’s the way I would go. I am building a 250 for my 79 c-10 it should have plenty of get up and go. I had .040 shaved off the head with sbc valves and a 3 angle valve grind for the head, then I had the block bored .040 over and got all new internals including a new towing cam. I am also putting an offenhouser 4bbl intake with a rockcester q-jet on top, and pacesetter headers, you can view my build thread herehttp://67-72chevytrucks.com/vboard/s...d.php?t=418493
A couple years back I built a 225 Plymouth slant six fir my 73 Plymouth duster and I am sure it pulls harder than any low compression v8 Plymouth had back then. This motor has plenty of power. we spent like 2 weeks porting and polishing the head, we had some huge valves installed it was a big increase over stock(I cant remember the sizes it was a long time ago) had .090 shaved off the head which put my compression at 9.5 to 1 we installed an erson cam with 270 duration and .465 lift and an offy intake with a holley 390 carb and Clifford headers, and this car pulls hard off the line it needs a little more gear ratio to be really strong but i am proud of the way it runs. And heres my extensively modified slant six btw I am kind of addicted to six cylinders
77 chevy BIG 10 350/sm465/12bolt w 3.73 bout 240 horse power NO power steerin
79 chevy 1/2 ton 250/three on the tree/3.08s soon to get built 250/floor shift conversion/3.08s
81 mercedes 300d 25 MPG
77 chevy BIG DOOLEY 454/sm-465/14 bolt 4.10s "fully loaded"
73 plymouth duster 225 slant six/230 3 speed/8 1/4 trying to acheve 300 horse six http://www.cardomain.com/ride/3135091
'77 chevy trucks. built to stay tough.
life is short build a hot rod
big10ratrod77 is offline   Reply With Quote
Old 06-30-2012, 12:55 PM   #20
cjlinkster
cjlinkster's Avatar
Re: 292 swap?
I agree. I really like the inline 6 engines too!
In addition to the Ford 300 and Jeep 4.0, we also had a 1968 mustang with the inline 6. We rebuilt the Mustangs inline 6, and it really transformed it into a nice balanced driver. Plenty of power, felt really nimble to drive. My brother's 69' Mustang with the 302 V8 always felt too heavy on the front end.
Old 07-01-2012, 12:26 AM   #21
rustyrodknocker
Re: 292 swap?
I have a soft spot for most any inline six. I wish they would have stayed around long enough to get in the 400 cu in. range. A 292 is a low rpm engine in comparison to a smali block v8 this is where they get a poor rep. for fuel mileage. if you keep it in its intended rpm range their is a dramatic difference in fuel mileage. this is where it puts its power on the ground anyway. you can spin it faster to go faster but you will pay dearly. just like over winding anything else.
I just finished six years of daily transpo and many several hundred mile trips with a 292/4:56 it got great mileage for a 3/4ton truck.
at 50m.p.h. so match your gearing to your needs
rustyrodknocker is offline   Reply With Quote
Old 07-01-2012, 12:56 PM   #22
Phillip Pennartz
Re: 292 swap?
What RPM range do 292s like?
Phillip Pennartz is offline   Reply With Quote
Old 07-01-2012, 11:28 PM   #23
rustyrodknocker
Re: 292 swap?
see post 14
Old 07-06-2013, 12:16 AM   #24
kjc292
kjc292's Avatar
Re: 292 swap?
Referring back to the specs given in post #2, it depends on what year the 292 is. those specs are after the California emissions which pretty much killed the 292 for americans. I have a 78 and it is perfect if you like to slowly steadily climb to the speed limit. Just purchased a 1967 292. Also needing parts for it....pulleys and pulley brackets. but those older 292's are usually where youll get the better engine overall
79' c20 std cab 292 3speed granny - daily driver.
77' c30 std cab 454 th400 4.10 - fathers truck then mine.
95' ford bronco 302 4speed overdrive.
2002 mustang auto v6 - girlfriends daily driver.
Debt just means that you had more fun than you're suppose to have
kjc292 is offline   Reply With Quote
Old 07-06-2013, 12:50 AM   #25
Zach B
Zach B's Avatar
Re: 292 swap?
A friend of mine actualy has a lot of power out of his 292. He changed the head on it and got an intake on it that took 3 carbs and he changed the exaughst manifold. That's an interesting engine to hot rod.
Zach B is offline   Reply With Quote
