Re: 72 k20 project
Sweet, thanks. I have been looking at the Mickey Thompson wheels since they are one of the few that I like, this wheel is similar but I didn't realize they made it in 8 lug.
![]() Join Date: May 2013
Re: 72 k20 project
Eh,a limp is a small price to pay.
Now the bad back,bad ankles and bad wrists, that's another story. ![]() Truck looks great. The stance looks just right.
Tom 71 K2500 71 K5 Jimmy |
Re: 72 k20 project
Thanks!
finally did some uploading. here are a few from the photo dump! i worked up some oil supply for the air compressor and the IP. the p7100 has been loosely sitting in place for a while because the oil ports are a super pain in the pooper with everything mounted up. started with this fitting in the comp case. this was a really close call getting it installed. par for the course on this turd, it was a bit of a pain. ![]() i used the double ferrule compression fitting and SS hard tube for this as well. simple little bracket to keep from getting the shakes. ![]() using this fancy swivel 90 npt to AN #4 fitting in the block... ![]() i got started with the oil line. ![]() the tee splits the oil out for the air comp and the IP. after some enhancements i was able to use the OE dodge IP supports and made up some more line. ![]() the line is all loomed in convoluted loom. no holes rubbed in my oil lines please! ![]() and a crappy shot of all of the oil line in and the IP installed ![]() |
Re: 72 k20 project
looking good!
Black 93 CCLB 3500 6.5 diesel, GV OD, TCI Ez-TCU controlled 4L80E, back on road 10/25/16 after sitting 4 years. 96 ECLB 2500, 6.5 diesel, auto, gone. |
Re: 72 k20 project
Wow. Looks awesome!!
BRIAN 1986 Chevrolet K20 Silverado 12 Valve CUMMINS P Pumped Intercooled/Getrag360/Divorced NP205/10B/14BFF Detroit Locker - DD Canadian Winter Beater. My Chevrolet CUMMINS Build http://67-72chevytrucks.com/vboard/s...d.php?t=585509 ![]() |
Re: 72 k20 project
Seriously some killer fab work
6>8 Plugless........
![]() Join Date: Sep 2007
Re: 72 k20 project
Great work! You definitely have a little more room for the air inlet than I did with the HT60.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
![]() Join Date: Nov 2009
Re: 72 k20 project
Ryan:
I love the look of the white wheels. I did something similar on mine. I noticed your concern about coolant boiling. Have you considered waterless coolant? I have been running Evans waterless coolant in one of my pickups and one of my tractors for about 3 years now. It has performed great. I am planning to use it in my GMC when I get it finished. Burnett |
Re: 72 k20 project
Just unblocking that plug does wonders. I have personally shot that freeze plug out of a motor before and it is a pain to fix in the truck. I was not fortunate enough to have the bolt out center hump in the ram! I ended up using a factory adapter that does the same thing. Its original purpose was for coolant to an air compressor. Either way you will be happy with that mod when you spin 4k RPMs a couple of times and don't puke the antifreeze like Niagra Falls. Another thing this mod will do is help keep from tearing up the cylinder walls on 5&6. All that extra heat tends to expand the rings and you will see a lot more scuffs on the rear holes.
Sunburst C10!!!
Re: 72 k20 project
Great build! I just read all 60 pages.
Gage 1967 C10 Shortbed Stepside |
#11 | |||
Re: 72 k20 project
Thanks Guys!
so far as the evans, i have considered it. when i get to the filling with fluids stage, that is what it will get. the pressure problem is more of a dead head issue with flow anyway, but i really like the properties and idea of waterless coolant. Quote:
Thats dedication! thanks for stopping in and for the kind words! |
Re: 72 k20 project
Been a while singe I stopped in for a update. Excellent work as always. It would take a guy who hasn't followed this thread days to spit the trick stuff. Wheels are very period correct looking . Great choice
56 gmc 4X4 Cummins 5 spd 60F 70R 2005 Ram 3500 DRW cummins 4X4. 2006 Conolift 9/15. 2011 F 350 winter beater New 2018 ram 3500 drw 4x4. Makes my 2005 Look as if it's been running on 4 cyl since new ! My Build http://67-72chevytrucks.com/vboard/s...d.php?t=556908 |
Re: 72 k20 project
Ha ha. I can't spell. I meant to say it would take someone who hasn't followed this thread weeks to spot all the trick stuff. Not spit all the trick stuff. Lol. Can I blame this on auto correct ?
Re: 72 k20 project
I almost sent him the cast cummins rear freeze plug but was afraid he'd kick me in the nuts next time he saw me because the cummins one is about 1.5" thick.
#15 |
Windy Corner of a Dirty Street
Re: 72 k20 project
Holy cow you’ve been a busy boy Ryan! Your work looks great as always. If there was ever anybody I would allow to touch my truck with a wrench it would be you and Mosesburb Nick. The truck pictures in post 1468 make me feel funny in my pants. I can’t wait until you get this bad boy done and come with us on a weeklong off-road excursion somewhere in the Southwestern desert to enjoy these rides. You’re thread is huge so if you already mentioned it, I apologize but when is your road-ready completion date ETA?
Current vehicle collection: 1978 Chevrolet K10, 8.1L, NV4500, NP205 1989 Chevrolet Suburban, 8.1L, NV4500, NP241 1993 Chevrolet C1500 Sportside, TBI 7.4L, 4L60E 2001 Chevrolet K2500HD, Ext Cab, SWB, 8.1L, ZF 6 speed 2014 Chevrolet Impala LTZ 3.6L Vortec 8.1L because life is too short to tolerate underpowered vehicles
#16 | ||||
Re: 72 k20 project
![]() I accept autocorrect as the perpetrator. happens to me all the time, even on my computer. Quote:
i set myself timeline goals, but my goal is to never stress the 'end' date so i can be focused on the details of it as i go. right now, my timeline goal is to be able to drive it to Iowa late in the spring. i have a buddy that has a get together for first gen cummins trucks around fathers day every year and even though i have a 2nd gen 12v and not a dodge, i still get the invite. id love to make it this year and show those dodge boys how you can have your cummins and still not have an ugly truck too.. hahaa |
#17 |
Re: 72 k20 project
So, after the clutch was installed, this went in
![]() then with a lot of jacking around and ample frustration the trans went it. ![]() ![]() after a few false starts i got all of the parts for this in a pile ![]() ![]() this was my first time working with a np241dhd. i missed a few parts the first order. ![]() the starting point was a 241dhd with a small output. it was from an auto truck so it had a 23 spline input. i built a 29 spline big output case. that included the new input and output as well as a one piece tail housing it was a wide bearing case to start with. so, i think it has all of the big boy parts. ![]() i ordered a 4x indicator switch for a chevy 241c. hopefully it will go in place of the nasty looking dodge vacuum switch. ![]() i still have to detail a few of the little parts, but its ready to go in for the most part. ![]() ![]() the tag is no longer accurate, but it looks good against the case! ![]() put the 6061 pto cover on it. this is counter sunk and uses std 82 degree flat heads. the pto hole is considered the weak point in these. hopefully an accurate location and countersink bolt will help add some stiffness to the game. if not, i had fun making it. ![]() hope to start the install soon. looking forward to getting shifters and drivelines working on this. |
#18 |
Re: 72 k20 project
Looking sharp! Build quality on this whole rig is !!
1972 K2500 Long Box 400/350 |
#19 |
Chevy Enthusiast
Re: 72 k20 project
Like brand new, nice! How hard was the NV4500? Had you done one before?
Tony 1985 GMC K2500 restoration Project: Rust, White & Blue 1989 Chevy R3500 CC Cummins & 4X4 swap some day... 1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress) |
#20 |
Re: 72 k20 project
The transfer case looks great Ryan. I really like the pto cover! Great work.
#21 |
Junk Yartist
Re: 72 k20 project
Ryan, there are at least 2 different shift "combs" that chevy used for the 241C, there's a break in years, I think it's 93, or something like that. Check to make sure the 4wd indicator switch is the same against the Dodge suck switch. there is a visible difference in thread-to-ball length in the GM variations. you should be able to tell if it will work in the DHD just by looking at it
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
#22 | |||
Re: 72 k20 project
Thanks! i have a ways to go before it looks as good as yours!
#23 |
Chevy Enthusiast
Re: 72 k20 project
Cool deal, I'm gonna have to rebuild one pretty soon.
#24 |
Re: 72 k20 project
It'll be a cakewalk I'm sure. Doing upgrades while in there?
#25 |
![]() Join Date: Dec 2004
Re: 72 k20 project
Looking great! What clutch did you go with?
1972 c10,2wd,long bed,250,4spd----> 1972 SWB Fleetside 4x4 12v Cummins build thread http://67-72chevytrucks.com/vboard/s...d.php?t=513791 |
