Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Old 09-23-2011, 01:50 PM   #1
tech@scottshotrods
CPP Drop Spindle Special
Hey Guys and Gals We here at Scotts Hotrods are offering you forum members a deal on the CPP Unofficial name "new school, old School" spindle which will accept your OEM rotor and it will move the wheel in 3/4" per side
$235.00 per pair and are ready to ship!
tech@scottshotrods is offline   Reply With Quote
Old 09-23-2011, 02:15 PM   #2
Clyde65
Clyde65's Avatar
Re: CPP Drop Spindle Special
So these are for the 71/72 suspension?
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 09-23-2011, 02:18 PM   #3
CG
BlahBlahBlah
Are these the ones they called modular or something like that? If so I do need a pair to fit a 71/72 C10. Do they require any other parts? I was thinking they needed some sort of bracket? I have no idea =)
Let me know how to order these please.
Mark
Old 09-23-2011, 06:23 PM   #4
SBTork
Garage wrench
SBTork's Avatar
Mark
I think these are the brand new CPP spindles that use all OEM braking/suspension components. They do also make a modular design one but these are "stock" style.
Also, is that price shipped?
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 09-23-2011, 06:24 PM   #5
Indian113
Indian113's Avatar
What else would I need to put these and disc brakes on my 64? If You can put together a package deal on everything PM me please! Thanks Ray
Indian113 is offline   Reply With Quote
Old 09-23-2011, 09:15 PM   #6
fishingjred73
fishingjred73's Avatar
What is the amount of drop on these?
James
'68 Stepside (ground up in progress)
My 68 build thread http://louisianaclassictruckclub.fre...side-t956.html
'81 SWB "Pap paw" (Driver)
The 81 build thread http://louisianaclassictruckclub.fre...-swb-t960.html
Member of
www.louisianaclassictruckclub.com
https://www.facebook.com/groups/296290610747732/
fishingjred73 is offline   Reply With Quote
Old 09-23-2011, 09:18 PM   #7
Scottshotrods
The spindal is 2 1/2 dropped and these are made very well and all brake parts bolt in place with no issues and the price on them are $235.00 and shipping will be $40.00
we have access to 25 pairs now
Justin
Scottshotrods is offline   Reply With Quote
Old 09-23-2011, 09:25 PM   #8
lolife99
67-72 parts collector,…
lolife99's Avatar
Do you have a link to these on CPP's website?
Keith
Convert to disc brakes.
Old 09-23-2011, 10:14 PM   #9
CG
BlahBlahBlah
Look good so far. I need a little extra room that's why I had my eye on the modulars. But if these move the wheel in the same amount as the modulars, I would rather have these.
Will take a set for sure if this is the case.
Old 09-23-2011, 11:05 PM   #10
fishingjred73
I want a set for my '68. What do I need to do to order?
James
Member of
Old 09-24-2011, 01:22 AM   #11
Scottshotrods
Give us a call at the shop 805 485-0382 we take all major credit cards or you can p/m us your phone number we will call you on our dime.
Justin
Old 09-24-2011, 02:21 PM   #12
mahanian
C10 addict
mahanian's Avatar
Do these spindles move each wheel in 3/4" over the stock 71/72 disc brake spindle (which would match 67-70 drum brake spindles), or do they move them back in 3/4" over the standard 2 1/2" drop spindles (which would move them back to the stock 71/72 disc brake spindle location)?
Do they use 71/72 ball joints and tie rod ends or 73-87 stuff?
Jared
67 C10 CST Short Fleet Big Window
65 C10 Custom Short Fleet Big Window
67 Camaro RS
mahanian is offline   Reply With Quote
Old 09-24-2011, 03:06 PM   #13
Scottshotrods
1.These spindals move each wheel in 3/4 per side
2.You can use your stock ball joints if you want to with these spindals
3.Cpp does have ball joints for 63-70 71-72 73-87
Part number for
63-70 cpp 3010-6-2
71-72 cpp 3010-6-3
73-87 cpp 3010-6-4
These part numbers are for new ball joints and they are $100.00 for all 4 and this is a retail price and forum price on these will be $90.00 for the set
Keep in mind these spindals will not push your track out all when you install them on your truck
These spindals can only be used for disc brakes only
The factory tierods can be used as well with the spindals or you can buy new ones if you would want to.
Justin
Old 09-24-2011, 08:45 PM   #14
mahanian
C10 addict
mahanian's Avatar
Part number for
63-70 cpp 3010-6-2
71-72 cpp 3010-6-3
73-87 cpp 3010-6-4
Justin
I think I may have confused you with my questions so I'll try and clarify.
When GM added disc brakes to the C10's in 71 they shifted each wheel out approximately 3/4" more than the drum brake spindles and they did the same with the 5 bolt rear ends to makes sure the front and rear had the same spacing. When drop spindles came around they pushed the wheel out an additional 3/4". My question to you is when you say "moves the wheel in 3/4" per side" is this in reference to the stock 71/72 spindles or compared to the drop spindles?
Regarding ball joints and tie rod ends, the 63-70, 71/72, and 73-87 are all different parts and the spindles will be bored for one of the three, unless they offer three different spindles.
I'm not trying to be a pain, but this information is important before I decide to order.
Old 09-24-2011, 08:50 PM   #15
lolife99
lolife99's Avatar
I believe CPP will make these in 3 different spindle versions.
I have yet to find the part numbers on the internet.
Have you confirmed that "drop spindles" push the wheels out 3/4" per side?
I've heard that for years,... but never confirmed it myself.
Adding drop springs also increases the track width due to the lower a-arms being at a "flatter" angle.
(more parallel to the ground)
Keith
Old 09-24-2011, 09:03 PM   #16
Scottshotrods
I had a long talk with Mario today from cpp he confirms with there dropped spindals the track width will not get wider like other manufacture spindals he said the track is narrow 3/4 per side and it will not be any wider than the stock track is on your year of truck you have.Before I got off the phone with him today I asked him one more time and he told me again the track will not get any wider with there dropped spindals at all.
I am not repeating myself here I asked this question several times with him today on the phone and on friday with Jeff a few times as well.Jeff confirmed this with me to
Hopefully this helps you all out.
Justin
Old 09-24-2011, 09:10 PM   #17
lolife99
lolife99's Avatar
I think what member mahanian is trying to say is the 60-70 trucks have a narrower track with than the 71-87 trucks.
(only because they are drum brake trucks)
So which track width do these match?
60-70?
71-87?
In all reality,... it doesn't really matter.
These trucks will always have a wider front track width.
The rearends have always been narrower.
The CPP "new" spindle will bring your wheels in 3/4" per side,... compared to all other drop spindles.
Keith
Old 09-24-2011, 09:13 PM   #18
Scottshotrods
There are 3 differnt type of ball joints in those years.Last week in cookville tnn we installed a set of cpp dropped spindals on a buddys 65 and the ball joints had to be changed on his truck so they would bolt up.
Justin
Old 09-24-2011, 09:16 PM   #19
Scottshotrods
Yes you are correct and Mario at cpp told me today it will have the same track width as the stock truck does.As you know these are for disc brake trucks and all the trucks that have drum brakes will have to be upgraded to disc
Justin
Old 09-24-2011, 09:42 PM   #20
CG
BlahBlahBlah
Ok thanks for the info. Basically on a 71/72 this will drop your truck without pushing out the track like most other drop spindles do (I'm pretty sure I have this correct lol). It will keep the track stock.
This means I cant use these because I want my track narrowed a little bit from stock. I believe their modular spindles do this. I will have to call CPP to make sure the modulars do what I think they do.
Mark
Old 09-24-2011, 09:50 PM   #21
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Mark
Mark is 100% correct... if you have the pre '71 setup, these will widen the front track width.
While I didn't use CPP spindles, they are esentially all the same no matter where you get them with the exception of the "modular drop spindles." On my 4.5/6" drop on a '69, it widened the track width .75" on each side (1.5" overall). Just want to make sure people understand what will happen with pre '71 trucks before purchasing.
Adding drop spindles to a pre '71 is not a 'stock option' thus they will not retain the same track width.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 09-29-2011, 01:41 AM   #22
Slow Build
Slow Build's Avatar
It kind of looks like a cross between the "Modular" and regular drop spindle. CPP's modular spindle had a 2" drop and the regular had a 2.5" drop. The modular spindle required disk brake bracket kit but this one is built in. If I can verify that these won't widen my 64's front track (drum brakes changing to disk) more than the 1/4" or so that the "Modular" spindle would I'm all over it.
Two quick questions:
Will these work on my 64 with the 6 lug steel rally wheels (clearance between lower control arm and rim)?
Can you run a dust cover on the behind the disks?
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 09-29-2011, 07:15 AM   #23
Boog
laying low
Boog's Avatar
So a fella can run the 15x8 4"backspace rally with no rubbing issue with these new spindles?
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 09-29-2011, 07:50 AM   #24
lolife99
lolife99's Avatar
I doubt it.
These are 2.25" drop spindles (according to Scott's).
(see below)
The spindle is not the issue.
The contact point in the lower a-arm (balljoint area) and the rim of the 15" wheel.
Trimming the a-arm will fix this.
The regular "Modular" spindle from CPP is only a 2" drop.
Those might clear,... but I don't know for sure.
Keith
Old 10-03-2011, 02:16 PM   #25
Scottshotrods
Here is some more info from Jeff at cpp this morning on the phone.
The spindal you see here in the link forum special is a little over 2 1/4 drop spindal and they will allow you to bolt up your factory disc brakes you have or a aftermaket kits.
This will allow you to bolt up the d52 calipers from wilwood as well.
On ther moduler spindal it is for the guys who want to run a bigger brake in the front and this does not have a caliper bracket part of the spindal you will need to use the cpp bracket they offer for the bigger brake.This spindal is also a little over 2 1/4 drop as well
per jeff at Cpp this morning.
Hopefully this helps you all out a little more
Justin
