Old 09-24-2011, 12:00 AM   #1
longbed67
longbed67's Avatar
Project: Turbo 250
So here it is my first build thread.... So day 1 stats
2 Guys
8 hours
1 '67 Chevy C10
8 Beers
2lbs Venison Steaks
2- 20" Sub Sandwiches
The truck is down to a rolling chassis.... The cab is in the upstairs garage and the rolling chassis is back down in the downstairs shop. I cant express how nice it is to buy a one owner truck that never seen salt and was garage kept.... It is definitely worth paying a few extra dollars for especially when all of the bolts come right out with out busted knuckles all of them except the coil spring bolts in the rear so we just cut out the springs instead. I only get one day per week to work on this so it will be once a week that I post updates and photos. Plans for Day 2 include pulling the engine and trans and power-washing the entire thing so that it is grease free for when I sand blast which is the plan for Day 3.
longbed67 is offline   Reply With Quote
Old 09-24-2011, 12:02 AM   #2
longbed67
longbed67's Avatar
Re: Project: Turbo 250
Here she is as she waits patiently till next Friday....
Old 09-24-2011, 12:23 AM   #3
lowdown72
lowdown72's Avatar
great looking truck to start with whats the plan for it?
72 c-10 67 clipped 327 th400
lowdown72 is offline   Reply With Quote
Old 09-24-2011, 08:29 AM   #4
longbed67
longbed67's Avatar
4 corner disc brakes, self leveling air ride all 4 corners 2" drop spindles up front to compensate for the larger tire size,12 bolt 3.07 Rearend with Richmond Gears and Richmond's Powertrax unit, 20 gallon RCI Aluminum Fuel Cell in the rear. B&W 5th wheel plate, and 2" receiver out back. New Process 435 transmission with twin disc clutch. Engine: MSD Digital 6 Plus ignition, MSD BTM, HEI Distributor, Clifford Intake, Holley 4776 600cfm double pumper carb, SPA turbo Manifold, Machining the head to accept 1.86 Valves, Lump Kit, New COMP cams custom ground turbo cam calculated by Tom Lowe. Methanol Injection, Tial wastegate, New 3" into 2.25" exhaust, NOS 75HP shot spray bar (Prolly never going to use it, but I have an extra laying around with a couple extra tanks laying around), this truck will be my daily driver in the summer. I dont plan on doing the body work until I finish physical therapy school, but ya never know I might get a bug up my butt and decided to dive in and get it done....
Old 09-24-2011, 08:58 AM   #5
502ms
502ms's Avatar
Love it! Subscribed.
Best Regards,
Leon M.
502ms is offline   Reply With Quote
Old 09-24-2011, 09:05 AM   #6
quandelgarage
quandelgarage's Avatar
Nice
old school like your mother.....
My Build--- Body dropped 67 service truck http://67-72chevytrucks.com/vboard/s...d.php?t=485504
quandelgarage is offline   Reply With Quote
Old 09-24-2011, 09:11 AM   #7
OJ1988
Just a car guy
OJ1988's Avatar
A 5th wheel plate? What kind of trailer you gonna pull?
1955 belair Blown Pro Street cruiser
1971 Camaro Pro Touring
1973 Vega Drag Car
1970 C20 tow rig
OJ1988 is offline   Reply With Quote
Old 09-24-2011, 11:55 AM   #8
longbed67
longbed67's Avatar
OJ 1988- I plan on eventually pulling a Cattle trailer occasionally...I dont plan on pulling more than 10000 lbs (trailer wt+cargo) It will just be nice to have a truck with a plate.
Old 09-24-2011, 01:24 PM   #9
longbed67
longbed67's Avatar
I forgot to add I got my wheels and tires i am ordering... Show Wheels Streeter Polished 18x8 upfront with a 18x9 Rear. Tires are General Grabber HTS 255/55R18 Front and 275/60/R18 Rear.
Old 09-24-2011, 03:24 PM   #10
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Looks like you guys made quick work of becky..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 09-24-2011, 03:26 PM   #11
OJ1988
Just a car guy
OJ1988's Avatar
Was that the factory color? If so what was it called?
1973 Vega Drag Car
1970 C20 tow rig
Old 09-24-2011, 04:11 PM   #12
longbed67
longbed67's Avatar
According to the Window Sticker it is Vermillion Metallic-Paint code 515 and the interior is Fawn- Paint Code 600. My sister likes the color... Personally I dont care for it.
Old 09-24-2011, 07:42 PM   #13
hgs_notes
GEARHEAD
hgs_notes's Avatar
I've thought about doing a turbo 6 for a while now. Glad to see someone doing it. We'll just keep calling it Becky.
hgs_notes is offline   Reply With Quote
Old 09-25-2011, 11:04 AM   #14
longbed67
longbed67's Avatar
I need to take the time to lay out all the parts and take a couple of photos... Tom Lowe who lives an hour and a half west of me has been of great help so far in the process of making sure I am doing the right things/getting the right parts with the turbo build and he is doing the machining on my head and crankshaft as soon as I get it out.
Old 09-26-2011, 07:27 PM   #15
longbed67
longbed67's Avatar
So here is my predicament I just degreased and powerwashed my framerail today and turns out what I thought was surface rust was just grime and 85% of the rail is still covered in the factory paint. The other 15% not covered I either power-washed off when I got to close or is light surface rust and could be hand-sanded off. SO.... I already own the equipment and material to sandblast the entire frame and I already have POR-15, Do I take the time and blast the frame and take off the factory paint and start from bare metal and then POR-15 it, or do I just sand the factory paint to scuff it up and sand off any of the remaining rust and POR 15 the frame? Any thoughts or other ideas. On a side note it is not in my budget to pay someone to powder coat the frame as nice as that would look...
Old 09-26-2011, 08:10 PM   #16
FRENCHBLUE72
PROJECT 7DEUCE
Scuff the frame and then do the por...15
MEMBER #6377
Project "7DEUCE"
Old 09-27-2011, 02:03 PM   #17
longbed67
longbed67's Avatar
Looks like I will be pulling the motor and trans and all the lines off on thursday night and Blasting on Friday! Which leaves Sat to Paint! Found out from POR- that it will not properly stick to the other paint, and as long as I use the metal ready (phosphoric acid) it will bond nicely to the bare metal.
Old 10-01-2011, 02:33 PM   #18
longbed67
longbed67's Avatar
Took my head and crank over to Tom Lowe today to get machined... and taking the block in to a local shop on mon. Hopefully this motor can be back together before November. The blasting and painting didnt happen this weekend as planned because the professors laid the homework on thick but oh well there is always another weekend.
Old 10-01-2011, 02:59 PM   #19
longbed67
longbed67's Avatar
Some photos of how things are going, and I had to mock up the turbo manifold to see how it was going to look!
Old 10-01-2011, 05:52 PM   #20
longbed67
longbed67's Avatar
Attempt #2
Old 10-01-2011, 08:35 PM   #21
Krooked Kustoms
Krooked Kustoms's Avatar
Looking like a real clean truck mate. Love the sound of the turbo 6! I'll be watching this one.
Krooked Kustoms is offline   Reply With Quote
Old 10-06-2011, 08:42 PM   #22
longbed67
longbed67's Avatar
Finally figured out what individual parts I need to build my own brake kits so I dont have to pay for someone else to do the research and put a kit together for me! All said and done...including McGaughy's drop spindles and shipping I have a complete front and rear set up with cross drilled and slotted rotors semi metallic pads D52 front calipers, eldorado rear calipers (I need the e-brake), All the lines cables bearings ect... Everything should be in next week I cant wait to get it!
Old 10-07-2011, 07:58 AM   #23
OJ1988
Just a car guy
OJ1988's Avatar
I'd like to hear more deatils on your disc swap parts.
1973 Vega Drag Car
1970 C20 tow rig
Old 10-07-2011, 07:57 PM   #24
kyull67
kyull67's Avatar
Cool. I'm in the middle of a 250 turbo set up. Probably wont have time to get it running for a while though.
kyull67 is offline   Reply With Quote
Old 10-08-2011, 02:39 PM   #25
slow72
slow72's Avatar
I'm thinking about doing this too and in the research/planning/dreaming phase. Except i think i'm going to go with Megasquirt and a junkyard TBI setup.
Where did you get that exhaust manifold from?
1972 GMC LWB, 250, 4sp
2010 GMC Sierra 6.6 CCSB
slow72 is offline   Reply With Quote
