Re: What Did You Do With Your Truck Today ?
Looks cool Tomb23 but what is it? Maybe I'm out of the loop. I have a 3D printer to help out in prototyping if need be. All I need is the STL file.
1952 Canadian Chevy 1300 C4 IFS & D44 IRS 5.3 HO L33 My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938 ![]() |
Oh ya! Forgot. Sprayed on the first coat of paint on the 51. Sprayed Nason epoxy primer on the bottom of cab and up inside the top rear panel in preparation of installing the new rear lower cab panel. Gonna get the inside of the cab done tomorrow. Sandblasted the last two days just on the cab. If I see another grain of sand ......................
The Rubber Shifter Boot
Fleetside bed inner fender body work. Wish I hadn't tossed so many bricks, rock, etc in there for 25 years. Got it close with hammer and dolly, then some skim. Final finish will be bed liner so prefection is not necessary.
FarmerSid, Does a 3D Printer, print with RUBBER or PLASTIC
The one I have makes parts in ABS plastic. Soluble support. Dimension 1200 sst.
Installed a dropped axle from Sid today. Had some trouble with the u-bolts not being narrow enough and had to trim the wedge shims down to 1.75". Bought some new rear brake lines and put some 31x10.50's all the way around it (it's the only size that I had four of) to get an idea of stance.
Stalker Nate
Put on a new sexy Quickfuel blackdiamond 780 VS carb for the 57 as it goes in for dyno tuning tomorrow and the old Holley 670 wasn't gonna cut it.
1957 GMC SWB stepper modified summer time driver 1963 Chevy Fire Dept. Command Center Van 2 ton - future food vending truck project 1965 Chevy P10 Ice Cream Truck project Instagram - TheDonutDiner FaceBook - @UscreamIscream |
Pulled the truck into my garage last weekend- last night I finnally got to work..
Pulled the spark plugs, squirted some marvel mystery oil into each cylinder. Got out my breaker bar to attempt to turn it over manually- then realized there is no crank bolt on this thing... how the heck do you turn it over? I hooked my battery back up, thinking i would try and kick it over with the starter, since it spun for me last week (just didn't engage) I thought maybe i could whack it with a hammer and it would start engaging. Pushed on the stomp starter and POP! No more headlights and no more starter spin. :-( I used engine cleaner and power washed the engine bay before i moved the truck... guessing water got into the starter or something. Will have to pull the starter and see if it will work on its own, then re-install.
_____________________________________ Ben R. 1953 Chevy 3100 Classic Seat Restorations -Preventing me from working on my own projects since 2009! |
Sometimes you can pull the flywheel inspection plate and set a socket and bar on the converter or clutch bolt to see if it will turn or use a pry bar on the flywheel teeth.
worked on exhaust and install of gas pedal plus modified fender support rods. pic's in build thread.
LIL ERV the 50-3600 396 BBC stroked to 415 cid Richmond 6spd over drive C4 rear Porter built a arms Never give the Devil a ride,because he'll want to Drive! |
New radiator and electric fan setup.
http://67-72chevytrucks.com/vboard/s...d.php?t=481531 |
New Boot & Handle Done
#15 |
were did you get you radiator set up thanks... Sp
My Spelling is Not Incorrect...It's 'Creative' . . 1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E http://67-72chevytrucks.com/vboard/s...d.php?t=789617 59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341 |
#16 |
GMCDAC
This is a fun thread to read, but my first post in it as in the last few months all I can say is drove it to work day after day or every now and then make a beer run or jerky run into town--LOL!
We had to haul a garden tractor I had fixed up down to my Father-In-Law today, 150 mile round trip. My wife digs the old GMC, but didn't like my cup holder so last night I built a new one that I was able to attach to an extra ash tray slider. I loaded the tractor with my gantry crane in the shop, but forgot to take the camera on the drive. Came back with a tool box, several new air filters a couple new oil filters, new coveralls and a weedeater scored at a rummage sale. DAC
1970 GMC K5 Jimmy Custom 4X4 Mom's driver from 1971 to 2001!! Under rebuild! 1972 GMC C2500 Pickup owned since 1979 Needs a rest and refurbish! 1955 GMC 100 2nd design driven almost daily! Rest In Peace Mom. "Dolly" 7/15/23 - 5/18/09 GMC driver for 30 years! ![]() |
#17 |
Very Cool, now that's thinking outside the box !! If she loves the truck Do whatever it takes to keep it that way !!
#18 | |
![]() Join Date: Dec 2012
1971 GMC Sierra 1959 GMC 100 |
#19 |
Mounted Fuse Block...................Wiring = baby steps here on out.......
Hope I don't stick a sharp pencil in my eyeball before it is done. |
#20 |
Made up today, this for a guy that's going to be in The Parade of Pickups In Vale, Oregon on The 4th of July weekend. They are trying to set a world record, for the longest Parade of Pickups. Retired Army.
#21 |
That's not a bad drive from Boise, will you be going?
#22 | ||
GMCDAC
It was a decent little tractor, but the garden tractors I use are Massey-Ferguson's, a 1965 to push snow, dirt and gravel and a 1975 for mowing. Thanks---DAC
#23 |
Mounted my spare up front on the side of the bed, its been sliding around in the bed for months. Also installed a fuel pressure gauge.
'55 Chevy 1/2ton pickup w/ Pontiac 350 and Muncie M21 close ratio 4speed "Red Ryder" |
#24 |
Very cool guys!
I haven't had much time to get on the forum, but I bought this souix valve grinding setup for $100. I started tearing it down right away. By the time I'm done, it'll look like a brand new machine! |
#25 |
Well... The cab got taken off the frame. Now to finish some welding on the camaro clip, get it cleaned up and painted. Then start in on brake lines. Woohoo
